Question for those with Demello rock sliders
Discussion in '2.5 Gen Tundras (2014-2021)' started by bradleykd, Jan 9, 2020.
  1. Jan 11, 2020 at 1:38 AM
    Maadcaap
    Maadcaap White Tundys
    Rancho Cucamonga, Ca.
    2019 Trd Pro
    275/70/18 KO2
    I installed Demello hybrid sliders today.. Drivers side rear was supposed to get an 8mm bolt that threads in.. My truck has a hole in the frame but its not threaded... 2019 CM
    anyone else experience this?
  2. Jan 11, 2020 at 1:55 AM
    bradleykd
    bradleykd [OP] New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    Mine 2016 is threaded. It is a nut welded onto the back of the hole, so it doesn't look threaded unless you are completely underneath. If you don't have the nut there, you can get an 8mm nut almost anywhere. I'd get a nylock nut or use a lock washer with it.
    Maadcaap[QUOTED] likes this.
  3. Feb 24, 2020 at 2:49 PM
    kevine0001
    kevine0001 New Member
    Kevin
    thanks for the pics. I was suppose to weld my own several months ago but got busy with hunting season. Mine will be the same as the demello's, 2x2 square tubing. looking at the closeups, any reason not to put a flap wheel to those welds and re-paint?
    Pinay, thanks again for the slider pics (like 6 months ago!) I promise, i'll post pics once they're done
