Rago Dash Plate
Discussion in '2.5 Gen Tundras (2014-2021)' started by ProtoJ, Jun 29, 2020.
  1. Jan 11, 2021 at 12:29 AM
    #61
    Zilla18
    Zilla18 New Member
    Scott
    Richmond, TX
    18 SR5 CM TSS Offroad
    Looks Awesome, great job on the install! Glad everything went smoothly for you, hopefully you didn't pull put too much hair! Really like your dash mat!
  2. Jan 11, 2021 at 8:31 AM
    #62
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    Thanks for all the help! Was nervous at first. But just had to take it slow and double check everything. Couple of times I didn't think the dash was going to come apart. Just had to use more power. Definitely took about 3-4 hours. I bought a punch tap for the plates and dash to start the drilling. But I've used that thing to install bed rails. that $10 was worth every penny.
    Zilla18[QUOTED] likes this.
  3. Jan 11, 2021 at 9:30 AM
    #63
    kyle112006
    kyle112006 New Member
    Kyle
    Do you want to sell it lol?
    DjSamthrax likes this.
  4. Jan 12, 2021 at 11:33 AM
    #64
    Rocko9999
    Rocko9999 New Member
    Where did you get your 12v outlet that shows voltage?
  5. Jan 12, 2021 at 11:37 AM
    #65
    Zilla18
    Zilla18 New Member
    Scott
    Richmond, TX
    Amazon, it's the one pictured at the bottom of this thread page. Works well and looks oem.
    2point5seconds likes this.
  6. Jan 12, 2021 at 11:44 AM
    #66
    2point5seconds
    Sensei
    Nor Cal
    Zilla18, I think I asked about the USB chargers before, but are any of those the 'always on' chargers? Does it depend on how they're wired? I know you can piggy back on the lighter. And there's a way to hook straight to the fuse box. Thanks!
  7. Jan 12, 2021 at 11:50 AM
    #67
    Zilla18
    Zilla18 New Member
    Scott
    Richmond, TX
    For the charger with voltmeter, i used existing wiring that turns on with ignition. For the quich charge usb only i wired with an add-a-fuse to fuse box in the cab, also controlled by ignition. There are multiple spots that are unused in the fuse box to accommodate always on or ignition controlled. Hope this helps. If you need a pic I can take one for you.
  8. Jan 12, 2021 at 11:53 AM
    #68
    2point5seconds
    Sensei
    Nor Cal
    No, thank you. I just wanted to verify what I've been reading and researching. Thanks!
  9. Jan 18, 2021 at 12:59 PM
    #69
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  10. Mar 14, 2021 at 2:59 PM
    #70
    Pigglet222
    Pigglet222 New Member
    So... the paper towel trick works like a snap to keep the bolts from falling down into the abyss. Any tips on how to retrieve a pry tool that may have disappeared down behind there?
    Asking for a friend...
    bulldog93 likes this.
  11. Mar 14, 2021 at 3:09 PM
    #71
    Pigglet222
    Can you please share more about how this is done?
    I’m a total noob to wiring and such.
    I’m hoping to keep the factory usb charger behind the stereo and run a usb cable from that up to the Rago on the dash so that my iPhone has audio+charge...
    And then since that one would be hidden behind the dash, I want to also have a 2-port usb like you used in place of the factory one (now hidden) going right to the fuse panel but I need some direction in how to do that, please.
  12. Mar 17, 2021 at 4:29 PM
    #72
    Billy Swamp
    Billy Swamp New Member
    Ben
    Seminole County, FL
    2014 CM Magnetic Platinum 4x4 Tundra
    7" pro-comp, 35" tires, fuel assault rims, Amp Research power steps, JRT system
    Really great info and pics! Trying to decide between the two. I won't ever have anything mounted up there full time. So if every now and again I mount a CB up there how do I get the CB bracket to mount to the either dash plate? Take it apart, mount, and put back together?
  13. Mar 22, 2021 at 6:09 PM
    #73
    pillpusher84
    pillpusher84 New Member
    2024 Silverado High Country
    That looks quite extreme!
  14. Apr 7, 2021 at 7:38 AM
    #74
    Zilla18
    Zilla18 New Member
    Scott
    Richmond, TX
    Sorry for the delayed response. I disconnected the battery and used the existing wiring for the circular 12v input. The seconday port was connected with a add a fuse into the panel by the parking brake. I connected to aslot that is controlled by the accessory position of the ignition. You can connect to a slot that would always be on, but you run the risk of draining your battery. If you go this route let me know, i'll post a pic of the fuse panel.
  15. Apr 13, 2021 at 11:23 AM
    #75
    Lost in the East
    Lost in the East New Member
    Derek
    Voodoo Blue TRD Pro (Should’ve kept it) Mudbath TRD Pro
    It's definitely worth it!! I love mine.
    Wallygator likes this.
  16. Apr 14, 2021 at 10:37 AM
    #76
    Tundraofnv
    Tundraofnv New Member
    2020 Cement Crew
  17. Jun 1, 2021 at 9:14 PM
    #77
    t-rey1
    t-rey1 New Member
    What size tablet is that?
  18. Jun 5, 2021 at 10:15 PM
    #78
    Zilla18
    Zilla18 New Member
    Scott
    Richmond, TX
    Samsung A7 tablet. Think it is a 10in. Screen
  19. Aug 8, 2021 at 4:31 PM
    #79
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Major props to @TSands83 for the parts list. Did mine slightly different but essentially the same. Rock solid. Only problem I ran into was one of the new holes being too close to the edge of the ICS plate. Wound up drilling through it but it still holds just fine. Would be much easier if Rago offered their own backing plate.
    6992AAA6-0C30-421F-8DE6-428D412D603C.jpg CABA6028-B1AB-4D46-BD6C-C42D49A137B9.jpg 0135CE37-E662-4A85-86D8-56DEB256652E.jpg
  20. Sep 14, 2021 at 9:24 AM
    #80
    deepblu89
    deepblu89 New Member
    2018 Barcelona Red Tundra
    Anyone have the new version with the built in USB ports? I received it yesterday but Rago has no instructions for the wiring and I'm new at this.... I contacted them and they said eventually they'll make a video but no idea when.
  21. Sep 14, 2021 at 11:44 AM
    #81
    DuneShoot
    DuneShoot New Member
    West Phoenix
    ‘21 Limited Cement
    I connected mine to the cig lighter wires. Pretty simple.
    deepblu89 likes this.
  22. Sep 14, 2021 at 12:50 PM
    #82
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    What mount is that for the radar?
    BUGEATER likes this.
  23. Sep 14, 2021 at 2:09 PM
    #83
    TRD4x4Liberty
    TRD4x4Liberty Dog hauler
    NYC area
    Heavy Metal Crown - Black TRD PRO Sequoia
    Original.
    Wait till y’all find out about Zacuto arms with Manfrotto phone mounts…
    15mm rods and 1/4 20 threads
  24. Sep 14, 2021 at 3:50 PM
    #84
    AggiePhil
    College Station, TX
    Just Googled the Zacuto arms. Very expensive. What would the benefit be in this application?
  25. Sep 14, 2021 at 4:15 PM
    #85
    TRD4x4Liberty
    NYC area
    Original.
    Build whatever you want with grip gear…
  26. Sep 14, 2021 at 4:21 PM
    #86
    AggiePhil
    College Station, TX
    I don’t get it.
  27. Sep 14, 2021 at 5:02 PM
    #87
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Yeah, the backing plate makes all the difference.
    Fortunately, it’s easy to retrofit.
    ToyoD likes this.
  28. Sep 14, 2021 at 6:15 PM
    #88
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I use the ram mount accessories and they have worked great
  29. Sep 14, 2021 at 6:17 PM
    #89
    Hightide
    Abalama
    Magic School Bus
    Different types of mounts.
    Not really a replacement for what we’re doing.
    https://gripgear.com/
  30. Nov 10, 2021 at 6:50 PM
    #90
    Last of the V8
    Last of the V8 New Member
    21 limited Trd calvary Blue
    Rsi smartcap, predator steps, roadmaster suspension, nicks tyranny cooler. Rago dash mount plate. Console safe.
    I just ordered the plate today. They are. Running an early black Friday sale of $20 off. Appreciate all the info on here.
    ToyoD and YotaBro like this.
