Ps3 brake controller
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Mikenins, Oct 19, 2017.
  1. Oct 19, 2017 at 12:44 AM
    Mikenins
    Mikenins [OP] New Member
    Anyone add a ps3 brake controller on 2017
  2. Oct 19, 2017 at 4:05 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I don't have one, but I have only heard good things about the Tekonsha P3 brake controller...
    As far as the PS3 controller, I don't game much...;)
  3. Oct 19, 2017 at 5:24 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I just picked up a P2. We've had them in our trucks at work for a long time. They're predictable and easy to adjust. I like the simplicity.
    The P3 might be great, I've never used one. Stick with Tekonsha either way.
    MotoTundra likes this.
  4. Oct 19, 2017 at 5:54 AM
    MikeyMTBs
    MikeyMTBs New Member
    The P3 is great. I have one on the shelf from my last truck that is about to go into my CM. F the IBC that Toyota put in.
  5. Oct 19, 2017 at 6:01 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I recently put a P3 in my 2nd gen - it has amazed me. I highly recommend it.
  6. Oct 19, 2017 at 8:18 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    I haven't had a chance to use it yet, but i swapped out my IBC w/the Tekansha P3 on my 2016 CM, it took all of 10 mins.
  7. Oct 19, 2017 at 12:45 PM
    CincyCrewMax
    CincyCrewMax New Member
    Cincinnati, OH
    2014 White CrewMax LTD.
    Just installed the P3 in mine with the ESP dash kit. Have not used it yet. LOL
  8. Oct 19, 2017 at 12:47 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I have one on my 2014 and it works very well. The trailer I tow is 9200ish pounds.
  9. Oct 19, 2017 at 1:09 PM
    multimile
    multimile New Member
    2020 Crewmax Cement
    I’ve got one with the ESP kit collecting dust on a shelve since moving from a 14’ to a 17’. Let me know if you’re interested in it.
  10. Oct 19, 2017 at 3:53 PM
    Mikenins
    I have the ps2 brake controller from my 2010 tundra will it work with new truck it's a 2017 5.7 with tow package or do I need a new harness/ brake controller
  11. Oct 19, 2017 at 4:49 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    Best thing I've done to my 16 cm factory one sucked. Put in p3 with esp mount and amazing
    757TUNDRA likes this.
  12. Oct 19, 2017 at 5:32 PM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Same here. The factory IBC was junk, even after the dealer performed the tsb.
  13. Oct 19, 2017 at 6:19 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Again I'm not much help, but you should be able to figure it out by checking www.eTrailer.com, and typing each vehicle info in and selecting the proper equipment.
  14. Oct 29, 2017 at 8:12 PM
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    I’m very happy with this controller. I tow a dump trailer all the time works great!
  15. Oct 29, 2017 at 8:27 PM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    I towed last weekend with the IBC, it was ok, but would not let the family ride with me. I had the TSB done on it. Thinking I may pull it and get a P3.
  16. Jan 3, 2018 at 5:38 PM
    Nomagination
    Nomagination New Member
    2017 SR5 CM
    Is there any warranty voiding issues if I install an aftermarket controller? I can't see how there would be if I'm not cutting wires or anything.
  17. Jan 3, 2018 at 5:52 PM
    757TUNDRA
    Illinois
    No warranty issues at all with installing an aftermarket controller. I've installed them in my last two Toyotas (Tacoma and Tundra) and never had any issues when I took it in for maintenance. I actually had a Toyota dealer help me unscrew the wiring mess my RV dealer did when he initially installed the controller in my Tacoma.
  18. Jan 3, 2018 at 6:02 PM
    Nomagination
    2017 SR5 CM
    Thanks. I think I'll be swapping my factory controller out soon.
  19. Jan 3, 2018 at 6:07 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    Just installed the P3 this past weekend, is it supposed to be powered on all the time or do I have defect? Will it drain my battery? Also I used the Toyota harness for PNP.
  20. Jan 3, 2018 at 6:44 PM
    Scott_sFZJ80
    Scott_sFZJ80 New Member
    2018 CM Platinum
    Nishibot, it typically stays illuminated for a while. It should shut down the display if you let it sit long enough. I thought the same thing last summer after I installed it on my Land Cruiser, but then it does shut down. I love the controller, works great.
  21. Jan 3, 2018 at 6:48 PM
    nishibot
    Perris, CA.
    Thanks for the reply
  22. Jan 5, 2018 at 6:49 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    *Note* I have a Gen 2 - 2013 Tundra with tow package.
    Here's some photos of my P3 install. Maybe this will be useful (or confusing :laughing:) to someone else. PM me if you want more details on how I did this... Basically, I had the factory brake control wire harness in my glove box. So I used that to lengthen the P3 harness so it would reach all the way from under the foot well where the factory brake control harness is (see photo of red square- that is factory connector where you plug-in) to the little cubby with the cig lighters... which is where I mounted the P3. I cut the bracket that came with the P3 to get it to sit farther back. Also cut a hole in the back of the cubby to fit the P3 connector thru.
  23. Nov 24, 2018 at 10:28 AM
    lilharv321
    lilharv321 New Member
    Do you still have this?
