Ram bringing back 5.7 hemi
Discussion in 'General Automotive' started by ansel123, Mar 24, 2025.
  1. Mar 25, 2025 at 9:54 AM
    #61
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Are you saying that dropping 2 cylinders off an engine stops all chemical contamination ?
  2. Mar 25, 2025 at 10:00 AM
    #62
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Pondering this
    towing 5000lbs
    Does a v6 or a v8 tundra contaminant more children?
    if you look at the comparative mileage, it would appear they are VERY similar
    cruising at 65mph. Unloaded
    which one contaminates more?
    My point. It’s insignificant
    yet, I can’t get another v8 tundra
    If, God forbid, something happens to my v8 tundra….i will replace it with another v8 half ton
    v10 is possible
    Godspeed Ram. Bring on the displacement
    WNY PAT likes this.
  3. Mar 25, 2025 at 10:00 AM
    #63
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Not until your fit it into a truck that is bigger than HD truck of past, and hand it over to soccer mom for soccer mom's daily chores. Then it is all good and EPA-approved.
    Cpl_Punishment likes this.
  4. Mar 25, 2025 at 10:02 AM
    #64
    nobodyintexas
    nobodyintexas What?
    South of Houston
    the excursion
    diesel bliss
    centex and WNY PAT like this.
  5. Mar 25, 2025 at 11:20 AM
    #65
    ansel123
    ansel123 [OP] New Member
    Sr5 2024
    Several
    no im saying getting rid of the epa and allowing multinational companies to do whatever the hell they want does.
  6. Mar 25, 2025 at 11:52 AM
    #66
    18" TRD Off Road Wheels
    Right. Because the only option is a complete and extreme reversal to shove the pendulum to the other far extreme. That's exactly what people who don't like the way the EPA, CAFE, and other alphabet agencies are run are advocating. For sure. Totally. :rolleyes:
  7. Mar 25, 2025 at 12:00 PM
    #67
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I must admit, I ran over a bunch of chipmunks and squirrels, one duckling and hit two birds to death in my old school V8 truck. It is basically scything the environment each time I drive it. I blame it on the V8. Unfortunately not any deer yet, so no venison for the table.
    Lovetrucks and Cpl_Punishment like this.
  8. Mar 25, 2025 at 12:06 PM
    #68
    enve46
    enve46 New Member
    Andrew
    Whats interesting that I rarely see ever get mentioned in these debates is the amount of oil most of these modern engines burn. Your average run of the mill commuter vehicle burns oil on regular use due to the oil manufacturers are using as well as the tighter ring packs to get the slightest bit more economy out of it by less drag. No one can tell me that this doesn't create more problems than the stricter emission standards fix.
    Coming from diesels, the DEF in plastic jugs that get tossed in the trash, also makes zero sense. They created the need for DEF cause of the EGR which then created a need for a DPF which then... etc etc etc... This is my beef with EPA regulations. They're not fixes, they're bandaids that create MORE problems than they solve and pad the pockets of companies that give two shits about creating cleaner environments. Add that to my deleted diesel getting significantly better fuel economy, oil stays cleaner cause its not full of soot and can actually run great OCIs and so on. The EPA has a great concept but their execution is shit, like most government agencies.
  9. Mar 25, 2025 at 12:34 PM
    #69
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 2016 Platinum Sequoia, 2003 Tacoma SR5 V6 5Spd
    All great points, and to add to that, another thing not mentioned is what is the EPA's goal? They have shifted that goal post continuously. Initially the EPA cut down on N03, carbon monoxide, and other tailpipe pollutants that contributed to smog over metropolitan areas. That was worthwhile and a rare example of a government agency succeeding at something.
    They then shifted their focus to reducing carbon dioxide emissions (eventually aiming for net zero), a totally impossible goal, that ensures job security for their entire agency.
  10. Mar 25, 2025 at 8:41 PM
    #70
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Chevy was supposed to put the 6.2 in an RST but I don't think they ever did.
    nobodyintexas[QUOTED] likes this.
  11. Mar 25, 2025 at 8:44 PM
    #71
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I don't suppose anyone bothered to tell them that burning ethanol in gasoline increases smog.
    Red&03Taco[QUOTED] likes this.
  12. Mar 26, 2025 at 3:09 AM
    #72
    nobodyintexas
    nobodyintexas What?
    South of Houston
    we have 2 6.2l's that have dropped the lifters. Denali pickup...Denali Tahoe.
    the remedy:
  13. Mar 26, 2025 at 4:52 AM
    #73
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    That answer has more to do with market share goals than capitulation to regulatory standards.
    What’s crazy to me is how Toyota sells more highly efficient commuter cars than all the domestics combined—more than enough to offset the inefficient, last-forever drivetrains of their trucks and BOF SUVs.
    But think of all the Toyota vehicles the 3UR went into—Tundra, Sequoia, Land Cruiser, and LX570. Not a single one outperformed in its class compared to domestics, and most full-size domestics either had v8s with cylinder deactivation or twin turbo v6s.
    Maybe Toyota understands that Americans care a lot about improved fuel economy. Seeing over 20mpg at the end of one trip of highway cruising makes people think they’re making significant inroads to efficiency, even if that gap dwindles to only 3mpg over the entire tank of fuel with the same driving style and vehicle mods. Maybe Toyota’s move to turbos, v6s and 4cyls, and hybrids in BOF trucks and SUVs is just as much if not more about capturing market share than crying uncle to the EPA.
    Cpl_Punishment and Lovetrucks like this.
  14. Mar 26, 2025 at 5:02 AM
    #74
    ansel123
    Sr5 2024
    Several
    Good point i purposefully did not buy the old 4 runner or the old tundra because of their miserable mileage.
    Terndrerrr[QUOTED] likes this.
  15. Mar 26, 2025 at 5:15 AM
    #75
    Terndrerrr
    Music City
    6UR-FE
    The opposite viewpoint is that the fuel economy delta in reality is only about 3mpg (aggregated self reporting of real world experiences on Fuelly supports this), and this is well worth the track record of zero hassle ownership over the long term. But if you swap out vehicles a lot, it’s probably not a big deal
  16. Mar 26, 2025 at 5:38 AM
    #76
    ansel123
    Sr5 2024
    Several
    13 mpg epa in the city is a complete joke and a colossal waste of money in gas
  17. Mar 26, 2025 at 5:42 AM
    #77
    centex
    centex New Member
    Gas mileage isn’t as big of a cost factor as the media and government make it out to be. If people actually sat down and did the math, they’d realize 3mpg isn’t the savings they thought.
    At 12k miles a year, the difference between 15mpg and 20mpg assuming $3/gal is only $600 a year in savings. Not exactly worth getting a new car payment or dealing with higher insurance rates or risking longevity or really even worth the hassle.
    Same applies to all this new green energy high efficiency crap appliances. Read through the marketing and do the math and these things don’t save enough to justify the cost of upgrading to them.
  18. Mar 26, 2025 at 5:43 AM
    #78
    centex
    centex New Member
    I will agree these trucks get shit mileage compared to the competition. It’s pretty freaking awful and Toyota could have done better there. But then again I read about plenty of people on this forum getting 17+ so I dunno.
  19. Mar 26, 2025 at 5:49 AM
    #79
    nobodyintexas
    nobodyintexas What?
    South of Houston
    right on.
    at the end of the day...you can't have the shit you want, because you got told you can't.
    and
    it is about mileage or clean air?
    because we are the leaders in both of those aspects.
    or is it climate change? because that line of bullshit is a simple grift.
    and...let me get this straight...a 6500lb vehicle gets bad mileage? welcome to the real world.
    next thing they will say is...there is a vehicle weight limit...because polar bears are dying.
    imagine the pearl-clutching if someone puts a big ole Supercharger on their Tundra.
    Red&03Taco and Terndrerrr like this.
  20. Mar 26, 2025 at 5:50 AM
    #80
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I drive a 13 MPG city car that I've got for $2200 in 2018. It would take a few human life spans to offset fuel savings of a new $50k hybrid car.
    Less exacerbated but still a good example is my $35k Tundra. It is literally gas every month, oil twice a year and rubber every 3-4 years. Nothing breaks. Buying a new Tundra with meager MPG improvement is at least $30k on top of that, and that's a lot of fuel. Not to mention I don't want a new engine. I don't want to visit dealer at all. It is wasting my time and hurting my income, even if it's "free" and "under warranty".
    Do your math.
  21. Mar 26, 2025 at 5:52 AM
    #81
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Wife gets 21+, almost 22 MPG in her V8 Sequoia on highway. Tundra was 16-17 before mods.
    Terndrerrr likes this.
  22. Mar 26, 2025 at 6:01 AM
    #82
    enve46
    enve46 New Member
    Andrew
    Excuse my lack of knowledge here but does the new V6TT require premium fuel? Many new turbo engines don’t require premium but return the best performance and economy with premium, therefore wiping out any savings.
  23. Mar 26, 2025 at 6:05 AM
    #83
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Runs "normally" on 87 gas. Means, it starts with higher pressure and retards once engine starts knocking.
  24. Mar 26, 2025 at 6:05 AM
    #84
    Breathing Borla
    AZ
    no, full power on 87 regular.
    the 479 ft lbs at 2,400 with the 10-speed Aisin behind it is super impressive. I loved my 350 tundras , but this thing does everything with ease.
  25. Mar 26, 2025 at 6:44 AM
    #85
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Assuming there's no magic in this world, how did they do it? I mean, I have a vehicle (god forbid saying its brand here) that has a low pressure 0.5 BAR turbo, yet I see at least 50% boost cutoff on a mildly warm day on 87 vs 93 that I normally put into it. V6TT is HPT, yet it runs "full power" on 87. Perhaps it does not show same numbers when it's fully warmed up, especially on a hot day?
  26. Mar 26, 2025 at 7:08 AM
    #86
    centex
    centex New Member
    Exactly. These people spewing all these cost savings for driving electric like no oil changes or low maintenance are just spinning people up. Yes you may save $200 in a year by not having to do two oil changes but what’s it cost you monthly for that new car payment? People don’t factor in the return on investment. It’s why I’ve never put solar on my house. The cost to install would take me 40yrs to offset the energy savings and my entire house is electric with no gas. And that’s assuming I paid cash for the install and didn’t have to finance it.
  27. Mar 26, 2025 at 7:11 AM
    #87
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Funny you said it, this weekend I turned away solar panel contractors at Lowes as soon as they've heard "ROI" :)
  28. Mar 26, 2025 at 7:16 AM
    #88
    enve46
    enve46 New Member
    Andrew
    Thats kind of my point. There isn't THAT much difference in modern 87 to 93 octane but on a forced induction engine, it makes a significant difference in performance and economy. These modern engine have so many sensors that the slightest change or issue will show. Example... My previous Power Wagon, 6.4 NA. Ran fuel economy test across all octane levels available. 93 returned the best fuel economy, 9.3mpg and saw no timing retard versus 87 which returned 8.8 mpg and saw retard timing a lot. It wasn't enough to feel and the cost of 93 isn't worth it, but we are talking about an NA V8 here. Add boost and everything from that example only gets exacerbated
  29. Mar 26, 2025 at 7:27 AM
    #89
    Terndrerrr
    Music City
    6UR-FE
    If 13-14mpg is a complete joke and a colossal waste, what is 16? Just a partial joke and a regular-sized waste?
    Some of us would just rather not deal with any headaches at all and are happy to pay for 3mpg worse fuel economy. Maybe more of us that we realize. Ram seems to think people will buy their 5.7L v8 if they bring it back.
  30. Mar 26, 2025 at 7:39 AM
    #90
    Red&03Taco
    Red&03Taco YUT
    Jerad
    And compare that to 16-17mpg that 3rd Gen Tundras get, and then tell me how many years down the road is your break even point if it costs let's say ~$20k to upgrade from that "complete joke and colossal waste of money" of a truck.
