Rack and pinion
Discussion in '1st Gen Tundras (2000-2006)' started by Fftate, Dec 8, 2015.
  1. Dec 8, 2015 at 1:07 PM
    Fftate
    Fftate [OP] New Member
    Austin
    2001 white tundra trd
    Hey guys. I have a 1st Gen. 2001 Tundra. Access cab, limited, 4.7 v8, trd. I got roughly 310,xxx miles. Major fixes are the coil packs, LCA bushings, shocks and struts, and tie end rods. I need to fix my rack and pinion next. It's becoming worn out. I've took it to a few places to get a quote on fixing it. Their quote was $1000 . I found one for 300. But how hard is it to do and what tools would I need to do it myself?
  2. Dec 8, 2015 at 2:56 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    It's not hard, but does take time. You'll need something to pop the outer tie rod ends out (BJ separator, tie rod removal too, etc.), and a handful of sockets. The FSM calls for a SST (09023−12701) to remove the pressure & return lines, but can be done with a flair nut wrench if you are clever. The center bolt holding the rack on is a bitch because the bolt is above the rack/crossmember. My suggestion is to leave the steering wheel dead nuts centered before disassemble and make sure the gear assembly stud thingy is centered as well so when you put the intermediate shaft back on the rack gear is perfectly centered.
    Cross forum thread to help:
  3. Dec 8, 2015 at 6:57 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    What he said^ I would hate to do it on jack stands... that would royally suck...
  4. Dec 8, 2015 at 7:13 PM
    jberry813
    Lake Tahoe
    I did it at ride height on the taco.
    Fuck me right?
  5. Dec 9, 2015 at 11:54 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I did mine in the desert of Utah remember!? That sucked.... never again
