Raptor lights help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Kufdog, Jul 1, 2020.
  1. Jul 1, 2020 at 6:10 PM
    Kufdog
    Kufdog [OP] New Member
    2014 Platinum Crewmax
    Hi looking at where I can connect the wires to the raptor lights on the grille. If somebody has a detailed description of how they wired them up that would be great. Either wiring them up when the headlights go on or having them on with my running lights
    Thanks!
  2. Jul 1, 2020 at 6:14 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    I used a fuse tap and tapped into the IGN fuse under the hood. I wanted them on with my ignition.
    rons23 and TXTundra2722 like this.
  3. Jul 1, 2020 at 6:16 PM
    Kufdog
    Thanks, did you run with the same size fuse or did you add bigger one
    BamaMan44[QUOTED] likes this.
  4. Jul 1, 2020 at 6:18 PM
    BamaMan44
    Andre
    Tucson
    Shit, I'd have to go look at it. I also ended up running my LED TRD Pro headlight DRLs into the same circuit, so I probably went up in size.
  5. Jul 1, 2020 at 6:22 PM
    TXTundra2722
    2015 Black Tundra
    I tapped mine into my running lights
  6. Jul 1, 2020 at 6:38 PM
    BamaMan44
    Andre
    Tucson
    I don't remember what was in there before but the tap has 2 10s in it. This tap came with the headlight conversion harness.
  7. Jul 2, 2020 at 1:28 PM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Fuse tap to whichever fuse you want. I wanted mine on as soon as truck is on so I used IGN, I also wired in a switch so I can turn off when I want while the truck is on
  8. Jul 2, 2020 at 4:22 PM
    Kufdog
    What kind of fuse tap is that?
  9. Jul 2, 2020 at 4:26 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 2500 Duramax - 2017 4runner SR5p Trailpig - 2015 Prius V
    You could almost certainly get away with a 2.5a or 5a fuse. |
    That said, if you want "cRaptor" lights, get a cRaptor. Just my opinion, of course!
  10. Jul 2, 2020 at 5:05 PM
    BamaMan44
    Andre
    Tucson
