Radio antenna
Discussion in '1st Gen Tundras (2000-2006)' started by chunk, Mar 1, 2016.
  1. Mar 1, 2016 at 11:19 AM
    chunk
    chunk [OP] New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Is my antenna supported, that is, bolted at the bottom under the inner fender? My antenna is loose, but the top nut is tight. Thought I'd ask before taking the wheel and inner fender off. Maybe if needed i can leave the wheel on and work around the wheel? I've had to do so little on this truck i don't know it as well as my old motorcycles. Thanks for any info. Cheers.
  2. Mar 1, 2016 at 12:42 PM
    If its like the 2nd/3rd gen, then yes there is a bolt under the wheel liner.
    Krazie Sj likes this.
  3. Mar 1, 2016 at 2:57 PM
    chunk
    Thanks!
  4. Oct 13, 2016 at 9:43 PM
    Oldrosetattoo
    Oldrosetattoo New Member
    Eric
    2001 tundra SR5 access cab
    What about a first gen? Took it through the car wash and it broke it clean off with part of the thread screw still inside. Tried unscrewing the lock nut but was told I need a special wrench to remove it.
