Question on Wheel Spacers/Lift
Discussion in 'Wheels & Tires' started by Marine0351, Jun 10, 2024.
  1. Jun 10, 2024 at 3:38 PM
    Marine0351
    Marine0351 [OP] New Member
    Hi:
    I just put a 6” lift on my 2024 with the stock 20” TRD rims. I am getting in the mail tomorrow 275/65/20’s. I want the wheels to protrude outside the wheel well tastefully. Maybe an inch or 2 at the most just to give it an aggressive stance. What is the largest wheel spacer I should go with? Thank you in advance for the info
  2. Jun 10, 2024 at 8:51 PM
    Rabbi
    Rabbi New Member
    2024 Tundra(Limited Premium Package) 4X4
    Did you check with the dealer on the 6 inch lift? It is possible that lift will void the warranty if Toyota, can tie any damage to an aftermarket modification. I know it has to be related to the lift. Look on the forum for individuals having their warranty voided by Toyota for the modifications. I spoke with the dealership myself on my 2024, and the service department was clear. Basically you are rolling the dice. Hope it all works out for you.
  3. Jun 11, 2024 at 12:18 AM
    Marine0351
    Magunson-Moss Act
    … the Magnuson-Moss Warranty Act puts the burden on the automaker to prove that a modification directly contributed to the failure of a specific component
    Rabbi likes this.
  4. Jun 11, 2024 at 8:25 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    The lift manufacturer will have details about what offset wheels will work. Most all bracket style lifts give specs on appropriate wheels and offsets for their kits. Look into that before buying spacers or wheels to make sure it will work with the lift.
