PSI recommended for Falken Wildpeak AT3 285/65/18 on stock wheels.
Discussion in 'Wheels & Tires' started by Cl8NL, Mar 18, 2022.
  1. Mar 18, 2022 at 8:23 AM
    Cl8NL
    Cl8NL [OP] Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    Tire shop says keep to what the door jam says….
  2. Mar 18, 2022 at 8:35 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    This is a great tool when switching tires sizes, load ratings. Will get you right in the ballpark and then you can adjust up or down a pound or two based on how you drive, load, etc.
    PermaFrostTRD and Cl8NL[OP] like this.
  3. Mar 18, 2022 at 9:01 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Those are e rated. The door jamb is way too low for stock P rated tires. For e rated with no load in the truck 35 front and 30 rear is a decent start
    14burrito, snivilous and Cl8NL[OP] like this.
  4. Mar 18, 2022 at 9:01 AM
    Cl8NL
    MKE WI
    I was wrong, they do have 285 on there
  5. Mar 18, 2022 at 9:04 AM
    Cl8NL
    MKE WI
    Calculator puts me at ~44
  6. Mar 18, 2022 at 9:09 AM
    frichco228
    Sounds close depending on load rating. I run 275/70-18 E load and 39/40 in front and 40 in back keep tire wear nice and even.
    AZBoatHauler likes this.
  7. Mar 18, 2022 at 9:11 AM
    Cl8NL
    MKE WI
    Sounds really similar to where I’ll be playing around. Thanks for the tool!
  8. Mar 18, 2022 at 9:14 AM
    bflooks
    bflooks New Member
    Metrowest MA
    You can also write to Falken and they'll help you out.
  9. Mar 18, 2022 at 10:38 AM
    Geeoff
    Geeoff New Member
    NH
    2016 CrewMax SR5 TRD
    I have them in 275/70-18 E rated and keep them at 40 psi front and rear. Tire wear has been very even for me so far.
  10. Mar 18, 2022 at 11:26 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Door jamb sticker for the BFG D rated that came on my truck is 44 maybe 46. I ran them closer to 50 with even wear. I got new tires at 70k and could have gone 75.
  11. Mar 18, 2022 at 4:54 PM
    Falken QA
    Falken QA New Member
    @Cl8NL hey there,
    provide us your factory tire size and factory tire pressure so we can adjust it to the new tire size.
    Tom, Hbjeff, Cl8NL[OP] and 1 other person like this.
  12. Mar 18, 2022 at 5:21 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Cold psi?
  13. Mar 18, 2022 at 7:10 PM
    Cl8NL
    MKE WI
    factory was 275/65/18
    thank you much!
  14. Mar 18, 2022 at 9:24 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Up to whatever the side wall says.
  15. Mar 18, 2022 at 9:25 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Definitely don’t wanna do this with an e rated tire on a half ton
  16. Mar 18, 2022 at 9:26 PM
    Joe333x
    Joe333x Member
    Boston
    I'm just saying you can safely inflate up to what the tire says. Not saying it will be the best performance. I keep my stock tires at 35 cold. If i need to air down for off road i do but best mpg and tread wear is higher psi. Definitely not the best ride quality though.
    chugs likes this.
  17. Mar 19, 2022 at 6:12 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Or on a 3/4 ton. 80 lbs would be like rolling on a solid tire. Plus I can't imagine filling with 80 lbs. I run 60 in my boat trailer.
  18. Mar 21, 2022 at 9:02 AM
    Falken QA
    Based on this size, toyota calls for 30 PSI front, 33 PSI rear. As such, the tire supported 2421 lbs of load front, 2535 lbs of load rear.
    To match this load capacity:
    If LT285/65R18 tire size, inflate front to 45 PSI and rear to 49 PSI. Keep in mind this is based on Toyota's load spec with full fuel tank, driver & 4 passengers, etc. This would be your minimum cold street pressure.
    If non-LT size 285/65R18, inflate front tires to 31 PSI and rear tires to 33 PSI.
  19. Mar 21, 2022 at 9:10 AM
    Cl8NL
    MKE WI
    Great, thank you very much
  20. Mar 21, 2022 at 10:25 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Ive run LT tires before on my tundra. 49psi is gonna be stiff AF
    AZBoatHauler and r1-superstar like this.
  21. Mar 21, 2022 at 11:06 AM
    Falken QA
    Tire manufacturers follow vehicle manufacturer air pressure recommendations or if plus sizing, coming close to the load capacity of the OE tire size/load rating(for liability purposes). The air pressures set by the vehicle manufacturer are based on a fully load truck (driver + passengers, full fuel tank, and contents in the bed of the truck).
    However, I would use those pressures as a starting point and tinker with it to get a comfortable ride when not fully loaded.
    Mater, Cl8NL[OP] and r1-superstar like this.
  22. Mar 21, 2022 at 1:52 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I run my 305/65-18s at 30 psi all around. 40+ psi in the rear when I tow/haul.
    Falken QA likes this.
  23. Nov 27, 2022 at 4:04 PM
    manhster
    manhster New Member
    Richmond, VA
    '17 Black CM 4x4 Ltd TRD OR
    Same factory recommendations, what do you recommend for LT275/70R18?
    Thx
  24. Nov 29, 2022 at 12:13 PM
    Falken QA
    For the LT275/70R18 tire size, you'll adjust to
    44 PSI front
    47 PSI rear
    This is based on Toyota's load spec with full tank of fuel, topped off on all fluids, full cab of passengers and any remaining load, from total passenger weight, for payload/cargo.
    Mater likes this.
  25. Dec 3, 2022 at 6:22 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I really like this!!!
    I’d love to hear your input on my current, and future tires…
    OEM was 275/55-20. 30# front, 33# rear.
    Currently, I have LT275/65-20 LRE Cooper Discoverer AT3-XLT. I’ve been running 40# all around, but bump the rears up to 45# when towing the TT. (I try to keep it so that heat generated pressure increase doesn’t exceed 50# and turn my TPMS light on…)
    I will be moving to LT285/75-18 LRE Wildpeaks soon, and am curious about two things.
    What is my ideal pressure with the LT275/65-20 that I have now?
    What should I expect to run when I move to LT285/75-18?
    Thanks!
    Falken QA[QUOTED] likes this.
  26. Dec 4, 2022 at 4:01 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Your TPMS needs to be reset for the larger tires. I had BFG KO2s in a D rated as OEMs and my TPMS will light up in cold weather at PSIs below about 46. The supplemental door sticker on mine is 48. I run all least that. I did not know the TPMS would trigger with too much air.
  27. Dec 4, 2022 at 7:57 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    In my 2018 Platinum, it will read pressures up to 50#, and then give me a TPMS problem message in my message page on dash instead of going to 51# on the monitor screen.
    I appreciate your response, but will wait to hear what @Falken QA has from their algorithm.
  28. Dec 5, 2022 at 11:54 AM
    Falken QA
    So, the factory tire size, P275/55R20, supported
    2249 lbs at 30 PSI front
    2348 lbs at 33 PSI rear.
    I can't comment on Conti's recommendation if they based their adjustment differently, but lets pretend it was one of ours, the LT275/65R20 pressure would be to match the OE tire size load capacity is
    40 PSI front
    42 PSI rear
    As for the LT285/75R18 tire size, you'll adjust to
    35 PSI front
    37 PSI rear
    Keep in mind the pressures are based ETRTO data/inflation chart, with the baseline being the OE tire size and tire pressure. Load is based on the vehicle manufacturer's load capacity, as stated on the door pillar. This typically translate to a full cab of passengers and/or total weight/load, full tank of full, and topped off fluids.
    Chad D.[QUOTED] and AZBoatHauler like this.
  29. Jan 21, 2023 at 5:30 AM
    BigJuelz
    BigJuelz New Member
    2020 Magnetic Gray Platinum
    What pressure for P275/60R20 (OEM 275/55R20)?
    I have 35psi @ room temp, or about 32/33 cold and they look too low.
    2020 platinum
  30. Feb 27, 2023 at 8:15 PM
    vilord
    vilord New Member
    Jesse
    2019 TRD
    If you don't mind, @Falken QA I'd be curious what the recommendation would be for a bigger tire. My 2019DC is listed with P275/65R18 at 30 front/33 rear (so similar to what others posted above)
    Right now I'm running LT295/70R18 load range E (129/126) tires. What would be the right pressure for fully loaded / max towing? Thank you!!!
