Questions on VLEDS
Discussion in 'Lighting' started by Chaosx4, Apr 24, 2016.
  1. Apr 24, 2016 at 4:13 PM
    Chaosx4
    Chaosx4 [OP] New Member
    2016 White Tundra SR5 TRD
    Has anyone used vleds led headlights? Which ones if so? Also what led are you guys using to replace the DRL.
  2. Apr 24, 2016 at 4:27 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    From what I have read, it doesn't sound like Led headlights work to well in a halogen housing. Every picture I've found shows very scattered light patterns.
  3. Apr 24, 2016 at 4:56 PM
  4. Apr 24, 2016 at 4:59 PM
    Chaosx4
    Thanks Sean, do you know what bulbs those are? Also any idea if there's a replacement bulb for Amber lights?
  5. Apr 24, 2016 at 5:12 PM
    From the owner:
    "Yep, they are not cheap but they work great and they are white in the DRL mode too."
  6. Apr 24, 2016 at 5:27 PM
    Chaosx4
  7. Apr 24, 2016 at 6:05 PM
    TruckyTruck
    Gary
    Sean, can you get a picture of the bright lights on the wall? I haven't decided what I'm going to do with the brights. I almost ordered a set of led, but of course searching the internet for info can really wreck your plans sometimes.
    Hate to leave them halogen when all the other lights will be changed.
  8. Apr 25, 2016 at 7:12 PM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    It depends on which ones you get. For the switch/back led's they are awesome. I have used Stark led's for headlights for some time. They are a 3 sided cob led. Haven't had anyone complain yet
  9. Apr 26, 2016 at 6:37 PM
    Chaosx4
    Hey sstoddard, did you install the led headlights in the spyder headlamps? I'm am trying to figure out how to install the led in the aftermarket headlamps. I know I have read that someone has done it but I can't find the post.
  10. Apr 26, 2016 at 6:42 PM
    sstoddard
    Shawn
    2019 Crewmax Sport
    I installed mine in the oem headlights. They should install the same in your aftermarket headlights as long as the bulb is the same.
  11. Apr 26, 2016 at 6:42 PM
    Chaosx4
    Ok thanks.
