Rad support cracks
Discussion in 'General Tundra Discussion' started by Mountun Goat, May 15, 2018.
  1. May 15, 2018 at 8:50 PM
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Anyone ever have the upper part of the rad support crack? Mines 2008 for info. This is the piece that also conveniently holds the hood latch... The aux rad in front the main rad is also mounted to this. The amount of shake my hood gets is gross. I kept thinking my hood was open. I thought it was a Tundra thing until I investigated haha. Looks like I’ll be busting the old welder out this weekend for some repair beads.
  2. May 16, 2018 at 8:14 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    That sucks!!! Big time!! Good luck on fixing it when you do.....keep us posted on how it goes.
    Mountun Goat[OP] likes this.
  3. May 16, 2018 at 8:46 AM
    n2deep
    n2deep Pavement Princess
    Yupp @osidepunker and I have been dealing with those for some time. His is worse than mine but it has caused the radiator to rub a hole and leak. Waiting on new radiator now. Have to redo the mount for the cooler and fix a couple other cracks in the same area.
  4. May 16, 2018 at 8:58 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s cause you guys use your trucks to the max LOL. Flexing! :muscleflexing: You need strut tower braces like the ricers use. Full tube chassis!
  5. May 16, 2018 at 9:00 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Mine is cracked in the same place on both sides. Also, one of the upper radiator screws pulled all the way through the sheet metal. But in my case this all happened because my vertical support under the hood latch broke.
    The entire radiator support piece from headlight to headlight is $138 but requires cutting and welding to install. Local body shop want $500 labor.
    I'm going to weld and patch the cracks and fabricate a new vertical support
  6. May 16, 2018 at 2:07 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Jeeze. Well there ya go. I guess it’s common enough. Looks easy enough to weld up the cracks. Yes I will update on how my repairs go. Whether they come back or stay away is another question...
  7. May 16, 2018 at 2:29 PM
    15whtrd
    15whtrd Mr. Blonde
    I would think you would want to drill a hole at the end of the crack and then weld it up. But I’m no welder.
  8. May 16, 2018 at 2:45 PM
    Professional Hand Model
    Hand Protectors
    Run some self tapping screws with rubber washers strategically on either side of those cracks and call it a day!
  9. May 16, 2018 at 3:16 PM
    ZPMAN
    Minnesota
    If you want it to last, take the unit out and clean up all surfaces and mig weld it or take it to a body shop with a 12 pack and they will mig it. If you are a very talented welder then give it a try with the red bomb box. Just my 3%
  10. May 16, 2018 at 3:49 PM
    n2deep
    I am dealing with a handful of cracks on my truck. Front Spindle gussets are cracked, Rear bed in multiple spots, rear fenders, front radiator support and Radiator and those are just the ones I have found. Will be redoing the rear soon adding some bracing and gussets to address those. The rest will be easy fixes with the MIG
  11. May 16, 2018 at 7:17 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Gross! That’s a lot. I was thinking of building some box brackets like the aftermarket ones I see. I’m curious what a front spindle gusset is..? It doesn’t sound good to be cracked haha
  12. May 16, 2018 at 7:17 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    That was my thoughts too! Good call!
    15whtrd[QUOTED] likes this.
  13. May 16, 2018 at 7:19 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’m not super talented at anything haha. I’m ok at a lot of stuff haha. I’ll try welding it up first since above almost everything else I’m cheap! :anonymous:
    ZPMAN[QUOTED] likes this.
  14. May 16, 2018 at 7:58 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    No welds yet- but hole drilled! One step at a time here. Don’t want to over do it.
  15. May 16, 2018 at 8:04 PM
    15whtrd
    15whtrd Mr. Blonde
    At least the crack will have less of a tendency to spread. One step at a time. Gotta start somewhere!
  16. May 20, 2018 at 8:09 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I got my cracks fixed over the weekend The sheet metal is paper thin and we had a hard time. Kept blowing holes through the metal. Best technique we found was to lay a rod in the crack and weld the rod to the sheet metal. Use a copper backing plate. After we got the cracks welded we rivited a 16 guage plate over the entire area to reinforce it. Then we made some vertical supports and tried to spread the load a little. The hood latch is super solid now and I'm confident that everything will hold up.
    Mountun Goat[OP], equin and 15whtrd like this.
  17. May 20, 2018 at 8:14 AM
    15whtrd
    15whtrd Mr. Blonde
    Now to go out and Dukes of Hazzard that thing! See how she holds up LOL JK
    osidepunker[QUOTED] likes this.
  18. May 20, 2018 at 8:15 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    That's the ultimate system test isn't it?? LOL
  19. May 20, 2018 at 8:16 AM
    15whtrd
    15whtrd Mr. Blonde
    osidepunker and equin like this.
  20. May 20, 2018 at 2:48 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Wow thanks for your input. You gave me a new idea. I wonder how some kid of stir would work? Line it up and bolt it in? Have some predrilled holes in it to fill with weld? Easier or harder?
  21. May 20, 2018 at 2:57 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Lol repeat that Your autocorrect is confusing me about what you're asking
  22. May 20, 2018 at 3:02 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Oh shit haha. Use a piece of strut. ‘...some kind of strut would work?’ :oops:
  23. May 20, 2018 at 5:12 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Not with that red buzz box:eek:
  24. May 20, 2018 at 7:19 PM
    ZPMAN
    Minnesota
    Anyone needing sheet metal parts for there trucks check out Cirtifit, they are very reasonable with the prices and they will send you a free catalog.
  25. May 21, 2018 at 4:45 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    The oem radiator cross member is only $138 from toyota. But labor quote from my local body shop was $500. Plus, I had to redo my vertical support anyway. So I gave it go. I figured if I dorked it up I could always just replace it. I think this will work and I'm only out $15 in metal and a bottle of rum for my assistant.
  26. May 21, 2018 at 4:51 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    We probably didn't really know what we were doing, but that sheet metal is so damn thin. Very difficult to weld. But the welds aren't really needed I think. The sheet metal patch is enough. After it was welded it was still flexible. Once we added the patch, everything was nice and stiff. After the vertical support was done, it was even more stiff.
    If this doesn't hold up, I'm going to cut the entire piece out from head light to head light and build a whole new cross member out of tube. But I think this is going to be durable.
  27. May 21, 2018 at 8:00 AM
    ZPMAN
    Minnesota
    Looks like you did a great job, changing out the support is not to hard. A few years a i did a make over on my 89 sr5 pickup , two doors, two fenders, grill, lower valence panel, and a tailgate was $400 from Cirtifit.
    osidepunker and Mountun Goat[OP] like this.
