Rat Attack
Discussion in 'Electrical' started by glennbama, Aug 20, 2021.
  1. Aug 20, 2021 at 7:37 AM
    glennbama
    glennbama [OP] New Member
    Glenn
    Got into 2015 Tundra yesterday and could not shift out of park. Used bypass button to get out of park and took to dealership for diagnosis. Tech took pic of where a rat had chewed through a wire and nearly chewed through others. I came home and could not find those wires after an hour of looking. Can anyone give me a clue as to where I might find those wires from the attached pic?? Want to see3 if it's possible to repair myself. Tech told me they would solder the wires back together and then he told me the "standard charge" is $850.00. If I find the wires and cannot do it myself, IO will look around for a better price.
    Thanks in advance!!
  2. Aug 20, 2021 at 7:51 AM
    AZTundra
    Paul
    Phoenix, AZ
    Engine bay next to the airbox?
    I'd have to assume $850 is to replace the harness. Soldering the wires wouldn't take much time at all.
    avssuc and YardBird like this.
  3. Aug 20, 2021 at 7:56 AM
    glennbama
    Glenn
    Is that under the hood or inside under the dash or console. The charge is to solder the wires and THAT"S it! They said I was lucky because to replace the harness would be $5000. $2900 for the harness and the rest in labor!!! I really appreciate your prompt response!!
  4. Aug 20, 2021 at 9:06 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Looks like the bottom half of the fuse box to me. Painted metal, wiring harness, etc.
  5. Aug 20, 2021 at 9:13 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    I'd solder them for half that price...screaming deal! ;)
    Geez, it's solder, not gold.
    If that affects the Shift Lock, I wonder if it could be under the center console.
    FrenchToasty likes this.
  6. Aug 20, 2021 at 9:25 AM
    daveS67
    daveS67 New Member
    Yeah, damn rats, mice and squirrels love to nest and sleep under the hood!...both in significantly cold and hot weather.
    Good luck with the repair. I would definitely try doing it yourself if you figure out the wire routing.
    Once you get it repaired. try an electronic pest repelller for cars. I have one in each car...some are better than others. They emit an ultrasonic pulse that the pests don't want to be near. Some also have strobe lights to annoy them.
    You can also use peppermint oil inside the engine bay...they hate the smell of that. I also took some strong smelling Irish Spring soap, shredded it up like shredded cheese, put it in plastic bowls and placed the bowls in the engine compartment overnight....they hate the smell of that too. A simple, quick trick is to simply leave the hood open. The rodents are looking for shelter and the hood keeps the heat in in the winter, keeps the cool shade out in the summer. They nest in there too so crack the hood once a week and check for nests.
    avssuc likes this.
  7. Aug 20, 2021 at 9:26 AM
    NoRcptn
    NorCal
    2017 Platinum
    Ohh good call of another place to check.
  8. Aug 20, 2021 at 9:27 AM
    AZTundra
    Paul
    Phoenix, AZ
    I poked around in my engine bay, but didn't see anything that matched up to the picture.
  9. Aug 20, 2021 at 1:07 PM
    NoRcptn
    NorCal
    2017 Platinum
    There was someone else n here that had all the wiring diagrams. Long shot but I wonder if you could detail it out from a wiring schematic. I’ll dig around…
  10. Aug 20, 2021 at 1:08 PM
    NoRcptn
    NorCal
    2017 Platinum
  11. Aug 21, 2021 at 6:00 PM
    glennbama
    Glenn
    I appreciate all your input and the gentlemen who said under the console get the chicken dinner. It was just in front of the shift lever. Anyway, I found a mechanic to do it for $$200 so Toyota can shove it!!
    BTW, thanks for the recommendations for keeping them out with scents and soap. I flooded the garage with rat poison and parked the truck outside the last couple days. The mechanic also put a baar of dove (in the box) in the console area near the wires. He said he's had a lot of success with that. I will try the peppermint oil under the hood as well.
    Thanks to you all for responding........you are all GREAT!!
  12. Aug 21, 2021 at 6:07 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    boostedtrdpro and AZTundra like this.
  13. Aug 21, 2021 at 6:50 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Put the peppermint oil in a spray bottle with water and a little dish soap for an emulsifier. Doesn’t take a whole lot of oil. Then you can spray it wherever you want. Has worked well for me.
    TILLY likes this.
  14. Aug 21, 2021 at 6:58 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Can you elaborate on the proportions you use? Oil/water/soap.
  15. Aug 21, 2021 at 7:03 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Yeah so… probably a tablespoon of peppermint oil as well as dish soap and then fill a decent size spray bottle with water. If you can smell it,it’s strong enough. If you spray in the engine bay and your eyes burn when you drive, add more water. :rofl::hattip:
    TOYOTARIG, Wynnded and TILLY[QUOTED] like this.
  16. Aug 21, 2021 at 7:09 PM
    TILLY
    Massachusetts
    Thanks. :thumbsup:
    Barrett50[QUOTED] likes this.
  17. Dec 23, 2021 at 10:08 AM
    Tzvia
    Tzvia Just an old woman in a pickup truck.
    Los Angeles County
    2019 5.7L Limited TRD Off Road 4x4
    Just a Bed Rug and Snugtop XTRA Vision
    AAAAAAGGGGGGG...... I make an appointment on monday with the dealer for service today, and as I was doing errands before taking it in, all of the sudden, a heavy noise/vibration when I turned on the heater. Then noise like pieces of something being spit out, like stones being flung by the tires.... the steering wheel vibrating with the deep low buzzhum. WTF? I turn off the climate control and the noise goes away. So I mention it to the service dept as I dropped it off this morning- I am thinking the blower or fan blades maybe self destructed. Turns out that rats had made their home in my engine, ate through the filters and filled the area with bedding/food. That dropped into the intake of the blower, making the vibration. They also damaged some wires so the wiring harness needs to be replaced, the blower motor removed and cleaned out, the filters replaced. To top that off, they found a live rat in the engine compartment that they had to get out. It was bad enough they ate the garden I was trying to grow last spring/summer. So now I sit at home waiting for them to finish. So I asked the service guy "what do I use to keep them away?" and he suggested getting a bar of Irish Spring soap and zip tying it to something in the engine compartment. So it looks like I will be stopping by the market on the way home today after picking up my truck, to buy a few bars... One for my old Prius which always seems to have acorns under the hood... and one for the Tundra. And to top it off, the city plants an Oak tree in front of my house. Nice. Food for rats that is... food for rats. Perfect.
  18. Dec 23, 2021 at 10:36 AM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    Curious to know where you end up placing the soap. I may try the peppermint oil recipe above as well. I have a place in the woods and rodents eating wires is a concern and I need to be more vigilant
  19. Dec 23, 2021 at 10:44 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Yep, the little bastards got me a couple weeks ago for $600. They chewed too close to the plug so we couldn’t solder and had to replace a harness. I’ve since washed out my engine bay and sprayed everything down with peppermint oil, along with a few snap traps in my garage.
  20. Dec 23, 2021 at 11:13 AM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    We have desert pack rats around here along with regular rats and they say to use bars of Irish Spring soap.
  21. Dec 23, 2021 at 11:33 AM
    foulcan
    foulcan New Member
  22. Dec 23, 2021 at 4:18 PM
    Tzvia
    Los Angeles County
    I have been reading around the internet (who isn't) that peppermint oil and pine sol work, so will mix up a bottle of the two with water, and spray down the engine compartment. First to scrub and clean up any piss and rinse it all down, then again and just let it dry on there. If that doesn't work, then I am off to the Green Thumb nursery to see if a 'coyote scent' repellent could possibly work. I also read that you can leave out some chopped up onion. They eat it then die. Don't know how true it is but as this has been the worst year for the rodents I have ever seen here (been at this house since '87) I will try anything. Someone at work mentioned that he lives near a grade school, and when lockdown hit, the rats lost their food supply at the school (gross) and hit the neighborhood because they were starving. Well, I live around the corner from two grade schools...
  23. Dec 23, 2021 at 5:16 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    In center console area could be spilled drinks/food that draws them there in the first place, though I know they like to go Everywhere too. But to chew so much on something, there is a Reason, food. Get rid of the food (crumbs even) and they won't be around. Luck.
  24. Dec 23, 2021 at 5:19 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    True. But another major aspect of the problem is that Toyota uses a soy based wiring insulation that the critters like.
    2mchfun likes this.
  25. Dec 24, 2021 at 4:58 PM
    Tzvia
    Los Angeles County
    Yea, I don't keep food in the truck unless I am going camping and the food is in a cooler. So I ended up getting a spray bottle with water, a little pine sol, 7 drops of rosemary oil, 7 drops of peppermint oil- sprayed around the engine compartment, on the wiring and plastic parts. Will have to check it every few weeks, clean the area and reapply. PITA. I park right next to some thick ivy, and noticed some evidence of small animals digging into it around the edges- small piles of dirt. So I am going to cut up some onion and sprinkle it around there. Sprayed the pine sol concoction already around the edges. My prius has the same problem but the starter battery is dead so I got one of those smart chargers for AGMs and and charging it first. Once I get it running (it's my mother's 05 that she hasn't driven in almost 2 years, and I drove it as much as I could but the battery died even though it's only 8mo old), I am gonna clean it up and spray the same stuff on it and cross my fingers. She can't drive any more, macular degeneration... I need it to take her to the store and Dr visits- she has trouble getting in the tundra. Sucks getting old. I will post back if there is any improvement from using that mixture. With the covid lockdowns and working partly from home now, I don't drive much so the rats are just having a field day. Truck is 3 years old and only has 18,000 miles on it. Normally I would put about 13,000 to 15,000 a year on it.
  26. Dec 25, 2021 at 5:55 AM
    WVI
    WVI New Member
    @008 Tundra Limited
    Many folks who RV full time, say that lights under the hood at night keeps the pesky critters at bay.
  27. Dec 29, 2021 at 8:28 PM
    Tzvia
    Los Angeles County
    Good Grief... Prius wouldn't start. Jumped it, took it to Toyota. Rats had eaten the wiring in the engine area that goes to the starter battery. Plus the battery was bad. So I get it home and spray it down with my concoction. I've already had the house gone over and rats removed from under the house and got it all plugged up, and they just moved to my cars. That concoction I sprayed had better work, this is getting really expensive.
    The bigger question is, what was Toyota thinking, using food based products for the wiring...
    And what was I thinking, buying a house in the Santa Monica hills, just off of a conservancy. This is Los Angeles county, the only 'wildlife' here is rats, rancid rabbits, and mangy coyotes.
