Putting 5100's on 166k mile 2006 DC. what else should I do?
Discussion in '1st Gen Tundras (2000-2006)' started by Twisted99, Jul 4, 2020.
  1. Jul 4, 2020 at 8:13 PM
    Twisted99
    Twisted99 [OP] New Member
    2018 Crewmax Platinum 4x4
    None, yet
    My 2006 2wd DC has 166k on it. I'm doing 5100's to level it (+2" front, no change to rear).
    Rack was replaced in 2018.
    Truck is never offroad or used for towing.
    I was thinking about new control arm bushings
    https://www.energysuspensionparts.com/kt03012bk
    Good idea?
    anything else I should do?
    Pinay likes this.
  2. Jul 4, 2020 at 8:14 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Thread moved to 1st gen section. Those members know errything!
  3. Jul 4, 2020 at 8:26 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Welcome to the forum.
    Mileage is not your only concern, your truck is roughly 15 years old.
    Has the timing belt been done? That is job 1
    Voss likes this.
  4. Jul 4, 2020 at 8:31 PM
    Casper421
    In the woods
    06 DC
    You could swap in new oem lower ball joints, uca and lca bushings and upper ball joints.
    Voss likes this.
  5. Jul 4, 2020 at 8:55 PM
    Twisted99
    None, yet
    I should have been more specific:
    Anything else suspension/steering related.
    I negotiated the timing belt be done when I bought the truck in 2018 with 133K on it.
    Salesman: "we'll provide the parts, you pay the labor"
    Me: how much is that?
    Salesman: about $275
    Me: OK
    Service tried to charge me $700. TRIED
    Darkness and Hooptytrix[QUOTED] like this.
  6. Jul 4, 2020 at 9:05 PM
    Twisted99
    None, yet
    Was wondering if I should do the ball joints.
    the link I posted was for the UCA & LCA bushings, which, unless I'm talked out of it, I'm doing them.
  7. Jul 4, 2020 at 9:11 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    If your doing the suspension, install new OEM lower ball joints, inspect the uppers. If they’re good don’t worry about them. Be ready to replace lower control arms/bushings if the alignment cannot be done due to seized eccentric sleeves either.
  8. Jul 4, 2020 at 9:12 PM
    Hooptytrix
    Dirty South
    Sounds good.
    If you're going to lift/level the front then you'll want the extended length sway bar links.
    https://suspensionmaxx.com/product/SMX-122270T
  9. Jul 4, 2020 at 9:18 PM
    Twisted99
    None, yet
    I read something about the sleeves. I should see that when I do the bushings, right?
    I'm doing the work, and don't want any surprises when I take it in to be aligned.
  10. Jul 4, 2020 at 9:19 PM
    Twisted99
    None, yet
    Hooptytrix[QUOTED] likes this.
  11. Jul 4, 2020 at 9:22 PM
    Hooptytrix
    Dirty South
    Since you are doing the work yourself, read the instructions and pay attention to the pics. You don't want to over/under tighten. It's not difficult
  12. Jul 4, 2020 at 9:25 PM
    empty_lord
    05 rollover special
    You’ll have to mess with the alignment cams if you want to know if they’re seized. It’s how you set camber and caster.
  13. Jul 4, 2020 at 9:30 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    If your lower ball joints haven’t been replaced, I’d replace those. Probably the weakest point on our trucks and no point in risking it when they are fairly inexpensive.
    160k miles, the radiator might go bad soon so might consider that. Also fairly inexpensive.
  14. Jul 4, 2020 at 9:31 PM
    Casper421
    In the woods
    06 DC
  15. Jul 4, 2020 at 9:35 PM
    Twisted99
    None, yet
    I'll have to check them just before I'm ready to replace everything, this way if the "alignment" is knocked out, I won't put too many miles on it before it gets done again. I'll mark the cams to get it close
  16. Jul 4, 2020 at 9:40 PM
    Twisted99
    None, yet
    revtune likes this.
  17. Jul 4, 2020 at 10:09 PM
    empty_lord
    05 rollover special
    they're not terrible.. but i'd wait till yours are actually worn.. i replaced my rack and just used the rubber bushings..
    revtune likes this.
  18. Jul 5, 2020 at 9:33 PM
    Twisted99
    None, yet
    Cheapest I've found OE are $132 each, more than double than the most expensive ones on Rock Auto.
    Are OE really that much better?
  19. Jul 5, 2020 at 10:03 PM
    empty_lord
    05 rollover special
    The balljoint design on these trucks Are problematic (look up ball joint failure on 1st gen Tacoma’s, same setup.)
    aftermarkets work ok for stock height. Once your lifted they wear fairly quick and may fail without much warning.
  20. Jul 5, 2020 at 10:05 PM
    empty_lord
    05 rollover special
    You don’t want this to happen. Spending a bit more is worth it for quality upload_2020-7-6_0-5-30.jpg
    Hooptytrix and Voss like this.
  21. Jul 5, 2020 at 10:48 PM
    Twisted99
    None, yet
    i was literally just reading another thread here about OE vs. AM.
    never had an issue with my 2 first gen Taco's. My 2001 had 102K when I bought it and 196k when I sold it.
    I'll stick with OE on the LCA/BJ
  22. Jul 5, 2020 at 10:53 PM
    empty_lord
    05 rollover special
    270k on my 01 tacoma ball joints. I replaced them with moogs. Had dangerous amounts of play within 15k miles.
  23. Jul 6, 2020 at 10:25 AM
    Voss
    Valod
    2003 AC TRD 4x4
    I wouldn’t take a chance with the lower ball joint. Check the pic above. Not a situation you want to be in. Had this happen with a 2000 GS300. Scary
    Hooptytrix likes this.
  24. Jul 6, 2020 at 11:11 AM
    Hooptytrix
    Dirty South
    Well since you are going to be under the truck taking shit apart. Swap the o2 sensors. The upstream units can be a pain, you may have a better chance of getting to them
  25. Jun 13, 2021 at 4:12 PM
    Twisted99
    None, yet
    Finally gong to put the 5100's in next weekend.
    What setting should I use to level it?
    Paperwork with shocks show 2.1" on 4th setting and 2.5" on 5th
    No AAL or shackles in rear.
    06 DC 4x2
  26. Jun 13, 2021 at 7:23 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    recommendations for replacements? Mine are seized...
  27. Jun 13, 2021 at 7:25 PM
    empty_lord
    05 rollover special
    OE is what I use. Loaded up with anti-seize. Then a bi-yearly removal and regrease. Seems to work well.
  28. Jun 14, 2021 at 4:38 AM
    Professional Hand Model
    Hand Protectors
    When you remove these bolts to dope them, does the front end need realignment again? Or can you just keep the same Mojo if careful?
  29. Jun 14, 2021 at 7:58 AM
    empty_lord
    05 rollover special
    Markjing them with paint pen on the indentations keeps it close. But ideally you’d want an alignment
