Question about an interior loose screw on my lower-front console box (link and pics)
Discussion in '2nd Gen Tundras (2007-2013)' started by dkmdkm, Mar 30, 2021.
  1. Mar 30, 2021 at 8:34 AM
    dkmdkm
    dkmdkm [OP] New Member
    I recently bought my 2007 Tundra (TRD Limited) and my wife noticed that the front end of the console box has a loose screw. It's a plastic interior screw, and I tried screwing it back in, but it isn't catching. I felt behind the panel and it may be that the screw broke off while threaded in, as if someone tried to just pull it out, rather than unscrew it. The screw in question is part number 58811D, shown here:
    https://parts.crowntoyota.com/a/Toy...6718123/CONSOLE-BOX--BRACKET/841430-5855.html
    So, my question is how would I go about tackling this? Any tips, advice or direction on how to remove a plastic screw with the head broken off? Pic is also attached. The screw is the lower front under the dash.
    Thanks for any help!
  2. Mar 30, 2021 at 7:28 PM
    idiggplants
    idiggplants New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels tonneau cover ditch lights
    It's a plastic rivet type screw, or "push retainer".
    https://www.amazon.com/dp/B00E0J07V4/ref=cm_sw_r_cp_apa_glc_fabc_1MGCSK2N0W9MWW1VW6EW
    Similar to one of these.
    They don't quite "catch"... And they are also a bit difficult to remove. Sort of have to unscrew with a Phillips as you pry it out with a flat tip.
    But to be honest it's likely the way it's supposed to be. Unless it's been pulled out and put in a few times recently, in which case it may be broke, or worn out. At which point I'd suggest you get one of the kits with all sizes of push rivets and pick the biggest one that fits.
    Wynnded likes this.
  3. Mar 31, 2021 at 8:11 AM
    dkmdkm
    Thanks for the reply. I thought they just unscrewed, but I learned how to pop them out. After removing it I saw that the clip was not broken, so I felt the hole it goes into and it feels like one area of it has broken off, so there isn't anything for the clip to attach to/catch the clip. Bummer.
  4. Mar 31, 2021 at 8:22 AM
    idiggplants
    PA
    2013 DC 4wd
    might be able to just toss a washer on there before the plastic push rivet. or you might be able to find a push pin with a larger diameter head.
  5. Apr 1, 2021 at 6:49 PM
    turn005
    turn005 New Member
    Same thing happened to me. I used a zip tie to hold it since the screw hole was broken. I could have moved the molding a bit to drill a new hole but you can’t really see it.
