Question on options for carrying a boat with a rack
Discussion in 'Tonneau Covers, Caps and Shells' started by shambo66, Jun 5, 2018.
  1. Jun 5, 2018 at 8:15 AM
    shambo66
    shambo66 [OP] New Member
    Hey All,
    First post!
    I have a 2014 Plat Crewmax. I am trying to figure out what the best option would be for carrying our 12' fibreglass fishing boat while towing our travel trailer.
    It came with a tonneau cover. I'm at a bit of a loss, but we need to bring the boat. Topper with rack and ditch tonneau? Or what?
    Any ideas? Thoughts? Help!
  2. Jun 5, 2018 at 8:22 AM
    BayRunner
    2017 Tundra Platinum
    I have a 12' RIB tender that I bring home to the garage every winter and then put back in the water/bigger boat every spring. I use the Northern Tool trailer for this. Has worked out so far and pulls well at interstate speeds.
    https://www.northerntool.com/shop/tools/product_200596746_200596746
    BTW, welcome. Also you may want to post a n intro post in the introl section and include a pic of your ride.
  3. Jun 5, 2018 at 9:54 AM
    shambo66
    Hey BayRunner!
    Thanks for the welcome. I will do that!
    My issue is that I will be hauling the travel trailer, and so will need to have the boat on the truck somehow.
    Any ideas?
  4. Jun 5, 2018 at 10:43 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4 x 4
    Toytec -Duratrac -Expedition One-Fab Fours
    How much does the boat weigh? I'll put a few hundred pounds on my camper shell roof rack but 12' "fishing boat" may be a little much.
  5. Jun 5, 2018 at 11:06 AM
    shambo66
    It weighs a few hundred for sure. I usually throw it on the old truck's rack and take it off on my own. Damn near kills me but it isn't so heavy I can't handle it solo.
  6. Jun 5, 2018 at 11:14 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I am sure you will find a rack that can handle that, but make sure you take uplift in account - that can cause more problems than the stationary weight of the boat. The way the boat is shaped it will tend to pull it up the faster you go. I have seen a boat rip the rack off a truck's bed and went flying on a highway. Fortunately it went sideways and landed on the side of the road and not in front of other cars.
    Sunnier likes this.
  7. Jun 5, 2018 at 11:42 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    There is always this option
    1UPPER, Outbound and Njmike13 like this.
  8. Jun 5, 2018 at 11:48 AM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    WELCOME
  9. Jun 5, 2018 at 12:25 PM
    BayRunner
    When I had the same dilemma, I mentally designed a roller/rack system where the boat could be winched up a set of rollers/slide boards at a angle from the tailgate to up over the cab. Once the boat was winched all the way up, the be able to winch up the rear end so that it would sit horizontally even to the cab top. Basically a custom rack system for this specific purpose. It could be done, but to do it right would take a lot of work which is why I simply settled on a small trailer.
  10. Jun 5, 2018 at 12:54 PM
    Boerseun
    Ferdie
    Sarasota Florida
    1UPPER likes this.
  11. Jun 5, 2018 at 12:59 PM
    Boerseun
    Ferdie
    Sarasota Florida
  12. Jun 5, 2018 at 3:22 PM
    Professional Hand Model
    Hand Protectors
    The ‘Sanford and Son’ theme song is playing in my mind right now.
    JoshuaA likes this.
  13. Jun 5, 2018 at 3:34 PM
    Over the LINE
    New Orleans
    I don't have a picture of it up there but I haul my layout boat on my rack once in a while. It is about 12-13' long and weighs maybe 100#. If you look I mounted my rack as far back on my camper shell as I could. I did this so I could load long items by leaning them on the rack and sliding them up without tearing up the rear edge of my shell. I always haul small boats upright so they don't turn into a parachute going down the highway. My rack is through bolted with good sized backing plates.
