Radar detector/rear view mirror wiring
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by 2TacoTony, Dec 29, 2019.
  1. Dec 29, 2019 at 1:25 PM
    2TacoTony
    2TacoTony [OP] Tony
    Anthony
    COLORADO
    2019 Super White Tundra TRD Pro
    Hey all. I recently bought a radar detector, and I hate the power cable coming from the cigarette port. I bought a direct wiring kit to pull switched power off of the rear view mirror. Has anybody tackled this in a 2019 TRD Pro yet. I have a multi tester, so I can figure it out. But was checking to see if anybody had some insight.
  2. Dec 29, 2019 at 2:06 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    I’ve always run direct wire tapped off one of the cig fuses. Never done it off the mirror.
    Brandisher likes this.
  3. Dec 29, 2019 at 3:32 PM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
  4. Dec 29, 2019 at 6:24 PM
    one4x4dad
    one4x4dad New Member
    James
    Houston TX
    2019 Tundra Crew Pro
    2TacoTony[OP] likes this.
  5. Dec 29, 2019 at 6:30 PM
    2TacoTony
    2TacoTony [OP] Tony
    Anthony
    COLORADO
    That is the exact one I bought. Same exact year and model of Tundra. Do you remember which wires you tapped into?
  6. Dec 29, 2019 at 6:31 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Blendmount and mirrortap are the 2 companies you need to be looking up :thumbsup:
    HackerDaHun and Medic343 like this.
  7. Dec 29, 2019 at 6:33 PM
    2TacoTony
    2TacoTony [OP] Tony
    Anthony
    COLORADO
    Will do, thanks for all the help guys!
  8. Dec 29, 2019 at 6:45 PM
    Captainjohn
    Captainjohn New Member
    2019 Tundra Dbl cab
    Rock sliders, topper, sliding bed
    Following
  9. Dec 29, 2019 at 6:54 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    on my 2016 platinum, i tapped ignition power from my mirror wires. Blue = 12v + and white/black = ground. I used it for my dash cam.
    TRDblvd likes this.
  10. Dec 29, 2019 at 7:41 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I had to grind down the terminals in the mirror tap to get good contact.
  11. Dec 30, 2019 at 11:27 AM
    one4x4dad
    James
    Houston TX
  12. Dec 30, 2019 at 11:28 AM
    one4x4dad
    James
    Houston TX
    Works like a champ. I can’t tell which wire it is without removing the whole setup. Voltmeter and 4 minutes.
  13. Dec 30, 2019 at 11:28 AM
    one4x4dad
    James
    Houston TX
    They come with smaller adapters. Make sure to use those.
  14. Dec 30, 2019 at 11:39 AM
    King R 808
    King R 808 New Member
    Ryan
    2020 White Tundra TRD Pro
    I had one of these many years ago but found it never worked right. Have they improved to actually detect police before i get tagged for a ticket lol? it would go off around automatic doors at stores and a lot of other random things that didn't matter to me and my speed.
    patek likes this.
  15. Dec 30, 2019 at 1:49 PM
    one4x4dad
    James
    Houston TX
    It really depends. They do a good job when you listen to them. The gps is now updated with live alerts and stored speed traps. although I was pulled over recently while ignoring it. I was given a warning, I believe because I admitted my fault and was totally respectful.
  16. Dec 30, 2019 at 4:50 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Anyone know if there is constant 12v at the mirror plug? I forgot to check and now I want to wire up my dash cam for parking mode. Lazy to run wires all the way down the dash.
  17. Dec 30, 2019 at 6:01 PM
    2TacoTony
    2TacoTony [OP] Tony
    Anthony
    COLORADO
    Done deal. It was easy. The Red is +12 switched power. White/Black stripe is ground. Didn't try searching for constant power for the dash cam. There were 5 wires total, so 2 of them are accounted for. I'm curious, I'll look into it tomorrow.
    BlueBottle likes this.
  18. Jan 1, 2020 at 4:02 AM
    patek
    patek New Member
    2019 trd sport
    Retired P.O for what's worth they are a waist of money. Police units always ahead of store bought when it comes to tech. Plus if stopped for speeding most officers will write you no hope for a warning.
  19. Jan 11, 2020 at 10:40 AM
    one4x4dad
    James
    Houston TX
    Got a warning 3 weeks ago speeding in a construction zone, while it was on, still buzzing when he walked up. I was super honest with the officer and very respectful. I think being honest and respectful is the key... It's really used on the HWY for me.
  20. Jan 11, 2020 at 1:28 PM
    2TacoTony
    2TacoTony [OP] Tony
    Anthony
    COLORADO
    I do totally get what your saying, cause I've never trusted them 100%. Yes, attitude is key regardless.
  21. Jan 11, 2020 at 1:36 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Sounds like you need a better understanding of how radar detectors work, the different radar and lidar technology cops use to obtain speed and what radar detectors can't detect. Also helps to know what radar guns your local police use.
    HackerDaHun and deptrai like this.
  22. Feb 4, 2021 at 1:06 PM
    Jmn
    Jmn New Member
    Did you find the constant power back there?
    Thank you!
  23. Feb 4, 2021 at 3:57 PM
    2TacoTony
    2TacoTony [OP] Tony
    Anthony
    COLORADO
    I apologize JMN, I never looked into it after all. I didn't want to run down my battery with constant 12+. I keep mine on switched power.
    Jmn likes this.
  24. Feb 4, 2021 at 8:11 PM
    Jmn
    Jmn New Member
    Hey don't worry :)
    I believe I will go the same route.
    Potentially using this harness:
    https://www.amazon.com/SimpleUSB-Mirror-Dashcam-adapter-mirrors/dp/B07DMW3DML/
  25. Feb 10, 2021 at 8:25 PM
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Minnesota
    2020 TRD Pro Tundra, 8371 Club
    Coachbuilder Pro Kit, 35x12.5 BFG KM3s, Baja S8 hood mounted, Rago Lo-Pro Brackets sitting empty at the moment, Rago Dash Divot Plate, AJT Stuff, LED Lighting throughout, TRD Intake, Bedliner, Tint, Full front PPF, SPS Graphene Coating, and dropped the B out of JBL ;-)
    I went the add a fuse way from underneath the drivers footwell and just hid and ran the cable up. Got an awesome floating mount for my V1IMG_20210128_132500.jpg
  26. Jan 8, 2024 at 2:03 PM
    HighwayStar22
    HighwayStar22 New Member
    Jax, FL
    '21 Tundra Platinum Crewmax 4x4
    Resurrecting this thread from the dead in lieu of making a new thread. I have a V1 Gen 2 and was planning on getting the BlendMount and Mirror Tap for that. I also am planning on installing a dash cam and want to get the Donger USB adapter to power that. Here's where the question is. I know the mirror tap has an inline fuse in it, curious what you all think about running both Mirror Tap and Donger at the same time splicing in Pwr/Grnd into the donger adapter at the picture shown. I don't want to blow fuses or melt anything down.
    Blend Mount: https://blendmount.com/aluminum-rad...tine-one-gen1-gen2-standard-series-bv1-2001r/
    Mirror Tap: https://blendmount.com/power-cord-mtx-1010-patented-10-long-rj-11-2-amp-fuse-military-grade-taps/
    Donger USB Adapter: https://dongar.tech/products/12pin-tacoma
