Question regarding oem aluminum oil filter housing….
Discussion in '2.5 Gen Tundras (2014-2021)' started by shawn474, Jun 28, 2023.
  1. Jun 28, 2023 at 1:48 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Just be gentle with the Fumoto, they are kinda soft.
    shawn474[OP] likes this.
  2. Jul 2, 2023 at 7:45 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    OK, since I haven't done this yet...
    When you remove the short one and replace it with the long one, does it just pull out? Do not like surprises.
  3. Jul 2, 2023 at 10:12 AM
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
    No there’s two tabs at the bottom that hold it in .
  4. Jul 2, 2023 at 5:52 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    You can generally push down and turn to remove the tube. Worst case if you have to straighten the tabs to clear the the housing bosses. Then bend them back to lock the tube in the metal housing.
  5. Jul 2, 2023 at 6:25 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Use a trim tool to gently press on the side of the tube just above the tabs and it will pop out
  6. Jul 2, 2023 at 8:14 PM
    SouthWestGA
    SouthWestGA New Member
    So what Fumoto Valve would fit an 08 Sequoia oil filter,and what for the drain plug?
  7. Jul 5, 2023 at 10:44 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
  8. Jul 5, 2023 at 11:01 AM
    coTony
    Tony
    Montrose, CO
    The tabs do NOT have to be bent, you can push the tube down to collapse the spring then rotate it and you can wiggle it out of there with NO bent tabs. I have done this 3 times now on different trucks
  9. Jul 5, 2023 at 11:28 AM
    TXBrit
    TXBrit New Member
    Weatherford TX
    2019 MGM Platinum
    Check in your owners manual for oil quantity. My 19 takes 8 1/2 quarts oil and filter change
