Question on putting weight in rear for winter driving
Discussion in '2nd Gen Tundras (2007-2013)' started by Jon1979, Oct 29, 2019.
  1. Nov 30, 2019 at 3:12 PM
    #61
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Used to add 5 or 6 100lb tractor weights on a sheet of plywood back in the 80's in my 2x4's, now with 4x4 I don't add anything.
  2. Nov 30, 2019 at 4:22 PM
    #62
    WNY PAT
    WNY PAT New Member
    Western New York
    2025 GMC Sierra 2500HD AT4 2017 CM Limited (Sold) 2019 CM SR5 l
    I put four or five 60# bags of tube sand over the rear axle. As others have mentioned, partly for the additional weight and partly for traction if I ever get hung up on sheer ice. Even in 4WD, the additional weight out back helps a lot. I spend a lot of time on snow covered and icy roads in the snow belts south of Buffalo... and the Tundra is great.
  3. Nov 30, 2019 at 5:37 PM
    #63
    Scottalator
    Scottalator New Member
    They are AT tires. Well... the 360lbs MADE ALL THE DIFFERENCE.... actually it's probably a little much. I tested spinning out in 2WD on an slightly icy and very mud road this morning and I tested the ABS brakes at speed. It performed exceptionally well. The same road two weeks ago almost put me in the ditch making a 5 mph turn and it wasn't even very wet.
    So I'm pretty happy. That means in 4WD I should be able to go anywhere I could with my '99 Dodge.
    Should I reduce it down from 360lbs? It wallows a little in turns. But the shocks at 145K could be going bad. The truck seems to float a little, but it is the Limited trim and not off road TRD... if that matters.
  4. Nov 30, 2019 at 6:52 PM
    #64
    WNY PAT
    WNY PAT New Member
    Western New York
    I think 240# is plenty personally. Squats the rear down a bit and softens the ride on my Limited TRD. On my SR5, without the lift, it rides pretty soft anyways. The ‘19 is always loaded down with tools and/or a heavy trailer for work. I’ll probably still throw a couple bags of tube sand in there when winter really sets in around here.
