PSA $200 off Sema Headlights
Discussion in 'Deals & Group Buys' started by MGMTUNDEE, Mar 20, 2018.
Thread Status:
Not open for further replies.
  1. Mar 21, 2018 at 8:45 PM
    #61
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    You will get it quick though!
    1UPPER, GodlessPro and 831Tun[QUOTED] like this.
  2. Mar 21, 2018 at 8:46 PM
    #62
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm hoping. I'd like to have 'em installed before we go to Death Valley.
    GodlessPro likes this.
  3. Mar 21, 2018 at 11:37 PM
    #63
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    I like these but I'm pretty happy with the 18 LED conversion and ihacker harness.
    I'm curious if the spot above the turn signal is white or where the drl would light up.
    iHacker likes this.
  4. Mar 22, 2018 at 12:05 AM
    #64
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    The spot above turn signal is the LED DRL, I have seen a SEMA video and they showed this truck
  5. Mar 22, 2018 at 9:39 AM
    #65
    BlueBottle
    '16 Platinum 4x4
    See fine print
  6. Mar 22, 2018 at 9:41 AM
    #66
    MGMTUNDEE
    MGMTUNDEE [OP] New Member
    Quacky
    Tampa
    just spent 20 minutes trying to get this video up:rofl:then saw the notification and knew that someone already got it up
  7. Mar 22, 2018 at 9:57 AM
    #67
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Looks like the white strip and amber strip are both park light and the amber is signal also. No real drl on these lights. Sequential signals are kind cool.
  8. Mar 22, 2018 at 9:58 AM
    #68
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I'm pretty sure there's a dick joke in there somewhere.
    Argh, i like these over the spiders, but i found a local set of oem headlights for $80 that i was going to do a retrofit with. I'll probably put around $400 in parts for the retrofit. Hands down i think the light output of the retrofit will be better, but dammit, those look awesome!
    I guess i should wait to see some real output shots.
    831Tun likes this.
  9. Mar 22, 2018 at 10:24 AM
    #69
    Whitewhale
    Whitewhale New Member
    Kyle
    The Berkshires
    16' white limited
    Funny you say that. Kustom54 is working on a pair for the 5th gens. I know it's not for tundra but it's still in the making and they are using them. Words are they are way North of 1k
  10. Mar 22, 2018 at 10:30 AM
    #70
    iHacker
    iHacker SW TRD PRO
    Mario
    Cool, I hope the Hi beam is bright enough because if you see carefully the projectors turn OFF with the Hi beam ON
    BlueBottle[QUOTED] likes this.
  11. Mar 22, 2018 at 10:32 AM
    #71
    iHacker
    iHacker SW TRD PRO
    Mario
    I own a Acura MDX and I measured the light the MDX jewel eye projectors is wide and maybe won’t fit into the TUNDRA headlight
    dcsleeper408, 1UPPER and BlueBottle like this.
  12. Mar 23, 2018 at 11:12 AM
    #72
    MGMTUNDEE
    Quacky
    Tampa
    They added up this post a short second ago, I'm really loving theseScreen Shot 2018-03-23 at 2.11.01 PM.jpg
    Watt maker, epa4wd and iHacker like this.
  13. Mar 23, 2018 at 11:23 AM
    #73
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I agree that the output from D2 4.0 is probably a lot better than these AO lights.
  14. Mar 23, 2018 at 11:25 AM
    #74
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Must be a way to wire it so the projectors don't turn off with high beam. I'm gonna take a wild guess that YOU could figure it out.
    iHacker[QUOTED] likes this.
  15. Mar 23, 2018 at 11:34 AM
    #75
    BlueBottle
    '16 Platinum 4x4
    See fine print
    You can do it with a Motocontrol and changing the plugs to a 9006.
    831Tun[QUOTED] likes this.
  16. Mar 23, 2018 at 11:58 AM
    #76
    epa4wd
    epa4wd New Member
    Ed
    :bananadance:Got a tracking #, delivery estimate Monday!
    MGMTUNDEE[OP] and 831Tun like this.
  17. Mar 23, 2018 at 12:00 PM
    #77
    Danimal86
    Daniel
    Sacramento, CA
    I keep telling myself that, but man, i really like the looks
  18. Mar 23, 2018 at 12:01 PM
    #78
    iHacker
    iHacker SW TRD PRO
    Mario
    It will be awesome if you and @1UPPER @epa4wd post pictures and videos to share your experience and the output at night.
    I think I’m sticking with the OEM option but this is a great option too they look cool!
    1UPPER and 831Tun[QUOTED] like this.
  19. Mar 23, 2018 at 12:10 PM
    #79
    epa4wd
    epa4wd New Member
    Ed
    Will do!
  20. Mar 23, 2018 at 12:19 PM
    #80
    mgh-pa
    mgh-pa Perpetually a New Member.
    2016 Tundra DC SR5
    Man. I have a harness sitting in my garage just waiting for me to pick up '18 headlights and this shows up.
    soarvet, the_midwesterner and 831Tun like this.
  21. Mar 23, 2018 at 12:24 PM
    #81
    iHacker
    iHacker SW TRD PRO
    Mario
    :p
  22. Mar 23, 2018 at 12:40 PM
    #82
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Well, if you like 'em now, you'll probably be able sell 'em later if you change your mind. And, since they're on sale now...... You might justify it by using 'em as your temporary lights while you build your retros.:D Actually, don't get 'em. I don't want anyone else in the BA spotin' the same lights as me.
  23. Mar 23, 2018 at 12:44 PM
    #83
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Hmmm. I have a couple motocontrols and I know this guy that's pretty good with this type of thing..... Can't vouch for his MGM color choice but he's got some BA SCS wheels.:rolleyes:
    GodlessPro, iHacker and dcsleeper408 like this.
  24. Mar 23, 2018 at 1:02 PM
    #84
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Haha you know my number. Get them lights!
  25. Mar 23, 2018 at 1:41 PM
    #85
    DMBfan
    DMBfan 2015 Tundra SR5 CrewMax
    $2400? for fiberglass fender flares? That's one of those accessories that are way over priced just because it looks good. Knock off $1000 and they'd sell a ton of them.
    1UPPER[QUOTED] likes this.
  26. Mar 23, 2018 at 4:29 PM
    #86
    R-C
    R-C http://101financial.com
    Ryan
    Las Vega$
    2017 TRD Pro
    Added to my b-day wish list.
    iHacker and 831Tun like this.
  27. Mar 24, 2018 at 5:37 AM
    #87
    Whitewhale
    Kyle
    The Berkshires
    16' white limited
    No I know they are long, they fit perfect into a 4runner headlight. But they are making them for the 4runners. Idk they look a bit wild for me haha
  28. Mar 24, 2018 at 6:27 AM
    #88
    atxtundra
    atxtundra New Member
    Goodbye retros
  29. Mar 24, 2018 at 6:40 AM
    #89
    mgh-pa
    2016 Tundra DC SR5
    I think I may buy these...need to resist.
  30. Mar 24, 2018 at 11:45 AM
    #90
    X09
    X09 New Member
    San luis obispo ca
    2017 Tundra Crewmax Limited
    Sold out!
    831Tun likes this.
Thread Status:
