Question about 4x4 with lift
Discussion in 'General Tundra Discussion' started by DM 2018 Tundra, Jun 11, 2019.
  1. Jun 11, 2019 at 3:02 PM
    DM 2018 Tundra
    DM 2018 Tundra [OP] New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    1 st off sorry if this is normal. To all I have 18 with 6 inch lift. I have never put it until today. I had to get a trailer in the very back of my yard. Due to the heavy rain we I read how the 4 wheel should in gage. So I was rolling very very slow and the 4 high flashed 2 times then I heard it and felt it in my pedals. Is this normal? Also as I was pulling up a steep hill I could hear it popping. All this as I was going forward. Thank for any help on this.
  2. Jun 11, 2019 at 3:12 PM
    koditten
    Kirk
    Midland of the Mitten
    I'm guessing you were spinning the wheels.
    I bet what you heard was the ABS cycling the brakes against the spinning wheel. This is normal.
  3. Jun 11, 2019 at 3:15 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    No spending. Left front side hub. It sounds like. Do you think that it was wanting to spend and made that noise. Only does it when Iam got toured seems like. Does not do it on level ground. Thanks again for the help
  4. Jun 11, 2019 at 3:16 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Nothing came on.
  5. Jun 11, 2019 at 3:17 PM
    15whtrd
    15whtrd Mr. Blonde
    Just so we’re clear, to put the truck in 4 x 4 high it needs to be in drive, preferably rolling straight. 4 low needs to be in neutral.If the light was blinking and you turned or hit the gas before it stopped blinking it might make a few noises. It is normal to feel the clunk of it going in and out of 4 x 4
  6. Jun 11, 2019 at 3:22 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    I think so. What I have read in the manuel.
  7. Jun 11, 2019 at 3:45 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    So do I need to take it to the shop?
  8. Jun 11, 2019 at 4:54 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I'm not sure what the problem is. But when I put mine in 4wd high rolling approx 35 mph, The transition is butter smooth including going back to 2wd high. No noises.
    If you have some abnormal noises, I would take it in..Or investigate further..
