question regarding a 3 in lift (leveling kit) and bilstien 5100 adjustable shocks
Discussion in 'Suspension' started by learnem, Jan 15, 2020.
  1. Jan 15, 2020 at 3:11 PM
    learnem
    learnem [OP] New Member
    Bakersfield, Ca
    16 Tundra crewmax
    3 in lift, 2in wheel spacers. Tinted all the way around Stock platinum wheels and tires
    Hi all. I currently have the above mods, and was wondering if, with these mods, i would be able to achieve another 2.5 in of lift in the front if i were to install bilstein adjustable 5100 shocks.
    Thanks for your time.
    i only have the 3 in leveling kit, not the shocks yet.
    Mnorris1206 likes this.
  2. Jan 15, 2020 at 3:16 PM
    Mnorris1206
    08 tundra
    I'm not an expert but I dont think you will be able to achieve this without a suspension lift kit. For instance a lift kit would come with extended knuckles and a diff drop kit to get your angles for alignment back to normal. Also you CV axels would be way out wack without a diff drop kit in place. The only way I think you could get 3" more lift would be from a body lift kit. they are cheep but not the way i would want to lift a truck.
  3. Jan 15, 2020 at 3:54 PM
    Rockanock
    Rockanock 21 Chevy 2500
    I’m running 5100’s at 2.5. Not goofing up my CV axles and don’t need a diff drop but if I went more than this I’d do a diff drop and new upper control arms.
  4. Jan 15, 2020 at 4:28 PM
    Mnorris1206
    08 tundra
    The only thing is the OP is already running a 3" level kit I assume spacers idk maybe he can tell us more.
  5. Jan 15, 2020 at 5:47 PM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    No diff drop needed for 5100’s on top setting?
  6. Jan 16, 2020 at 6:22 AM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    I think I’m reading your question right.
    You have a 3” spacer lift and are wondering if adding Bilstein 5100 shocks set at 2.5” will work correct?
    If that’s your question I would say no. That is not a good way to achieve a 6” lift. There is more to lifting that high than just the Coilovers. You will need a bracket lift.
    Joe S
  7. Jan 20, 2020 at 4:56 AM
    Ob1
    Ob1 New Member
    Bad idea, no actually really bad idea. As stated above, for a 6 inch lift a bracket lift would be your cheapest solution.
    The angles you'd induce with what you are inquiring about would be virtually unalingnable. Plus too stiff to be useful.
  8. Jan 20, 2020 at 5:30 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No. Never stack lifting parts. One or the other. If you want more lift, you have to go with a lift kit that provides the drop down for the front crossmember and taller spindles.
  9. Jan 20, 2020 at 9:53 AM
    Do not stack lifts
  10. Jan 20, 2020 at 11:06 AM
    pauldrade
    pauldrade Drade Tundra
    Paul
    2013 tundra double cab
    3" lift, 33” tires open country AT2, 18" Mayhem rims, flowmaster exhaust, K&N intake, smoke rear lights and 3rd brake light. Optima RED Top battery, LED Lights all around, Mesh black Grill, Alpine double dash Nav head unit. Suspension 5160s rear 5100s front.
    So can you have a 3” leveling kit and have 5100s set at zero and that be ok? Cause even at zero their is still a slight lift.
  11. Jan 23, 2020 at 4:41 PM
    I wouldn't do it. You are already pushing the bounds of you UCA when it comes to travel and alignment.
  12. Jan 23, 2020 at 7:28 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    This is a big negative..And if you attempt it your cv axles will probably be at a 45 degree angle.
