Raising rear seats 2017 CrewMax with spacers?
Discussion in '2.5 Gen Tundras (2014-2021)' started by travpayne, Jan 12, 2020.
  1. Jan 12, 2020 at 2:28 PM
    travpayne
    travpayne [OP] New Member
    17 Tundra CrewMax 4x4
    So I’m looking to raise my rear seats (or possibly just one) about 1-2” with spacers and longer seat bolts so I can fit a legit safe underneath.
    *im aware of ESP, but don’t trust their locking mechanism with my very expensive camera gear and these crafty thief’s here in the Bay Area.
    I plan on removing the insulation/foam as well, but I’m still not sure how much total depth I could use and still be able to fold the seat down.
    Does anyone know the distance from the floorboard to seat? Looks like possibly 6-7” max?
    And does anyone know if the floorboard is flat? It almost looks like the floorboard slopes up right around the rear seat bolt after watching a few of the ESP install videos. Hard to measure the depth without making a cut.
    Thanks I’m advance!
  2. Jan 12, 2020 at 2:54 PM
    travpayne
    E41DD179-C277-4FC5-B5CE-492234598139.jpg Kind of a confusing post. But this should help.
    Even knowing the dims of that steel seat mounting post would be very helpful.
  3. Jan 12, 2020 at 2:57 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    Have you looked at installing something in the bed? I’d imagine you can rig something up just as secure with less work
    Pinay likes this.
  4. Jan 12, 2020 at 3:04 PM
    travpayne
    It would be easy to install something in the bed. But I also like the out of sight theory.
    I don’t have a shell on my truck or I would consider it. I plan on using it mostly to store my camera and lenses, so not sure how much I want to depend on the weather sealing of a safe, or if they even make an affordable outdoor safe?
    I also live on the coast, salty air over time wouldn’t be good.
    I’m planning on running a small cable from the rear seat to a mount or even the front seat post to lock the rear seat in the down position.
  5. Jan 12, 2020 at 3:12 PM
    teedubbya
    Austin TX
    Gotcha. A hard cover is a pretty good deterrent and pretty secure but your cab safe would be way cheaper
  6. Jan 12, 2020 at 3:55 PM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
  7. Jan 12, 2020 at 4:16 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Hightide likes this.
  8. Jan 13, 2020 at 10:49 AM
    travpayne
    Shit. Lol. I always thought those would be a bit harder to get into...
    thank you for the videos and info!
    ZappBrannigan[QUOTED] likes this.
  9. Jan 13, 2020 at 11:26 AM
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
  10. Jan 13, 2020 at 6:56 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Yep. The rule is if it is expensive it should never be left in a vehicle.
  11. Jan 14, 2020 at 11:04 AM
    spork3127
    spork3127 New Member
    It's no safe, but applies to the "out of sight, out of mind" theory. I did this in my '17 DC, but I have the built in storage underneath the seat. The largest lens is a 100-400 v.II and it fits without the lid touching. I utilized old foam inserts from previous camera bags for padding where I could and stapled the rubbery drawer/cabinet lining material to the bottom. It's worked out ok so far. My biggest complaint is having to take off/put on lenses whenever needed.
    teedubbya likes this.
