Question for the electricians
Discussion in 'Home Improvement' started by Danimal86, May 24, 2023.
  1. May 24, 2023 at 4:54 PM
    Danimal86
    Danimal86 [OP] Looks clean even when its dirty!
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I'm installing a high pressure mister pump in my outdoor kitchen. And am thinking about a way to wire it up to a switch, so that god forbid i have to open the door and bend down to flick the switch on the pump.
    This outlet is in the middle of an outlet string.
    Z6rNFuAX8L8X6xocN0rGnjhZ6FEpR34pKAeMRwTM_b3f244058d5d2dc1492bbf6c665a2fc868431194.jpg
    Is it possible to wire in something like this, so that the switch would power the pump, the outlet below the switch would still work, and wouldn't interrupt the string of outlets?
    https://www.lowes.com/pd/Eaton-Whit...sidential-Commercial-Switch-Outlet/1001464104
    The pump has a regular 110 plug, i was thinking if i could just get a female cord and wire it to the back of the switch and plug in the pump.
    Is this possible or am i trying to burn down my house by thinking i can make this work? I'm open to more solutions to my first world problem ;)
  2. May 24, 2023 at 5:22 PM
    @FlyingWolfe don't you run electrical wiring if I remember correctly?
  3. May 24, 2023 at 5:30 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
  4. May 24, 2023 at 6:11 PM
    FlyingWolfe[QUOTED] likes this.
  5. May 24, 2023 at 6:17 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    What’s the amp rating on that pump? Most that I looked up via the Googles are around 10-12 amps, so I’d be worried about running anything else on that circuit.
    FrenchToasty, Mater and BlueRibbon4x4 like this.
  6. May 24, 2023 at 6:20 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I would wire that switch to another outlet inside the cabinet, and plug the pump into that. After making sure your amperage ratings are safe. Especially if those exterior outlets are on the same circuit as your garage or other exterior outlets.
    FrenchToasty, Mater and TRDFerguson like this.
  7. May 24, 2023 at 6:31 PM
    Brums
    Brums New Member
    Bethel, OH
    22 Tundra DC TRD Sport
  8. May 24, 2023 at 6:42 PM
    Danimal86
    Daniel
    Sacramento, CA
    10 amps I believe. Only other thing on that circuit is a small beverage fridge.
    It's on a 20a circuit
  9. May 24, 2023 at 6:46 PM
    Danimal86
    Daniel
    Sacramento, CA
    Nothing else on the circuit other than a beverage fridge.
    The outdoor kitchen is on a 20a circuit
    I'd also be fine just having a single switch that turns on the pump without an outlet, just need to make sure power still goes to the other outlets
    BlueRibbon4x4[QUOTED] likes this.
  10. May 24, 2023 at 6:53 PM
    Danimal86
    Daniel
    Sacramento, CA
    So I would connect the pump to the load side of the switch, and then use the same neutral and ground for the pump on the switch?
    I'm not sure how to connect the downstream outlet.
  11. May 24, 2023 at 7:07 PM
    Danimal86
    Daniel
    Sacramento, CA
    Alright, I think this makes sense now.
    What you guys think?
    I'll just wire nut the lines together and have some jumpers coming off
  12. May 24, 2023 at 7:28 PM
    Brums
    Brums New Member
    Bethel, OH
  13. May 24, 2023 at 7:53 PM
    Danimal86
    Daniel
    Sacramento, CA
    Thanks. I'll give it a go tomorrow and let ya know how it goes!
    Brums[QUOTED] likes this.
  14. May 24, 2023 at 7:55 PM
    Brums
    Brums New Member
    Bethel, OH
    just remember to be safe and turn the power off!
  15. May 24, 2023 at 8:03 PM
    Danimal86
    Daniel
    Sacramento, CA
    I always do.
  16. May 25, 2023 at 7:40 PM
    Danimal86
    Daniel
    Sacramento, CA
    This worked perfect.
    Got everything wired up this afternoon. I used wago's and was an absolute bitch to get it buttoned up. Thanks again for your help with the wiring diagram.
