Put some USB ports in the Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by GNX6, Dec 17, 2017.
  1. Dec 17, 2017 at 3:15 PM
    GNX6
    GNX6 [OP] New Member
    2014 Crewmax
    TRD rear sway bar TRD oil cap (adds 25 HP, It said so online)
    I was reading and looking online about how people put extra charge ports in their vehicles. My truck is the road trip and Trailer hauler so the need for multiple charge points is common. Turned out pretty good. Got both of them for about $25 on Amazon. IMG_2531.jpgIMG_2535.jpg IMG_2534.jpg
  2. Dec 17, 2017 at 3:22 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Turned out great! Are the ones in front just charging ones?
  3. Dec 17, 2017 at 3:50 PM
    GNX6
    2014 Crewmax
    Yes, the front one on the left is just charging, as well as the rear. It has factory usb port for the radio which I have a 32gb stick inserted. The only project left is I wanted to wire the left Aux 12v port in the picture to constant 12v in case I need to power anything while the car is off.
    MotoTundra likes this.
  4. Dec 17, 2017 at 4:42 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Great job @GNX6 .
    I should do something similar, that is a great mod!
    SouthBoundSteve likes this.
  5. Dec 17, 2017 at 4:44 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Can you post the direct link to the one you bought for up front? Does it fit a blank perfectly?
  6. Dec 17, 2017 at 5:38 PM
    GNX6
    2014 Crewmax
    My wife said don't look at Amazon purchase history cause there are gifts in there so give me a few days to figure it out without seeing history.
    To answer the other question yes the front USB charger fit perfectly into factory slot. There are 2 I purchase that looked similar but when they got here it was obvious one was much better than the other.
  7. Dec 17, 2017 at 5:40 PM
    GNX6
    2014 Crewmax
    I also put in a Hardwire kit for my Valentine One radar detector and added the bluetooth module for it.
  8. Dec 17, 2017 at 7:37 PM
    GNX6
    2014 Crewmax
  9. Dec 18, 2017 at 4:15 AM
    MotoTundra
    MotoTundra The Ocho
    Don
  10. Dec 18, 2017 at 5:18 AM
    Berettafan
    Berettafan New Member
    2017 CM
    what is the benefit to this vs a plug in jobber for $5.99?
  11. Dec 18, 2017 at 5:49 AM
    GNX6
    2014 Crewmax
    I've never seen the one on jobber. (Whatever that is)
    Install took about an hour for the rear one. The trick was to place the locking ring on the back panel on the inside to visualize position and so you have enoigh roon to spin it. It's a tight squeeze, luckily it just happened to be centered.
  12. Dec 18, 2017 at 7:08 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    He added ports where there weren't any plugs, etc.
  13. Dec 18, 2017 at 8:36 AM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    Looks great. I may need to do something like this for my truck as we will start traveling in it more and more.
  14. Dec 18, 2017 at 9:38 AM
    GNX6
    2014 Crewmax
    I like being able to have my phone plugged in behind me when I charge the phone so I don't have a mess of wires and adapters all over the car. Plus it looks a lot cleaner. The 2.1A port will keep my son's ipad fully charged while playing movies on road trips and it will charge it up quickly when the power is low. Most of the lighter adapters get really hot when charging at 2A and it is hard to find one that will have 2 ports and not look like the space shuttle sticking out of the lighter.
  15. Dec 19, 2017 at 6:41 AM
    Berettafan
    2017 CM
    Ah didn't catch that when I first read it.
    OP was thinking of these things:
    MotoTundra[QUOTED] likes this.
