Ramps for multiple vehicles
Discussion in 'General Tundra Discussion' started by RollTide82, Nov 3, 2019.
  1. Nov 3, 2019 at 8:03 AM
    RollTide82
    RollTide82 [OP] New Member
    Michael
    2019 Tundra 4x4
    Looking to purchase some ramps for a few of my vehicles to do oil changes and such. I am just kinda scared of the plastic rhino brand. Anything under 200 bucks would.be fine. Any input on these?
    Rustedfenders and Mountun Goat like this.
  2. Nov 3, 2019 at 8:14 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Nothing cheaper than a set of home made wooden ones. They’re nice and heaven too so unlikely to slide around as much.
  3. Nov 3, 2019 at 8:50 AM
    FXFormat
    FXFormat New Member
    I can easily do my oil changes without a ramp, are you a heavy set fella with a big gut? Then you might need a ramp, or just lift the truck using the would be ramp money.
    chugs likes this.
  4. Nov 3, 2019 at 9:17 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've had a set of Rhino Ramps for about 20 years, I know they've changed but there are the older versions on FB marketplace for under $50.
  5. Nov 3, 2019 at 9:18 AM
    RollTide82
    Michael
    2019 Tundra 4x4
    I weigh like 175 so no gut...lol mostly for my Avalon and my dad's cars. I can fit under the tundra and tacoma. Just thought they would be of help sometime
    15whtrd likes this.
  6. Nov 3, 2019 at 9:19 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Left tires on top of a curb, rights in the street. Drop oil into gutter. Easy peezy.
  7. Nov 3, 2019 at 2:54 PM
    FXFormat
    FXFormat New Member
    I dated a chick that weighed 175lbs, but she was also 5'0, so huge gut.
    plumber802, Black Wolf and Hondoman like this.
  8. Nov 3, 2019 at 3:35 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Pix or it didnt happen.
    mech_engineer09, chugs and Hbjeff like this.
  9. Nov 3, 2019 at 4:07 PM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    20191103_185835.jpg I bought the Rino Ramps years ago and modified to look like this. 2x6's and 2x8's and screws and washers. Made these for multiple vehicles even lower ones. Even makes the vehicle higher.
    TundraXPLover likes this.
  10. Nov 3, 2019 at 4:32 PM
    TundraXPLover
    TundraXPLover New Member
    Clif
    NC
    2018 CM 4x4 XP
    Love my Rhino's. Go for it!
  11. Nov 3, 2019 at 5:00 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have had a set of Rhinos for 10+years. I have not used them on the Tundra. (But I'm certain they would be fine) I can get under it for oil changes and if I need to go higher I use jack stands.
  12. Nov 3, 2019 at 5:10 PM
  13. Jan 19, 2020 at 2:13 PM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    This isn't that old, but did a Forum search and found this. When the Tundra arrives in Feb, I was looking for a set of ramps. I also wanted to use them for me Corolla XRS that is low to the ground and has spoilers.
    I saw a few, but the pricing on some is so high, I will stick with jacking the car up and putting it on jack stands. Right now Rustedfenders seems to have the best idea for getting and long easy slant.
    Anyone find anything or have a recommendation??
    Rustedfenders likes this.
  14. Jan 19, 2020 at 2:24 PM
    RollTide82
    Michael
    2019 Tundra 4x4
    I never bought any...I'll just squeeze under for oil changes...I do jack the avalon up and put a few jack stands underneath
  15. Jan 19, 2020 at 3:08 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I have a set of long metal tailgate ramps that will tri fold into vehicle ramps. Usually use them to pick up curb snow blowers and lawn mowers.
  16. Jan 19, 2020 at 3:15 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’ve got the plastic rhino ramps I use for oil changes on a camry and a mazda 3. Don’t need them for truck. They work great, and they stack so they don’t take up too much space.
  17. Jan 19, 2020 at 3:16 PM
    Captainjohn
    Captainjohn New Member
    2019 Tundra Dbl cab
    Rock sliders, topper, sliding bed
    I have used the Rhino ramps several times. They sell several different weight classes, just makes sure their rated to cover the weight posted in drivers door jamb.
    Not a bad idea to always use some jack stands or blocking for back up plan.
  18. Jan 19, 2020 at 4:48 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    All ramps won't work for all cars, so check them carefully. On some low cars, the front spoilers will get into the ramps before the wheel starts up the ramp. For that car, the ramp "approach angle" is too steep, and the ramp too short, to achieve the design lift in the ramp length. For that reason, most ramps' lift is limited to about 6". Length is the Achilles heel of ramps; the shorter the length to reduce cost, the steeper the approach angle.
    Once you have ramps, you have to store them. There is plenty of clearance under the Tundra, but I've looked at them for my wife's Honda Insight (@#$*!+% engine cover!). It's about 5" off the ground, so there ain't no way I'm fitting under there. At the first oil change, I used about six stacked 2" X 8" scrap lumber pieces each side with lengths to create a ramp. Worked great, and the scrap lumber I'm already storing.
  19. Jan 20, 2020 at 3:54 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    I did find one set of ramps that would manage all, race ramps. They sell the ramps and extenders (https://www.raceramps.com/garage-service/ramps/xtenders/p/xtenders/).
    But the cost is just more than I will spend. For my race car, I'll just use the jack and jackstand method.
    I might consider a set if I can also get my Corolla XRS under and my wife's new Civic.
