Radiator Cap Leak??
Discussion in '2.5 Gen Tundras (2014-2021)' started by Anthony605, Jan 2, 2022.
  1. Jan 2, 2022 at 10:18 AM
    Anthony605
    Anthony605 [OP] New Member
    Anthony
    2020 Limited Double Cab
    Took a look under my hood today. I constantly have to clean a small trail of dried coolant from the area of my radiator cap on my 2020 Limited. I am assuming that the cap is leaking a little bit? Anyone else have a similar problem? I know if the cap is bad it is under warranty but I do not feel like bringing it to the stupid dealer for a $17 part! Plus, they will probably spill coolant and make more of a mess for me to clean. Coolant is not low so the leak is very minor. I attached a pic....
  2. Jan 2, 2022 at 10:25 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    That looks like it follows a seam in the radiator tank. Clean it off and see if the seam is leaking, or if the cap is bad. If it's a failing seam, it could let go at the worst possible time.
    NewImprovedRon likes this.
  3. Jan 2, 2022 at 1:27 PM
    Anthony605
    Anthony
    I originally thought the same thing. I checked the seam really good and it does not appear to be cracked in any way. It looks like it is dripping out of the top of the cap and following the seam ridge down. Hopefully I am right! I just reversed the cap. I am going to see if the leak stops or goes to the other side of the radiator. If it goes to the other side then its the cap for sure. Thanks!
    1lowlife and Randy Morton like this.
  4. Jan 2, 2022 at 2:29 PM
    Randy Morton
    Randy
    I'll keep my fingers crossed that it's just the cap. :fingerscrossed: I, too, would hesitate to take it to the dealer. Sitting in the waiting room for a couple of hours while they confirmed the diagnosis wouldn't be worth it for just a radiator cap.
  5. Jan 2, 2022 at 2:41 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Gives you an excuse to buy the $$ TRD radiator cap..:D
    TRD Radiator Cap - Type N | Sparks Parts
    Just think how impressed anyone that looks under the hood will be with your TRD cap...:eek2::rolleyes:
    Might as well get the $$ oil cap too..:eek:
    TRD Oil Filler Cap - Screw On | Sparks Parts
    Just messing with ya...
    Hope it's just the cap, good luck..:thumbsup:
  6. Jan 2, 2022 at 3:29 PM
    Abos
    Abos Long live 5.7L V8
    2014 SR5 Crewmax
    Looks like it's leaking from the cap. Cheap fix to buy another and see if it stops leaking
  7. Jan 2, 2022 at 4:37 PM
    Anthony605
    Anthony
    That TRD stuff is funny! I am guessing the radiator cap is just a stock cap with a TRD sticker? Is the correct Toyota part number, 16401-36020, for the cap? Thanks
  8. Jan 16, 2022 at 4:19 AM
    Anthony605
    Anthony
    It looks like it was the cap for sure. I reversed it and no more leak. Since there is no more leak, I am just going to leave it as it. Thanks for helping!
    Randy Morton likes this.
  9. Jan 16, 2022 at 5:56 AM
    blanchard7684
    blanchard7684 New Member
    good to keep a spare cap on hand as well.
  10. Jan 16, 2022 at 6:52 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    You might check where that mold line hits the sealing surface on the lip of the radiator. Maybe a pronounced edge that you could sand off....
  11. Jan 16, 2022 at 6:55 AM
    blanchard7684
    might be debris under the gasket too...
  12. Jan 16, 2022 at 7:39 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    It's probably just a drip from when someone checked the fluid level.
    2mchfun likes this.
