Rattling from passenger side
Discussion in '2.5 Gen Tundras (2014-2021)' started by FabioXc, Feb 29, 2024.
  1. Feb 29, 2024 at 9:37 AM
    FabioXc
    FabioXc [OP] New Member
    None
    I had just traded in my ram 1500 for a Toyota tundra but a few days later a rattle noise can be heard ? Sounds seems to be coming from my passenger side ? Any thoughts
    truck had 96000 miles on it with the 5.7 non fuel flex
  2. Feb 29, 2024 at 9:49 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Tundra Crewmax Platinum 4WD
    The 5.7 has a fairly common "Tundra Tick" caused by loose timing chain tensioners. Most common on the driver's side. Some report 5w-30 (instead of the recommended 0w-30) helps to quiet it down. To the best of my knowledge it's never caused an actual failure (it's just annoying).
    Not sure if that's what you're hearing. The Tundra tick is usually only present on startup for a minute or two at most.
  3. Feb 29, 2024 at 9:58 AM
    FabioXc
    None
    Ah I see thank you I was just reallly worried about it
  4. Feb 29, 2024 at 9:58 AM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    bulldog93 and Joe333x like this.
  5. Feb 29, 2024 at 10:03 AM
    FabioXc
    None
    Wish I could show you a video but it doesn’t allow me to upload it on here
  6. Feb 29, 2024 at 10:06 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Upload it to YouTube, and then share the link to that video
  7. Feb 29, 2024 at 10:18 AM
    FabioXc
    None
  8. Feb 29, 2024 at 10:19 AM
    MistrRoboto
    Virginia Beach, VA
  9. Feb 29, 2024 at 10:20 AM
    FabioXc
    None
    Well it’s at the shop right now hopefully they fix it
  10. Feb 29, 2024 at 10:54 AM
    FabioXc
    None
    Other than that it’s drives way better then my ram in my opinion
    Florida AF likes this.
  11. Feb 29, 2024 at 10:59 AM
    Florida AF
    Logan
    North Florida
    I am glad you are happy once they fix this for you. Let us know what it is.
    It took me several months to switch from picking this truck apart to being happy with it. I had three Rams prior to this and missed every single one of them compared to the ride of the Tundra, but now... I wont go back unless I am forced to lol.
  12. Feb 29, 2024 at 11:12 AM
    FabioXc
    None
    Yeah I love those hemis in the rams I owned a single cab 2012 RT but there was also a ticking sound and knocking sounds coming from it but I know those things have lifters and cam issues
  13. Feb 29, 2024 at 11:27 AM
    Florida AF
    Logan
    North Florida
    I was one of those rare guys, or so I am told....
    2013 Lone Star - sold at 86k miles. No issues or dealer trips.
    2014 Laramie - sold at 105k miles. No issues or dealer trips.
    2015 Longhorn ED- Totaled at 107k miles. No issues or dealer trips. (bought used and the carfax was clean when I purchased)
    FabioXc[QUOTED][OP] likes this.
  14. Feb 29, 2024 at 11:32 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Definitely not right. Sounds like something attached to the engine is loose and rattling. Take a look at the heat shields around the exhaust. Also might look at service history as it may provide a clue if something wasn’t replaced or tightened correctly.
    Sierradevil and FabioXc[OP] like this.
  15. Feb 29, 2024 at 11:36 AM
    FabioXc
    None
    Thank you I was thinking that also heat shields
    Also I did check the service history seems everything is good I checked the CARFAX on it but hopefully they fix it
  16. Feb 29, 2024 at 11:38 AM
    FabioXc
    None
    I just hope it’s nothing really bad because it drove really well good thing I got a warranty
  17. Feb 29, 2024 at 11:43 AM
    AZBoatHauler
    So.Arizona
  18. Feb 29, 2024 at 11:46 AM
    FabioXc
    None
    Yeah I hope they can fix what ever it is that sound is . Yeah iam kinda bummed on it but I’ll let you guys know
  19. Feb 29, 2024 at 11:48 AM
    AZBoatHauler
    So.Arizona
    No check engine light? Almost sounds like it could be a broken valve spring but you typically get a misfire code…
  20. Feb 29, 2024 at 11:49 AM
    FabioXc
    None
    Nope no check engine light
  21. Feb 29, 2024 at 12:54 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    That’s probably tensioner #1 drivers side.. maybe 3? Whichever is high on the passenger side. I have the same issue. When it gets that loud it’s time to bring it in to have it replaced. Once a tensioner goes no weight of oil is going to fix it. Mine was pretty quiet until one morning when I let it idle on my inclined driveway after not warming up/building oil pressure. Was way worse when I came back out of the house.
    https://youtube.com/shorts/d6NZUrggv0w?si=JrDDTUxzyckkuTQd
  22. Feb 29, 2024 at 1:06 PM
    FabioXc
    None
    Well i hope they replace that !
  23. Feb 29, 2024 at 1:12 PM
    AZBoatHauler
    So.Arizona
    That definitely sounds like chain slap. :( His seems to have more rattle.
    Mater[QUOTED] and FabioXc[OP] like this.
  24. Feb 29, 2024 at 1:18 PM
    FabioXc
    None
    Yeah mine seems to have more of a rattle
    Mater likes this.
  25. Mar 1, 2024 at 6:52 AM
    xround
    xround New Member
    2015 CM Limited OR
    I have that exact same noise and it seems to come and go at random. Curious to see what you find out, please post an update if it is diagnosed correctly.
  26. Mar 1, 2024 at 7:02 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Invested now, keep us posted, good luck with it in the shop.
    Another note- had a 2016 Ram 1500 before my tundra, manifold seals went bad resulting in a terrible tick and had to replace, something else broke during that repair so I offloaded it before I started down a Fiat rabbit hole.
  27. Mar 1, 2024 at 7:18 AM
    Jaywhy
    Jaywhy New Member
    Jeff
    2016 SW TRD Pro CM
    Does sound like chain slap. Does this typically happen on a cold start once the truck comes down from high idle? And if so, does it go away after the truck is running for a little bit? Check out this youtube video from The Car Care Nut and my comment pinned to the top with a better description of the issue.
    FabioXc[OP] likes this.
  28. Mar 1, 2024 at 8:43 AM
    FabioXc
    None
    It doesn’t sound like an again slap sounds more like a rattle and when it warms up I really don’t hear it as much I remember as well when i cold start it it takes a while for it to warm up unless that’s a tundra thing or that’s a other issue as well but other than that it’s still at the dealership
  29. Mar 1, 2024 at 8:47 AM
    FabioXc
    None
  30. Mar 1, 2024 at 8:48 AM
    FabioXc
    None
    Some are saying add more oil or it could be a heat shield but Iam thinking as well it’s chain issue but will see .
