Raceline Gauge 950
Discussion in 'Wheels & Tires' started by TRDFerguson, Aug 27, 2020.
  1. Aug 27, 2020 at 5:24 PM
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  2. Sep 2, 2020 at 3:37 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Just got the call that these are in, and they'll be going on tomorrow!
    RobertD likes this.
  3. Sep 2, 2020 at 3:46 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I run on 18x9 Raceline Shift's.
  4. Sep 2, 2020 at 5:01 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Those are what my buddy has on his Sierra. They look good and were on my short list, but the Gauges won out. There were a few other brands and styles I was looking at, but it's kind of amazing how many didn't come in an 18x9. Or were completely out of stock *cough* SCS *cough*...
    realtorblake[QUOTED] likes this.
  5. Sep 3, 2020 at 1:18 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Just got back from the shop. The new wheels exceed expectations!
    However, since these are a little more aggressive on the offset than my old wheel/spacer combo, I've got some more fender plastic manipulation to do...
    That's the only rubbing I've found, though, so not bat at all.
    ZPhilip, Mater, dpast88 and 1 other person like this.
  6. Jan 19, 2021 at 7:12 AM
    SteelDragon
    SteelDragon New Member
    2021 Tundra SR5 DC
    None
    Hi Love the look of your set up. Do you have a lift and is it at full turn to the right with the minor rubbing?
    TRDFerguson[OP] likes this.
  7. Jan 19, 2021 at 7:28 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Damn fine setup!
  8. Jan 19, 2021 at 7:28 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Loosen the 2 x 12mm bolts and 1 x 10mm bolt underneath each bumper cap. Pull it forward, redrill through the plastic for the 10mm bolt and you should be able to gain 1/2".
    I just had the same thing happen and was an easy fix. Not my video, but this shows you what I mean.
  9. Jan 19, 2021 at 7:40 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I was leveled at the time I think, but just did what @BravoDeltaRomeo mentioned and solved all the world’s problems. I had already used bumper shims and trimmed the skid plate prior to this. I added 1” to the front and rear a few months ago though and now have plenty of clearance.
    BravoDeltaRomeo likes this.
  10. Jan 19, 2021 at 7:46 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Very nice and congrats
  11. Jan 19, 2021 at 8:01 AM
    SteelDragon
    2021 Tundra SR5 DC
    None
    Thank you for the reply and showing the video. Have a good day!!!
  12. Jan 19, 2021 at 9:01 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    If a 13y old can do it, outside in the snow....so can you :thumbsup:
  13. Jan 19, 2021 at 3:03 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Here’s a post-lift pic:
    Neo258, baron, ShinyConcretE and 2 others like this.
  14. May 8, 2022 at 8:04 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    @Eric1245
    @TRDFerguson
    Which lugnuts did you guys use for the Raceline wheels? Acorn, extended thread, short, tall & skinny, ...
  15. May 8, 2022 at 8:23 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I just had Discount Tire order the appropriate lug nuts for the wheels. I’m pretty sure they’re long splined acorn style, but I’d have to check.
  16. Nov 26, 2023 at 10:19 AM
    Samuel moreno
    Samuel moreno New Member
  17. Nov 26, 2023 at 10:22 AM
    Samuel moreno
    What wheel size and tire size is it?
  18. Nov 26, 2023 at 10:31 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The wheels are 18" diameter and 9" wide with a +18mm offset, and the tires I was running in those pics are 295/70R18, roughly 34x11.5". I've since moved up to 35x12.5.
    reywcms, RobertD and FrenchToasty like this.
  19. Jan 17, 2024 at 4:00 AM
    Marcoan06
    Marcoan06 New Member
    Marco
    2019 Cement grey SR5
    2 inch leveling kit. 17 inch raceline wheels. 34 K02
    2 inch leveling kit
    SnowToy, TRDFerguson[OP] and Nic146 like this.
  20. Jan 23, 2024 at 8:40 PM
    Nic146
    Nic146 New Member
    Probably stuck somewhere
    2016 Barcelona Red TRD CM
    Such a good looking wheel. So much better than having a fake bead-lock. :annoyed:
  21. May 18, 2024 at 8:52 AM
    Crews44
    Crews44 New Member
    Southern NJ
    2025 Platinum TRD MGM CM 3” TRD lift
    Just pulled the trigger on the 950 Gauges with Falken Wildpeak AT4W. Going with 285/65-18 in non-LT SL load range. Looking to get as light and quiet as I can. I’m tired of the ride of LT tires. Had Toyo ATIII in same size and loved them till they got to the end. Now they’re loud and treacherous in the rain.
    Neo258 likes this.
  22. Mar 21, 2025 at 4:05 PM
    Jmunk
    Jmunk New Member
    2020 Tundra SR5 Crewmax
    With the offset do you find that anything gets thrown on the painted surfaces of the truck given they stick out a little?
  23. Apr 19, 2025 at 4:24 AM
    Crews44
    Crews44 New Member
    Southern NJ
    I have this same setup on my 2.5 gen and love them. They about 6 months old but I just bought a 2025 platinum TRD.
  24. Apr 25, 2025 at 6:28 AM
    Crews44
    Crews44 New Member
    Southern NJ
    I will be posting my setup for sale today here. Falken Wildpeak AT4W 285/65-18, lugs and tpms sensors. Just bolt up and go.
    18k miles on them.
    Paid $2800 6 months ago. Will be asking $1500.
    HulkSmurf14 likes this.
  25. Jun 25, 2025 at 8:45 PM
    birdman86
    birdman86 New Member
    Old bump… so you were running the 295/70’s on stock suspension? Thinking about a set of these but the shop is saying 275/65r18’s are biggest option without a lift
