Rats
Discussion in 'General Tundra Discussion' started by txcoastie, Nov 12, 2017.
  1. Nov 12, 2017 at 6:50 AM
    txcoastie
    txcoastie [OP] New Member
    Andrew
    2018 SR5 Crew Max 4X4
    Anyone have issues with rats getting under the hood and chewing tubing, if so, did anything work
  2. Nov 12, 2017 at 7:34 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've read that Honda make an expensive tape that's infused with cayenne pepper. I wonder if spraying the looms with pepper spray would do anything. This is kind of a known issue, many manufacturers has gone to a soy-based wire insulation and rodents like. Moth balls might help too but the smell may get into the cab.
    NewImprovedRon likes this.
  3. Nov 12, 2017 at 8:02 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've had good luck with cotton balls soaked in peppermint oil.
  4. Nov 12, 2017 at 8:09 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Man I'd be pissed if a driving frickin rat chewed up my tundra! Real pissed! I hope you find a solution. We don't have a lot of rats or here so no problem, thank goodness.
    4x4_Angel likes this.
  5. Nov 12, 2017 at 9:01 AM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    Rat poison
  6. Nov 12, 2017 at 9:26 AM
    geno0506
    geno0506 New Member
    Michael
    My 2010 Tundra was attacked by rats or squirrels, they ate the wiring harness on the engine. I filled up 2 small socks with cayenne pepper and tied them off into a ball and hung them under the hood with small wires, never had a problem again!
    or you can be like this guy
  7. Nov 12, 2017 at 9:40 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    I've got a dumb as rocks neighbor behind me who decided it was their mission to feed every goddamn squirrel in North American. It's now my problem as I found dropping on the intake cover on my Tundra and in my wifes Camry as well. I've advise him the bill for repairs will be going to him via my lawyer, they have since taken the feeders down but now its on!
    FISHMASTER and 4x4_Angel like this.
  8. Nov 12, 2017 at 10:09 AM
    SLOBlueE90
    SLOBlueE90 New Member
    Bob
    San Jose
    2016 White Tundra Platinum
    Peppermint oil is a great place to start. Dilute some in a spray bottle and spray down the wheel wells and engine bay. Also, soak an old t-shirt in some of the oil, wrap it in foil and stick your oil foil burrito in the engine bay. I took some steel wool and stuck it between the engine bay and windshield cowling to seal up any exposure to the HVAC too.
    Finally, use the Tomcat brand outdoor rat traps around your ride. I use peanut butter as bait and I have had great success.
  9. Nov 12, 2017 at 10:17 AM
    TheBeast The Beach
  10. Nov 14, 2017 at 9:51 AM
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Awesome, just spent half an hour watching squirrels and rats get sniped! Lol
    JC303, T500 and 4x4_Angel like this.
  11. Nov 14, 2017 at 10:01 AM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Plenty of rats in NYC, the rodent type and the human type
    NewImprovedRon and TheBeast like this.
  12. Dec 3, 2017 at 5:04 AM
    Fr0gburp3r
    Fr0gburp3r New Member
    2017 Magnetic Grey Tundra SR5 Crewmax 4x4
    Looks like he/she has an extra ear.
  13. Dec 3, 2017 at 5:16 AM
    Slayer
    Slayer Member
    Slayer
    Rats chewed a wire in my truck cost $800 bucks to fix.
    I found some peppermint oil at Wal-Mart.. I poured it in cotton ball stuffed soda can I poked holes in & stuffed it in the upper rear of the engine compartment. WORKS !
    Tomcat & peanut butter works for catchin' the little bastards.
    I'm also going to check out that spray!
  14. Dec 3, 2017 at 9:08 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Through the years we’ve had about $1,500.00 of damage from rodents (mice, rats, squirrels). They can get into the air box through the fender. Sticking a tennis ball in the hole in the air box after parking can prevent this. They can squeeze through tiny spaces. The wire insulation Toyota used (not sure if they still do) was made with a soy biproduct, attracting rodents.
    DO NOT USE POISON, if they die inside your ducts or on top of the fuel tank they will rot and decay and be devastatingly hard to get out and clean up. Use multiple traps, don’t always park in the same place, switch up the bait and trap locations. Peanut butter was already mentioned and works well, add apple slices and pieces of walnut. Cats can help but are not dependable as a deterrent.
    Hopefully this helps...
    NewImprovedRon and Slayer like this.
  15. Jun 10, 2018 at 4:32 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Beast you still using this product? Still been happy with it?
    Im just wanting to be precautionary.
  16. Jun 10, 2018 at 5:08 PM
    TheBeast The Beach
    I used it for a year with no issues. Since then I moved to a difference place with no rats :)
  17. Jun 10, 2018 at 7:03 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    It's a constant battle around here. I used to park next to some bushes, and it was awful. Since I now leave some concrete between the truck and available cover, it's much less of a problem.
    I tried all the various chemical remedies. They work, but then who wants to spray down their engine compartment, replace mothballs, etc. in every spare moment? Who can remember? Also forget electronic sound devices. They get used to that real quick, and back they come. Where I park has made the biggest impact.
  18. Jun 10, 2018 at 7:17 PM
    Tacogrande
    Jeremy
    I dont have rats or mice and my place is very well kept and i park my truck inside. Might get a couple mice in the winter or if there are really trashy people living in a rental down the street and its most likely to happen in winter time. I keep poison set out year round. All that said, i always like to have 2-3 layers of protection against a threat. Always hearing about guys wiring being chewed on is crazy. Who the hell makes the decision that peanut oil goes into making wiring!
  19. Jun 10, 2018 at 7:41 PM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    They chewed my windshield wiper fluid hose a few years ago. :annoyed: That’s embarrassing when you own an exterminating company. :anonymous:I put out poison and didn’t have a problem after that. Agree don’t use poison if truck sits a lot and they may be actually spending a lot of time under the hood.
    Also the secret sauce for bait on rat traps even if they get trap shy, is a piece of slim jim.
    MatthewPTguy likes this.
  20. Jun 10, 2018 at 7:44 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    That’s good information to have... I hate all those rodents... mice, rats, opossums... yuk
  21. Dec 31, 2020 at 9:02 AM
    aindallas
    aindallas New Member
    jack
    2019 White Tundra
    I have had two occasion in the last six months, $1500 of damage each, where squirrels entered the engine compartment and chewed
    the sensors (which to my surprise are made with soy). My local dealer only recommendation was fox urine (a few drops under the hood) as the best solution.
    Seems like there would be a better way to block them from getting to the sensors?
  22. Dec 31, 2020 at 9:11 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Interesting how some critters choose underhood parts to chew on. I live where there are millions of tree and ground squirrels, rats, mice, possums, raccoons, etc. I have 4 vehicles that live outdoors, luckily not once (I know you're listening Murphy) has this happened, yet.
  23. Dec 31, 2020 at 9:31 AM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    It all depends on resources if they have it available to them the usually don’t bother with cars but in areas where it’s cold and busy with people like here in Chicago they love to hide in engine compartments and while their chilling in a cozy spot they nibble on wires and hoses I have fixed many harnesses the latest one I had to do was a 08 Charger the owner is a cop so his car is parked for weeks and they ate 4 injector harness wires and 2 vacuum hoses and poop everywhere
  24. Dec 31, 2020 at 9:45 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Wow old thread but i had this issue. Dryer sheets in the fuse box and spraying the bay with peppermint oil did the trick.
    TheBeast likes this.
  25. Dec 31, 2020 at 10:06 AM
    IBeam
    IBeam New Member
    Southeast Texas
    2021 SR5 CM 4x4 Trail Edition, bed-mounted M2
    txcoastie,
    It appears you might potentially be near Houston. If so, go by Solutions Pest Supply. They supply commercial pest controllers and will sell you some good stuff and free advice. I not, perhaps a similar supplier. I have had good results with this:
    https://www.solutionsstores.com/eratication-rodent-bait
    (I actually place against the house under the rood eaves and out of he rain, they last quite a while -- and they kill quickly
  26. Dec 31, 2020 at 10:50 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I'm glad that one of my cats will catch everything in the yard. Mice, moles, birds, even a snake once.
