Question - OEM CrewMax Running Boards / Step Assist parts.
Discussion in 'General Tundra Discussion' started by PermaFrost, Dec 30, 2017.
  1. Dec 30, 2017 at 2:56 PM
    PermaFrost
    PermaFrost [OP] New Member
    Washington
    2017 CM MGM SR5 TRD
    Should have just bought the Platinum!
    First mod / addition to my new 2017 CM. Wanting to add some of the OEM style step assist / running boards.
    *Question - can anyone confirm if the OEM boards in the pics below mount up directly to the undercarriage using the holes / bolts in the attached pics? Seems like (from the pics I've found online and attempting to match up the exploded view parts list) that they do but I'd like to confirm as I don't want to have to drill anything if it's not necessary to mount them.
    Thanks!
  2. Dec 30, 2017 at 3:40 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Yes those are the mounting points for the running boards. I had started out with a pair of Westin side steps and then replaced them with a take off set of the oem running boards you are looking at and both sets used these mounting points
    Black Wolf and MotoTundra like this.
  3. Dec 30, 2017 at 3:55 PM
    PermaFrost
    Washington
    2017 CM MGM SR5 TRD
    Awesome. Thanks man. Did your Westin's use the front inner bolt? My truck purchased with no boards on them from the factory is missing that front inner bolt on both sides.
  4. Jan 3, 2018 at 8:49 PM
    Tundra Bob
    Tundra Bob New Member
    Bob
    Western PA
    2018 Tundra SR5 Doublecab MGM 4x4
    Havoc HS3 Polished Hoop Steps , bed liner , bed rails, mud flaps , all weather mats
    My 2018 was missing 1 front mounting bolt on each side too .
    Bob
  5. Jan 4, 2018 at 11:05 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    @PermaFrost and @thomasbus337 do you have the part number for the complete set of OEM style running boards? I saw your photo with the part number for the Cover but didn't see anything for the full set. Thanks in advance.
  6. Jan 4, 2018 at 7:40 PM
    PermaFrost
    Washington
    2017 CM MGM SR5 TRD
    Thanks for confirming that @Tundra Bob :thumbsup:
  7. Jan 4, 2018 at 7:51 PM
    PermaFrost
    Washington
    2017 CM MGM SR5 TRD
    @757TUNDRA - I could be wrong but I don't think there is a part number for the whole set of parts needed to create the full OEM running board. I believe there are only numbers for the individual parts shown in the exploded view. If there is one number that encompasses all the parts I haven't been able to find it or heard of it referenced in this forum. @Roman - can you confirm? Thanks! :)
    757TUNDRA[QUOTED] and Roman like this.
  8. Jan 5, 2018 at 7:50 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    That is correct. Since they're not sold as an accessory, they do not come in a comprehensive kit with one part number. Everything is sold individually.
    757TUNDRA likes this.
  9. Jan 5, 2018 at 8:21 AM
    757TUNDRA
    Illinois
    Thanks. That's what I suspected but thought I would ask since I've seen a lot of new '18s with these.
  10. Jan 5, 2018 at 8:00 PM
    PermaFrost
    Washington
    2017 CM MGM SR5 TRD
    Thanks! :thumbsup:
    Roman[QUOTED] likes this.
  11. Feb 2, 2019 at 6:12 PM
    GoIrish16
    GoIrish16 New Member
    Gettysburg, PA
    2018 CM 5.7L TRD Sport
    TRD Air Filter, TRD dual exhaust, Toyota Tri-fold tonneau cover
    Does anyone have the PN or the size of the missing bolts at the front most mounting location?
  12. Jun 19, 2020 at 2:58 PM
    Balrz
    Balrz New Member
    Ryu
    New 2020 Tundra crewmax off-road premium
    Hey what’s the length of your boards?
  13. Jun 19, 2020 at 7:10 PM
    PermaFrost
    Washington
    2017 CM MGM SR5 TRD
    They are 92" long.
