Question about brake lines after Coachbuilder +3 shackles and longer rear shocks
Discussion in '2.5 Gen Tundras (2014-2021)' started by BamatundraSC, Jan 20, 2023.
  1. Jan 20, 2023 at 8:42 PM
    BamatundraSC
    BamatundraSC [OP] New Member
    Greer, SC
    2021 SR5 CM
    TRD Pro grille, color matched hood bulge, TRD Pro headlights, color matched front bumper end caps, Rough Country two inch loaded front struts, Matte black SCS Ray10’s, Cooper Rugged Trek 275/70/18, Rough Country tri fold hard bed cover, Dirty deeds 12” exhaust
    I posted this over on the suspension page with no response so I thought I’d try it here..
    Had shackles and Rough Country N3 (0-3.5” lift) shocks installed Thirsday. The local shop said they didn’t bolt the line back to the factory location because they were afraid that it would put too much tension on the line.
    Has anyone else experienced this? Did you buy longer brake lines, drop bracket etc.?
    Thanks
  2. Jan 20, 2023 at 10:00 PM
    Caveman
    Caveman New Member
    773_eddie likes this.
  3. Jan 21, 2023 at 5:27 AM
    BamatundraSC
    Greer, SC
    2021 SR5 CM
    Thanks for the info! I ordered the kit last night.
  4. Jan 21, 2023 at 7:55 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    There are 2 soft lines that go above the rear diff that you can replace for longer steel braided ones. Lift your rear end with jacks and let it full droop to see if you need it.
    BamatundraSC[OP] likes this.
