Question for the cord cutters - digital antenna?
Discussion in 'Off-Topic Discussion' started by ToyotaTundraMike, Apr 28, 2020.
  1. Apr 28, 2020 at 4:58 PM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    Finally tired of getting screwed by Xfinity so we cancelled cable and now use them for only internet and phone.
    I hung an outdoor antenna to receive local channels. I’m aware that a lot of people run these directly to the TV, but I’d like to use the same antenna for all 4 TVs in the house so I plan to run it to the box outside where my internet comes in at currently.
    The problem is there is only one “in” on the splitter outside so I need a way to have the antenna AND the internet coax both going into this input.
    Is this adapter all that I need?
  2. Apr 28, 2020 at 5:08 PM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    I'm no expert, based on my own experience, the XFinity line will be powered and your OTA antenna may be powered as well to a different voltage. I would disconnect the Xfinity line and run a single home run from outside to your modem/router. Then hook the OTA antenna up to the splitter outside and no more issues.
    The splitter you showed is for Direct TV/Dish TV, and the two antennas run on different frequencies and filter out through their splitter.
    ToyotaTundraMike[OP] likes this.
  3. Apr 28, 2020 at 5:25 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I have a hd homerun since my antenna is near my router. Works great; especially if you have an Apple TV. I use it with a firestick and find the channels app works a little more smoothly than the hd homerun app. Best part..no need to run wires and I can watch it on an iPad, laptop, or tv. The new version I believe has a Dvr built into it to if you hook a hard drive up to it. Pretty slick.
  4. Apr 28, 2020 at 5:54 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
  5. Apr 28, 2020 at 5:54 PM
    thearborbarber
    SoDak
    2018 Tundra SR5
    Also keep your cable runs as short as you can.
  6. Apr 28, 2020 at 7:24 PM
    biebs96
    PA
    I use an amplified flexible wall mounted antenna in my garage for the tv. Works great for my football needs and local weather in the morning.
