Question about sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Sep 8, 2019.
  1. Sep 8, 2019 at 2:33 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    06ADAC48-D2E2-408B-87AB-C90D6AE17129.jpg Would a sway bar make a stiffer ride, (not sure if I have a sway bar) is there different sizes available. Please help
    For 2015 Tundra 1794
    Rica25 and Rob's Inferno like this.
  2. Sep 8, 2019 at 3:00 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    All trucks have a front swaybar,some have a rear if it was ordered with it or added later.Normally rear has none,except on the the current sport model.As for the ride it will stiffen it up some yes.I have the TRD bars front and rear and love it.
  3. Sep 8, 2019 at 6:25 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    It will help with body roll and should handle better cornering. On the flat or running straight it is in balance. It will add a little to stiffness but not a lot. It stiffens up and down motion from side to side.
    15whtrd and YardBird like this.
  4. Sep 9, 2019 at 7:13 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    This. Personally, while I did like the increased handling capabilities of adding the rear TRD bar I did not care for the increased ride stiffness, even if it was slight, so I removed the bar. My experience.
    flinky14 and TTund16 like this.
  5. Sep 9, 2019 at 7:18 AM
    15whtrd
    15whtrd Mr. Blonde
    I didn’t feel that the rear end got any stiffer after my swaybar. Only in the corners do I notice how much more stable the truck feels. Plus polyurethane bushings in the leaf springs helped smooth everything out.
    Rex Kramer, Trooper2, Rica25 and 3 others like this.
  6. Sep 9, 2019 at 7:29 AM
    15whtrd
    15whtrd Mr. Blonde
    Another benefit to adding a rear sway bar, is my front tires wear so much more evenly. Before the sway bar the outer edges of the front tires were feathering pretty heavily, even with extra air pressure. The swaybar reduced that greatly.
    Pudge, Kerch71, JoshuaA and 1 other person like this.
  7. Sep 9, 2019 at 7:30 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I don't believe the rear bar stiffens the ride, but it does make it more responsive to driver input by making the rear end feel as though it is connected to the rest of the truck. Before I installed my rear bar, the rear end always felt like it was taking a different path to get where I was going.
    Rica25, YardBird and 15whtrd like this.
  8. Sep 9, 2019 at 7:47 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    TRD RSB will work with 3" lift, you may need to attach it behind instead of below the axle. Heck, trayday mounted it above on a 7" lift, and jberry318 has explained it doesn't matter the mount, it'll still work.
    https://www.tundras.com/threads/sway-bar-and-lift-kits.16843/
    Whatever the case, I noticed no added stiffness, rather a really nicer ride not feeling my shoulders rock side to side as much on turns.
    Pudge likes this.
  9. Sep 9, 2019 at 7:54 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Optional, you have an existing FSB, whereas the TRD front one is heavier and thicker. Adding that too people have reported you really feel planted but there's a bit more stiffness and jarred bumps.
    That said, those who offroad and want to flex often prefer no sway bars at all.
  10. Sep 14, 2019 at 5:20 AM
    Eric32444
    Eric32444 "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    sway bar is a must...not stiffer, just less rolley polley in the turns....
    Rica25 likes this.
  11. Sep 14, 2019 at 5:35 AM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    This is the best response. It’s a must have mod. Ride stiffness is the same but the body roll on turns is no longer there.
    Rica25 likes this.
  12. Sep 14, 2019 at 5:39 AM
    Take it on the highway at 85 and do a quick lane change and then install it and do the same thing. You will feel the difference.
    Eric32444 and Rica25 like this.
  13. Sep 14, 2019 at 6:55 AM
    Taofouajarodeve
    Taofouajarodeve New Member
    Tao
    2021 Voo Doo Blue Crewmax
    None
    Please put sway bars on. It’s night and day with handling and body roll. I don’t off-road and my truck is on pavement 90% of the time.
    Eric32444 likes this.
  14. Sep 14, 2019 at 7:15 AM
    ZeRussian
    ‘11 CrewMax
    As a previous Ram owner (don't hate, it was a cash purchase so I didn't have to have a payment) going to a Tundra I was surprised by the body roll and I am still baffled why Tundras don't come stock with a sway bar like most other trucks.
  15. Sep 14, 2019 at 7:25 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I suspect I know the answer already based on the last few comments but is this mod also recommended if you plan to do some towing? I assume it will make your truck more stable (and maybe even reduce sag if towing heavy?) but I figured I would double check with the experts.
  16. Sep 14, 2019 at 8:04 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    You're overall driving experience while towing or not, will be greatly improved along with your confidence driving it all together...do it and smile more...
    Eric32444 and Cpl_Punishment like this.
  17. Sep 14, 2019 at 8:11 AM
    ZeRussian
    ‘11 CrewMax
    Cpl_Punishment likes this.
  18. Sep 14, 2019 at 8:41 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That's a brave cameraman...
    I would have liked to see their front and rear systems both set to the tight setting.
  19. Sep 15, 2019 at 4:05 AM
    Trdpro Chadwick
    Trdpro Chadwick New Member
    Parkersburg, W(by god)V
    15 TRD Pro Inferno CM
    35/12.5/18
    The sequoia TRD front sway: if I understand correctly; will fit on tundra?
  20. Oct 9, 2019 at 10:29 PM
    rds95991
    rds95991 New Member
    2018 Super White Tundra CrewMax SR5 TRD
    I upgraded my front sway bar and added a TRD rear sway bar. I notice going over speed bumps that I feel it more. Primarily got it for towing.
    TTund16 likes this.
  21. Oct 10, 2019 at 4:30 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Yes.
  22. Oct 10, 2019 at 5:47 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Look under the rear and see if there is a sway bar. I'm no expert but wouldn't a 3" lift make the ride stiffer?
  23. Oct 10, 2019 at 10:24 AM
    CLowery
    CLowery New Member
    Bates City, MO
    2018 Cement Tundra TRD
    None (yet)
    I towed the racecar 1 time before I added my HELLWIG rear swaybar. If you plan on towing the swaybar is a must add. A lot better towing experience after I added the swaybar. The ride difference between with and without is very minimal.
    I've been considering adding rear air bags to level the truck out when towing. I think the AIRLIFT bags are less than $300.
