Radiator Fan Not Working
Discussion in 'Off-Topic Discussion' started by Thattundradude, Aug 15, 2019.
  1. Aug 15, 2019 at 4:48 PM
    Thattundradude
    Thattundradude [OP] New Member
    Platinum Tundra
    Lifted
    Hi everyone, wondering if theres any experts out there. I got a 2010 Hyundai and the radiator fan is not working. If I ground it and supply power directly it turns on, I've checked the fuses and relays and it doesn't have the typical ones. It's a multi fuse junction box and the connector looks perfect. It also is drinking up coolant from the reservoir a lot.
  2. Aug 15, 2019 at 5:32 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Bad fan switch not making a ground???You’ll need a radiator pressure tester to find your leak. some autoparts stores may have a loaner program for that tool. If you can’t find a leak, check your oil for signs of water and raising the oil level. It maybe seeping into the cylinders and burning off. Check your spark plugs look for a really clean one it’s usually the one. You may even need to take your plugs out and pressurize the system over night to see if antifreeze seeped inside the cylinder/s. Good luck hope this helps.
    Thattundradude[OP] likes this.
