Question about front shock/strut installation
Discussion in 'Suspension' started by a522467, Mar 28, 2022.
  1. Mar 31, 2022 at 9:45 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    it wasn't that difficult for me, just put a wrench on it, then another one on that wrench and I was able to break it loose pretty easily
    Rodtheviking likes this.
  2. Mar 31, 2022 at 9:46 AM
    joseph_womack
    Joe
    Louisiana
    I followed this video:
    https://www.youtube.com/watch?v=Cu-xZMbj40E&t=216s
    AggiePhil[QUOTED] likes this.
  3. Mar 31, 2022 at 10:08 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    A right angle impact could fit at least on one end, if you have a deep and a normal socket + a couple different size extensions you can get it to the right length so you can maneuver it around lines and cables.
    Pistol style wrench will not fit.
    joseph_womack likes this.
  4. Mar 31, 2022 at 10:19 AM
    2mchfun
    Put the box end 22mm's on each end with one rotated to hit a solid spot or tied with a rope. Slip another big box end of a different combo wrench around the open end of the one free movement 22mm. Basically chain 2 wrenches together if you will and give it all you can. I use wrenches linked all the time to multiply force and it works great 99.9% of the time.
  5. Mar 31, 2022 at 11:19 AM
    SouthWestGA
    SouthWestGA New Member
    That’s what I did yesterday
  6. Mar 31, 2022 at 11:30 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Used a 1/2” ratchet with a 22 on the bolt side, and used an adjustable on the nut side when I broke mine loose.
    You’ll have more clearance breaking it on the bolt side vs nut side since you’re dealing with quite a few hard lines…
    joseph_womack and AggiePhil like this.
  7. Jul 10, 2022 at 6:29 AM
    Pines2007
    Pines2007 New Member
    2007 Tundra SR5
    I just replaced my front struts but now the 4 wheel won't work. Did I mess something up?
  8. Jul 10, 2022 at 6:58 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    That's a bummer, sorry to hear. A simple shock change out shouldn't affect the axle/ 4WD system as long as those weren't damaged when you had your emergency breakdown.
    When you say the 4WD isn't working, you mean that the truck is flashing like it's trying to go into 4WD, but it won't engage permanently? How often would you use 4WD before this situation happened? When the 4WD system isn't regularly exercised or you haven't used it in awhile, it may be tough to get into 4WD. When that happens, some people have been able to give the actuators on the front differential and transfer case a few taps to get them working again.
    This also might be worth reading...
  9. Jul 10, 2022 at 12:18 PM
    Pines2007
    2007 Tundra SR5
    Thanks I will try that
