Radio has no power...what fuses?
Discussion in 'Audio & Video' started by Tundra234, Oct 12, 2020.
  1. Oct 12, 2020 at 11:53 AM
    Tundra234 [OP] New Member
    I lost power to the radio while installed the Anytime camera backup kit. What fuses control the power to the radio besides the 15A fuse under the dash, which is good. Thanks.
  2. Oct 12, 2020 at 12:11 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    If it is aftermarket, some HU have fuses on the back of the radio.
    A can't remember if you are still using the Entune or aftermarket..
  3. Oct 12, 2020 at 12:16 PM
    Entune. It has no backlighting in the buttons either.
  4. Oct 12, 2020 at 12:17 PM
    George, are you 100% positive that the radio plugs are seated correctly?
  5. Oct 12, 2020 at 12:18 PM
    Yes....I have it apart now. I unplugged the camera harnesses and plugged the factory plugs back in and still nothing.
  6. Oct 12, 2020 at 12:21 PM
    :monocle:
  7. Oct 12, 2020 at 12:22 PM
    No backlighting either that's why I'm leaning to no power
  8. Oct 12, 2020 at 12:24 PM
    Dash lights by AC/Blower knobs light up?
  9. Oct 12, 2020 at 12:25 PM
    Is that @TundraTex 's FRAC or a different one?
  10. Oct 12, 2020 at 12:27 PM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Is this of any help?
  11. Oct 12, 2020 at 12:27 PM
    Anytimebackupcamera.com. Radio still doesn't power up when I unplug it and put factory connectors back in.
  12. Oct 12, 2020 at 12:30 PM
  13. Oct 12, 2020 at 12:33 PM
    CaptainGrumpus
    Maine
    Check your acc/ignition fuse as well. Also, are you plugging in the heater/ac controls back in before testing?
  14. Oct 12, 2020 at 12:33 PM
    Under hood
    #20 or #21
  15. Oct 12, 2020 at 1:06 PM
    My fuse box is layed out different.
  16. Oct 12, 2020 at 1:12 PM
    The heat and AC work.
  17. Oct 12, 2020 at 1:12 PM
    Yes. Its only the radio that is out.
  18. Oct 12, 2020 at 1:15 PM
    AZBoatHauler
    So.Arizona
    This is the one under the hood - not in the cab.
  19. Oct 12, 2020 at 1:16 PM
    Test light, check the wiring harness/plug for power.
    Hopefully you didn't burn out the radio.
  20. Oct 12, 2020 at 1:17 PM
    Right but mine is not laid out like that.
  21. Oct 12, 2020 at 1:18 PM
    I grabbed that off the internet, says it a 2020 under hood fuse box.
    Did you check the owners manual?
  22. Oct 12, 2020 at 1:18 PM
    AZBoatHauler
    So.Arizona
    Can you snap a pic of the label on the lid?
  23. Oct 12, 2020 at 1:20 PM
    Check all those 15 amp fuses, one should be for the radio.
    AZBoatHauler likes this.
  24. Oct 12, 2020 at 1:25 PM
    andyman68 likes this.
  25. Oct 12, 2020 at 1:30 PM
    Those are all good.
  26. Oct 12, 2020 at 1:43 PM
    I am not seeing a fuse.
    The fuse panel inside the cab by the driver kick panel are all good?
    If so, time to get a test light and check the plug that goes into the radio for power.
  27. Oct 12, 2020 at 1:45 PM
  28. Oct 12, 2020 at 1:46 PM
    Check this one....
  29. Oct 12, 2020 at 1:46 PM
    CaptainGrumpus
    Maine
    Did you the 7.5A IGN fuse? Sorry to keep spitballing...Its gotta be a fuse somewhere!
  30. Oct 12, 2020 at 1:48 PM
    Wouldn't that 40 amp main fuse blow first? :notsure:
