Qi charging
Discussion in '2.5 Gen Tundras (2014-2021)' started by cpatts9747, Feb 14, 2019.
  1. Feb 14, 2019 at 2:40 PM
    cpatts9747
    cpatts9747 [OP] New Member
    Corey
    15 tundra sr5
    Has anyone figured out a good way to make this indent in the dash a charger? This is what I came up with and the wire bugs the crap out of me!
    040Tundra likes this.
  2. Feb 14, 2019 at 2:54 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Could always just make the center console the charger instead. Several DIY posts here about it.
    Tierhog likes this.
  3. Feb 14, 2019 at 3:06 PM
    cpatts9747
    Corey
    15 tundra sr5
    I have a fold down center bench seat. If I had the console in the center of be all over that!
    040Tundra and Sas[QUOTED] like this.
  4. Feb 14, 2019 at 3:08 PM
    What about finding longer wire run top of dash by window run down kick panel behind all carpet to charger???
  5. Feb 14, 2019 at 3:13 PM
    cpatts9747
    Corey
    15 tundra sr5
    I could sure do that. I'd need a USB coupling of some sorts. Then an 8' USB or something along those lines.
    But if I could hide it under the dash and just put the phone on the dash of rather do that. But I don't no how thick the dash is. And I don't no how much those qi chargers can project through.
  6. Feb 14, 2019 at 4:33 PM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    BD Squadron Sport Amber WC Fogs
    If you take the little rubbery insert off (mine pops off anytime it's bumped) there are two small holes where it is supposed to snap in.
    You could probably hardwire in a power cord and run it inside the dash and up through that point. Might have to drill a small hole to run it through.
    Or hell, if you're hardwiring a power cord up there, why not modify the center console mod to fit that spot and use the same process to mount a wireless charging base into that indentation?
    I'm not brave enough in my mod skills to undertake something like that. I haven't even convinced myself I can handle what most here consider simple wiring projects. But, I've got faith that you can do it.
  7. Feb 14, 2019 at 4:35 PM
    Why not pop the speaker grill and run the wire down that way and turn the charger around so the wire faces the grille?
  8. Feb 14, 2019 at 4:36 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I think the dash and rubber mat are going to be way too thick to mount a hidden charger. @ARamirez73 suggestion to use a longer cable to route through the dash speaker is probably your best bet to clean that up. Let us know what you end up doing!
  9. Feb 14, 2019 at 4:41 PM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    A drimel could fix that.
    TRDFerguson[QUOTED] likes this.
  10. Feb 14, 2019 at 4:56 PM
    cpatts9747
    Corey
    15 tundra sr5
    Any idea what the under side of the dash looks like? I've found charges made for embedding in end tables (see link) seems like it would work great if it's flat enough
    10W/7.5w/5w Wireless Charger Qi Charging Pad Ultra Slim Universal Newest Model Compatible with iPhone X iPhone 8 Plus iPhone 8 Samsung Galaxy S9 S8+ S8 S7 S7edge S6 All Qi Devices (White) https://www.amazon.com/dp/B07K5RSSS1/ref=cm_sw_r_cp_api_i_a2GzCbM5A60JA
  11. Feb 14, 2019 at 4:59 PM
    cpatts9747
    Corey
    15 tundra sr5
  12. Feb 14, 2019 at 5:19 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Underneath the HU where the USB panel is, that'll pop out with a pry tool. Then remove the screws, and pull out the HU, you don't need to disconnect the harnesses. Place the HU on a towel. Flip your charger around, take the OEM tray off the dash and tunnel the wire through at the windshield side. If you need to make the hole bigger, it won't be visible anyway as it's in the front of tray and underneath it. How you want to wire the other end, behind or in front of where the USB panel, is up to you.
    Or, you could just do the wireless center console hack
    https://www.tundras.com/threads/wireless-charger-in-center-console-diy-2014-tundra.18365/
  13. Feb 14, 2019 at 5:30 PM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
  14. Feb 23, 2019 at 10:01 AM
    cpatts9747
    Corey
    15 tundra sr5
    So I had some time today got the dash ripped apart. It's completely flat up there. So I ripped apart the qi charger I had for ontop of the dash and epoxied the coil right to the dash above the radio. Added a usb plug under the dash and buttoned it back up. That top indent is now a fast charger qi charger.
    I would have don't the console mount one if I had one. I have the front bench seat so I needed something different
    ardnutoz, Hondoman and TRDFerguson like this.
  15. Feb 23, 2019 at 10:37 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    did you take pics of your install?
  16. Feb 23, 2019 at 10:50 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Unless I'm on a long drive, I rarely use my wireless charger. I prefer quick wired USB-C high output cigar charger.
  17. Feb 23, 2019 at 10:57 AM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    OP, where did u get that specific charger?
  18. Feb 23, 2019 at 11:25 AM
    cpatts9747
    Corey
    15 tundra sr5
    It's an Amazon buy. I'll find the link in a few minutes
    TRD-tv[QUOTED] likes this.
  19. Feb 23, 2019 at 11:27 AM
    cpatts9747
    Corey
    15 tundra sr5
    Unfortunately there isn't much to see I covered it all with Electrical tape as a back up
    That's the charger I gutted to install it
  20. Feb 23, 2019 at 11:27 AM
    cpatts9747
    Corey
    15 tundra sr5
    TRD-tv likes this.
  21. Feb 23, 2019 at 12:27 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    thanks!
    cpatts9747[OP] likes this.
