Ramps, jackstands, or…….?
Discussion in '3rd Gen Tundras (2022+)' started by Oldandfat, Nov 19, 2023.
  1. Jan 8, 2024 at 9:33 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    :confused: What last stand?
  2. Jan 8, 2024 at 9:34 PM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Go with the Rhinos. I’ve got them and love them. They don’t slip when you’re driving up onto them. Plus, you can often find them for the same price ($59.99) and they’re double the weight capacity of the HF ramps.
  3. Jan 8, 2024 at 9:38 PM
    KroppDuster
    Bilstein 5100s
    Their cheaper jack stands had a safety issue where the pawl would lose grip and allow the jack stand to drop without warning. There was a big recall on all of their cheap 3-ton and some of the 6-ton units. They swapped them out for free if you brought them into the store. The new units are quite beefy though. I use their 12-ton stands.
  4. Jan 8, 2024 at 10:06 PM
    TacomaTRD4x402
    Southern California
    You sold me. Purchased! :thumbsup: thanks
    KroppDuster[QUOTED] likes this.
  5. Jan 8, 2024 at 10:23 PM
    KroppDuster
    Bilstein 5100s
    Had mine for over 5 years now. You’ll be happy you got them.
  6. Jan 9, 2024 at 4:10 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    I have a couple of floor jacks and some jack stands, but for oil changes and messing with the cat shield and skid I just use my old set of Rhino Ramps. They aren't the newer heavier duty model but still work fine. It's crazy that these Tundras have less room to work underneath than my old gen 2 Tacoma. I didn't need to raise it at all to do this kind of work. I probably could do the Tundra oil change without lifting except for needing to remove the front TRD skid plate. If you don't have one of those you can probably do oil without ramps.
  7. Jan 9, 2024 at 4:21 AM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    This. I went to HF to replace my older HF ramps (Tundra over weight capacity) and didn't like my options. Home Depot was right there and the Rhino's were on sale. They are very nice and I recommend them.
    TacomaTRD4x402 likes this.
  8. Jan 9, 2024 at 4:56 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    Years ago I had a Contour SVT and it sat pretty low, didn't like pulling the jack and stands out for an oil change so I used some 2x10 I had and made some ramps, I cut 4 pieces for each side with a 45° leading edge. Bottom was about 3ft, middle was 2ft, top was 1ft and a backer about 6in long and screwed them all together. They worked great and fit under the body. Best part is it was free because I had everything I needed. That car has been gone for a long time but I still use those ramps for quick jobs.
  9. Jan 9, 2024 at 4:58 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    I have those. I love 'em. Never had Rhino ramps though, so I can't make a comparison.
  10. Jan 9, 2024 at 5:06 AM
    Gene_in_FL
    FLORIDA
    They had a recall on three models of their "Pittsburgh" brand jack stands, manufactured between 2013 and 2019. I'm pretty sure I own a set of the recalled stands. LOL
  11. Jan 9, 2024 at 5:36 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    I have that same set up drain pan, HD bucket, HF ramps my creeper is a little older
    The 5 gal bucket makes this job so much easier and cleaner got the tip off here
    Gene_in_FL[QUOTED] likes this.
  12. Jan 9, 2024 at 5:56 AM
    TacomaTRD4x402
    Southern California
    Thanks guys. I think I'll definitely be happy with my rhinos. Couldn't find them in sale anywhere nearby so just ended up ordering them through Lowe's. Pick up on Friday. Got my aftermarket eBay skid waiting for the install. Got all the hardware on it, just now waiting for the rhinos. Plus future oil changes looks like it'll be a breeze. I'm the back of my head, I've always been a bit skeptical about them breaking while under the truck(I'm kinda a big guy) so while the thought of being thinner is nice, I'd rather go about it a different way :rofl:
    Thanks again for the recommendation :thumbsup:
    Leo's first and Mattedfred like this.
  13. Apr 16, 2024 at 12:33 PM
    Gaston
    Gaston New Member
    Gary
    SE MI
    I use 6ton up front under the frame and 3ton in the rear under the axle. If I needed the rear suspension to droop, I'd use 6ton under the frame. I feel more comfortable with the 6ton for taller support.
    Leo's first likes this.
  14. Apr 16, 2024 at 12:37 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    I've used Rhino ramps for every oil change on my 2018 (9 times so far). For me personally, these are the only way to go, no need to find jacking points and slide axle stands into position and lower on to them.
    With the ramps, slide them up to the tire, line them up and carefully run up the ramps until the front tires settle in to the recess. Put in Park, set the parking brake and you are totally safe.
    Also, being reinforced plastic, they are light in weight and easy to move around. I got the heaviest model (supposed to support way more than the front of the Tundra weighs).
  15. Apr 16, 2024 at 1:02 PM
    Leo's first
    Groton ma
    Probably not but for a few more dollars I’d go with the 6 then you have them if needed to do repairs under the truck
    I hate all jack stands especially putting these beasts on them
    Gaston and Mattedfred[QUOTED] like this.
  16. Apr 16, 2024 at 1:14 PM
    DRP
    DRP Old Member
    Dave
    I also go to 4 low going up the ramps. Way easier to control the forward movement. :thumbsup:
    Mattedfred[QUOTED] likes this.
  17. Apr 16, 2024 at 2:41 PM
    Leo's first
    Groton ma
    No jack stands are safer just for the fact they have wider base
  18. Apr 17, 2024 at 1:33 PM
    Tom976
    Tom976 New Member
    Tom
    Little light on the capacity side....
  19. Apr 17, 2024 at 1:46 PM
    #49
    Leo's first
    Groton ma
    Those are great same price as the Rhinos
    :confused: They have more capacity then the Rhinos
  20. Apr 17, 2024 at 4:23 PM
    #50
    TacomaTRD4x402
    Southern California
    I ended up getting the Rhino's. Used them a few times already but I still use my Badlands jack and 3 ton jacks as extra safety. They are great ramps but I'm going to be building my own ramps out of wood and will sell or giveaway my Rhino's.
  21. Apr 17, 2024 at 7:58 PM
    #51
    MrKABC
    MrKABC Not so new Member
    Art
    Corona, CA
    2023 Mesquite 1794 TRD OR Hybrid
    Miller Cat Shield, Sumo Springs Blue, Diode Dynamics Stage Series hidden light bar.
    I have Quick Jack 5000 series which are unfortunately not robust enough for the Tundra's weight. Worked great for my Taco when I had it.
    Anyone use the 7000 series? Thinking of upgrading.
  22. Apr 18, 2024 at 5:21 AM
    #52
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    I use the 7000TLX on my F30 335i, F25 X3 35i, and 2008 Legacy GT. I purchased the 7000TLX so it could handle the weight of a full size SUV or 1/2 ton pickup when we eventually purchase one.
    The frames for the 7000TLX are heavy. The only inconvenient part is setting it up and putting it away. But if you have a project where you think you might need to work on the car at different heights to access stuff, it's much better than jack stands. It's also much better if you're working on more than 1 car during the day because you can quickly lift and lower each vehicle. Since getting them, I haven't gone back to jack stands.
  23. Apr 18, 2024 at 5:29 AM
    #53
    Polo08816
    2014 BMW 335i
    Do you have the 7000TLX?
    I can see the advantage of using them being lessened on a pickup compared to a car/smaller SUV because the underside has more jack points/is more exposed.
  24. Apr 18, 2024 at 12:49 PM
    #54
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  25. Apr 18, 2024 at 1:30 PM
    #55
    ksj0823
    ksj0823 New Member
    2024 Tundra Platinum 6.5 MGM HV
    kirkb, des2mtn, Mattedfred and 3 others like this.
  26. Apr 18, 2024 at 1:47 PM
    #56
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I have a Torin 3 ton “offroad” jack that’s tall enough to get the truck off the ground, and then 6 ton stands.
  27. Apr 18, 2024 at 2:00 PM
    #57
    Bergmen
    Bergmen New Member
    Ukiah, California
    Good job, those look really great! Plenty strong as well.
  28. Apr 18, 2024 at 2:15 PM
    #58
    TacomaTRD4x402
    Southern California
    That's awesome! That's what I'm planning on doing too. Found a really good video of the perfect ramps I want to build. My brothers really good at woodworking out in Texas so we're gonna build em when I head out there next month.
    Mattedfred and Leo's first like this.
  29. Apr 18, 2024 at 3:47 PM
    #59
    sno1
    sno1 In search of quality
    I made some ramps out of 2x4's in a time of need about 15 years ago and they worked so well I still use them
    These combination bottle jack/jack stands are handy for rotating wheels
    kirkb, TacomaTRD4x402 and Leo's first like this.
  30. Apr 18, 2024 at 6:00 PM
    #60
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Need a jack. Should I snag this or spend a bit more like the other pic?
