Ramps, jackstands, or…….?
Discussion in '3rd Gen Tundras (2022+)' started by Oldandfat, Nov 19, 2023.
  1. Apr 18, 2024 at 6:11 PM
    #61
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Are there coupons right now for the 12 ton jack stands? I gotta check it out
  2. Apr 19, 2024 at 10:24 AM
    #62
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Speaking of jacks, I just did a rotation on my truck a few days ago. I found it odd the manual recommends jacking the front tires up from the frame just rear of the trans crossmember. It worked, but it sure seems to be too far rearward. You end up jacking up the whole side of the truck, instead of just the corner you're working on. My 3.5 ton floor jack barely had enough travel to get the front tires in the air. That was with 33" tires and no lift.
    Also, I haven't used the factory jack, yet, but it doesn't appear tall enough to jack the front tires up from the recommended jacking points. It might be worth checking out before you have to rely on it on the side of the road. I'm going to throw a few 4"x4" blocks in my truck just in case.
    Leo's first and Mattedfred like this.
  3. Apr 19, 2024 at 6:39 PM
    #63
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    Looks like this is the ticket then:
    7000TLX Extended Portable Car Lift - QuickJack Store
    Since I already have the 5000TLX, I asked if I could just get the frames and use my existing pump to run them. Answer is yes. That means it's a bit less expensive to just order the frames:
    "7000TLX. I do have the Frames available for sale @ $1180.00 for the set. "
    I also already have the "Truck Adapter Kit" so it looks like this is the direction I need to go. I really like the Quick Jack and feel it's much better than jack and stands.
