Random smell from vents
Discussion in 'General Tundra Discussion' started by MrWrench, Dec 30, 2018.
  1. Dec 30, 2018 at 1:42 PM
    MrWrench
    MrWrench [OP] New Member
    2017 White Tundra limited
    Spray on bed liner, Bak mx4
    When using my heat, I get a random smell from the vents. It almost smells like a solvent used for cleaning. Anyone know some good cleaners to try to get the smell out. I’m hoping this will clear out the smell. I changed the cabin filter recently. I change it every November. Only way I ever fixed this was to replace the evaporator but usually they are covered in mold when it gets that bad.
  2. Dec 30, 2018 at 2:35 PM
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
    Try putting dryer sheets with febreze in with the cabin filter
    OR18TRD and Blueknights75 like this.
  3. Dec 30, 2018 at 2:41 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    So many jokes...so little time..
    OR18TRD likes this.
  4. Dec 30, 2018 at 2:43 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Maybe try another cabin filter, could be something in the one you recently installed.
    You could look into renting an ozone generator and leave it in overnight if you really can't solve the issue.
    OR18TRD likes this.
  5. Dec 30, 2018 at 2:44 PM
    Chase1
    Chase1 New Member
    Jeff
    2019 Tundra TSS
    Yes, farting being the first of many.
    Is it possible it is exhaust smell? I see yours is a 2017, so that should rule out new gasket and catalytic converter fumes.
  6. Dec 30, 2018 at 3:54 PM
    War Machine
    War Machine SSEM # 5 3MW
    Pudge likes this.
  7. Dec 30, 2018 at 4:20 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    This works great. Goes everywhere, even through your filter. The New Car smells best, I think.
    Previous owner of my truck had dogs. Noticed it as soon as I got in for the first time.
    One of these made it all go away.
    War Machine[QUOTED] likes this.
  8. Dec 30, 2018 at 5:58 PM
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    They make a foam spray deodorizer for a/c vents. Comes in a kit with a small hose you run down through the vent and it expands. Helps kill any lingering mold that creates the odor.
  9. Dec 30, 2018 at 6:06 PM
    JoeCoastie
    JoeCoastie New Member
    Joe
    Hammond, OR
    2015 White Crew Max SR5
    I’ve had good luck with the vent spray in my wife’s Honda Element when we lived in Hawaii.
    I used three Chlorine bombs to get the ashtray smell out of my Tundra when I bought it. I ran the A/C for at least an hour each time to circulate the gas through the system. Good luck!
