Quick question about debadging
Discussion in '2nd Gen Tundras (2007-2013)' started by ChadGrissom, Apr 8, 2017.
  1. Apr 8, 2017 at 2:58 PM
    ChadGrissom
    ChadGrissom [OP] New Member
    2012 Texas Edition Crewmax
    Bilstein 5100 front (Level) and back, K&N Ram Air Intake, Flowmaster Cat back dual, Toyo 295/65R20 on XD Misfit 20X9
    I'm wanting to debadge my truck and repaint the badges black, its a 2012 so I'm sure there will be a difference in the finish that's under the badges which is a driving force behind wanting to put them back on, I did a test run on my grill logo after I removed the factory chrome insert today and I'm happy with the results after a bit of sanding, two coats flat black, and two coats clear coat, how do I go about getting the badges back on? I'm assuming the factory adhesive will be no good so what are my adhesive options?
  2. Apr 8, 2017 at 3:04 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    My 13 didn't have a difference in finish when I took them off......you might be okay. If you just want to black them out, leave them on the truck and spray them with plasti dip. If you are determined to r & r, then some good 3m double side tape is your friend. Mark where they belong really well before you remove them, you don't want to put them back in the wrong spot.:)
  3. Apr 8, 2017 at 3:05 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    Go to the auto part store and get 3M double sided tape. Clean the back of the emblem and the area it mount to very well so it had a good sticking surface. They have different widths so find a width that matches. I would also make a mental note of where the factor tape was and try to mimic it simply bc they put it there so might as well to try to make sure you get the same quality connection.
    NewImprovedRon likes this.
  4. Apr 8, 2017 at 3:06 PM
    ChadGrissom
    I didn't consider leaving them on and using plasti dip, thanks man
  5. Apr 8, 2017 at 3:08 PM
    Tundra Fan
    Toby
  6. Apr 8, 2017 at 3:08 PM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
  7. Apr 11, 2017 at 3:27 PM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    Just finished my 08 with no issues in paint color difference. 50lb fishing line. Goo gone.... Wax :thumbsup:
    NewImprovedRon and TheBeast like this.
  8. Apr 11, 2017 at 3:36 PM
    Leave em on...plastidip em... i did 5 coats..use kabob sticks to remove inside letters and around em
    BravoDeltaRomeo likes this.
  9. Apr 22, 2017 at 4:19 PM
    Smdg32
    Smdg32 New Member
    Steven
    2012 Tundra crew max TX edition
    Linex front grille, M1Bumper, 7" BDS Suspension with Fox Shocks, Linex Buschwhacker fender flares(Linex), 295/65/r20 Nitto MT, 20" Raceline Mamba, Trd Cold Air Intake, Weather Tech floor liners, Spyder Ubar smoked headlights & Taillights, Tonno Pro hard bed cover, Recon extended range antenna, Pioneer head unit, Rockford Fosgate Prime speakers, front/back/dash....More to come
    I took off all badges but my Texas edition stars by my rear doors. I then taped around then with newspaper very well. I then sprayed them with plasti dip and put a few coats and then the clear. Let it sit then used a toothpick to pull (easy) looks great and has held up for 3 years.
    TunaDr and NewImprovedRon like this.
  10. Apr 22, 2017 at 8:24 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    @TheBeast debadged his recently and his Tundra is black as well. Maybe he can answer some of your questions.
    TheBeast likes this.
  11. Apr 22, 2017 at 8:25 PM
    TheBeast The Beach
    2012 debadged in 2016
  12. Sep 23, 2019 at 11:57 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    So are you guys spraying the badges right on the vehicle, just masking the crap around it. I've looked at covers but they are not cheap. I've looked at new emblems, but they are even more expensive. One of the kids likes dark emblems, so we may be going that route.
    How are you covering the painted portions in between the letters? Or do you paint on those portions and then pic it with the kabob?
    Now just have to tell my wife I'm actually on a Tundra forum and looking at moding our brand new truck. :facepalm:Personally, I would prefer to de-badge it, but not sure how well that would go over with her either.
  13. Sep 23, 2019 at 1:26 PM
    Tundra Fan
    Toby
    Go for the debadge.........it looks clean. :cool:
    If she wont go for it, then yes, leave them on the truck. tape off around them , and apply several coats of PD. Then go back and pick out the spots you don't want dipped like ARamirez said in post #9.
  14. Sep 23, 2019 at 4:58 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I was too lazy to take proper pics of everything, bit this gives me a sense of a before and after....it does look clean without any badges
  15. Sep 23, 2019 at 4:59 PM
    AZBoatHauler
    So.Arizona
    You forgot the one on the C-pillar!! Looks good. I love that color.
  16. Sep 23, 2019 at 5:04 PM
    Some people like the clean look, some people like the blacked out look, it's your truck it's up to you, either way it looks good
  17. Sep 23, 2019 at 5:11 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Agreed. So here's the scoop, our youngest 12 is a Forza racing game and car guy. This is something I never thought I'd be interested in, but the truck has changed that. My wife thinks I'm crazy with looking at upgraded and mods but it allows me and the little guy to bond and talk about stuff, look stuff up and make decisions on truck things....he loves the truck
    I'm a simple guy, so this is more my style than all chromed and I'm too cheap to color match everything.
    Can't argue with the clean look and I'm comfortable and confident doing that, than plastidip the logos and scrap off extra or removing them and realigning them to the same factory spots. Plus this gives us some ammo to present to her with regards to missing out truck with 700km on it :thumbsup:
  18. Sep 23, 2019 at 5:19 PM
    oriojasjr
    oriojasjr New Member
    White 1998 T100
    Plasti dip is the easier route, but 3M is the way to go if you’re pulling them off. Your truck- do what makes YOU happy, not the masses. ;)
  19. Sep 23, 2019 at 5:47 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Oh I know, just looking for thoughts and suggestions. And to be honest, debadging and plastidip weren't even in my vocabulary a week ago. See what you guys have done to me!
    As far my de-badging mission goes, I got the go ahead to start with the SR5 badges. :yes:.
    We watched a couple videos, I showed her some pics and I think I'm winning her over.
  20. Sep 25, 2019 at 5:50 PM
    Fozzy360
    Fozzy360 New Member
    Hunter
    2010 Tundra Crewmax Limited
    Stock
    I use 3m tape for mine
  21. Sep 25, 2019 at 7:22 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    My 13 SR5 Crewmax is Barcelona red and I went with the matte black look on the emblems.I replaced the chrome emblems on the sides with matte black emblems and de badged the tailgate.Painted my Toyota emblem in the grill Barcelona red.IMG_20190502_195040800.jpg IMG_20190401_171911936.jpg IMG_20190401_171728454_PORTRAIT.jpg
    jewsNbrews and BravoDeltaRomeo like this.
  22. Sep 26, 2019 at 6:43 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    plasti dipped my front grill badge matches perfect with rest of the factory black.IMG-4704.jpg
  23. Oct 21, 2019 at 1:04 AM
    OrlandoSR5
    OrlandoSR5 New Member
    Personally, I like the blacked out look, but I also debadged the Toyota and dealer badges from the back. I took fishing line on a hot Florida summer day and peeled them off. Then used WD-40 to remove adhesive and clay bar to remove the ghosting from the letters. Can't tell that there were badges there at all.
  24. Mar 31, 2020 at 10:16 AM
    12TunToy
    12TunToy New Member
    JP
    Peoria, AZ
    2012 Tundra Limited CM RWD
    58k miles
    Krylon Fusion is what I’m using on my front grill & emblem. Stuff is amazing!
