Project Thundra - 9 second, 1000 hp daily driven AWD Tundra build
Discussion in '2nd Gen Builds (2007-2013)' started by ViktorG, Oct 11, 2019.
  1. Jan 30, 2021 at 7:10 AM
    #241
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Vik saw this today on TFL - https://youtu.be/3bPm3qNM0Ng
    There are looking for another truck to go against the new Ram TRX :devil:
    Toyota Tundra V8 SC against Ram V8 SC
    ViktorG[OP] likes this.
  2. Jan 30, 2021 at 11:58 AM
    #242
    ViktorG
    ViktorG [OP] Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I would LOVE to do this, but the damn border will probably be closed for at least another half a year if not more :mad:
    MTRock, dorton and Black@Blue19 like this.
  3. Feb 10, 2021 at 6:36 PM
    #243
    ViktorG
    Viktor
    Calgary, Canada
    saybng, Black Wolf, Warreng and 5 others like this.
  4. Feb 10, 2021 at 7:04 PM
    #244
    Yzed608
    Yzed608 New Member
    Wisconsin
    Nice! I know nothing on the racing rules, would you ever get to the point where you would need a 5 point harness?
  5. Feb 10, 2021 at 7:37 PM
    #245
    TXTundra2722
    2015 Black Tundra
    Yes, there gets a point where if you run too fast you have to have a full cage and all. I don't know what that time is.
  6. Feb 11, 2021 at 7:55 AM
    #246
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    IIRC the time is 11.40 seconds for a 5 point harness and a 6 point roll bar.
  7. Feb 12, 2021 at 4:14 PM
    #247
    ViktorG
    Viktor
    Calgary, Canada
    At my track, you just need a fire jacket for under 11.5 sec
    You don't need a roll cage/harness until 9.99 or 135 mph, I am still quite far away from that (best of 11.4@120 without nitrous)
    Yzed608[QUOTED] and dorton like this.
  8. Feb 14, 2021 at 10:26 AM
    #248
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    ViktorG[QUOTED][OP] and Wynnded like this.
  9. Feb 14, 2021 at 10:58 AM
    #249
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    TX210Tundra and ViktorG[OP] like this.
  10. Feb 14, 2021 at 7:45 PM
    #250
    ViktorG
    Viktor
    Calgary, Canada
    saybng, airosey, Prostar 190 and 8 others like this.
  11. Feb 21, 2021 at 7:45 PM
    #251
    DR132
    DR132 New Member
    ALASKA
    2014 Tundra CM Platinum Blue Ribbon Metallic
    AWD Conversion, BAMuffler 8", Custom tuned with HPTuners, 2018+ LED Headlights, TRD front and rear sway bars
    Hey Viktor and other AWD enthusiasts I figured I would post this here since this is kind of the default "AWD Tundra thread" on this forum...I wanted to let y'all know since I haven't heard of anyone else doing this yet but I just successfully completed an AWD conversion on my 2014 Tundra. I used a LC200/LX570 T-case and swapped out the rear output flange with one from a 2007-2013 Tundra t-case as the Land Cruiser has a much smaller rear flange than our trucks. Going into this I had first determined that the front and rear driveshaft interchange was the same from the 2007-2013 and 2014+ trucks so overall t-case dimensions were expected to be equivalent between the Aisin and Borg-Warner units and as determined in other threads the Land Cruiser and earlier Tundra cases were physically interchangeable with no driveline modifications so I speculated that the Land Cruiser case should then also be a direct bolt in replacement for the Borg-Warner case. Luckily this all proved to be true and the Land Cruiser case easily bolted in place of the Borg-Warner case just like it was meant to go there, the crossmember holes lined up perfectly as well. Electrically there is unfortunately no way that I'm aware of to control the Land Cruiser case so I'm essentially just a straight AWD truck now, which is perfectly fine with me in all honesty. Coming over from the GM world the lack of an AWD option was one of my few major gripes with the Tundra, especially since I'm reminded of it every time I drive my wife's Escalade lol! At this point the only downside is that my 4lo and 4hi lights are flashing so I need to figure out a way to fool the truck into thinking everything is fine. I left the 4wd switch on 4hi and the original encoder motor, front differential actuator plugged in but the Borg-Warner has a pressure sensor/switch and another mystery wire that goes into the case that had to be left unplugged. The important part is that the truck drives great and is AWD! I don't do any off-roading so I don't foresee needing the 4lock feature and I've never put the truck in lo-range except once just to verify that it would. I did a few little traction tests on a snowy hill from a stop in both drive and reverse and the Torsen device did an excellent job of biasing torque and the truck powered up the hill with zero trouble. Doing the same in 2wd was not previously possible. Another plus of this is that since the 4wd switch is always on 4hi traction control is now a simple on-the-fly one button push to turn-off instead of that ridiculous two stage, only possible at a stop procedure like it is in 2wd (my only other notable gripe compared to the competition). I'll make a thread for this once I work the minor electrical kinks out and establish that this should be good to go long term, just wanted to share that AWD in a 2014+ IS possible and is mechanically very straightforward. Cheers!
    Saltyhero13, saybng, Warreng and 7 others like this.
  12. Feb 21, 2021 at 10:50 PM
    #252
    ViktorG
    Viktor
    Calgary, Canada
    Nice work man!
    I’ve had many people reach out to me over the years wanting an AWD conversion done on their 2014+ trucks and I’ve always told them that it shouldn’t be a problem to have full time AWD as long as they are willing to give up the ability to shift into 2HI or 4LO or lock the centre diff.
    Now you have confirmed that it is mostly bolt on, which is great, and I am happy the setup satisfies your needs!
    Please let us know if you can get the electronics figured out, I am sure there would be a lot of guys interested in doing this swap once full functionality is achieved.
    Wynnded and DR132 like this.
  13. Feb 22, 2021 at 12:00 AM
    #253
    DR132
    DR132 New Member
    ALASKA
    I certainly will! I found some wiring diagrams so I'm confident that I can at least get the flashing 4hi/4lo lights to shut off so that the truck just thinks it's in 4hi (which it behaves like as far as I can tell, minus the flashing lights). As for actually controlling the shift actuator on the LC case I don't know if I'll dive into that. Obviously, as you know, the wiring is entirely different between the Aisin cases and Borg-Warner. I'm sure someone more knowledgeable with electronics than me could probably rig up an auxiliary system to run the shift motors with limit switches and make it work pretty easily...I might be able to muddle my way through it but it would be a bit of an endeavor for me I think lol!
    ViktorG[QUOTED][OP] likes this.
  14. Feb 22, 2021 at 4:01 AM
    #254
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's very cool! Well researched and well done! I also look forward to reading the write-up. I would speculate that the center differential would be relatively straightforward to figure out, but I could be wrong. With the LC T-case, were you able to collect the LC 4WD ECU? That could be of use. It'd be nifty if a custom harness was all that would be needed to sort the lights and the ability to access 4LO/differential lock...
    DR132 and ViktorG[OP] like this.
  15. Feb 22, 2021 at 8:36 PM
    #255
    DR132
    DR132 New Member
    ALASKA
    Unfortunately no I wasn't. I haven't found a relevant wiring diagram for the LC yet but I found some for the Borg-Warner case that I took out and it looks like a relatively simple system for a modern rig. The Aisin case actuator is just a couple motors driving a gear set to move the shift rods so if nothing else an auxiliary system could probably be wired in to run the motors.
  16. Feb 23, 2021 at 3:56 AM
    #256
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm sure the wiring diagram is out there somewhere, it's just a matter of time before you stumble across it. What you've done is groundbreaking though regardless. It'll be interesting to read the journey.
  17. Feb 23, 2021 at 1:18 PM
    #257
    ViktorG
    Viktor
    Calgary, Canada
    Attached is the 4WD diagram for the LX570/Landcruiser
  18. Feb 23, 2021 at 5:03 PM
    #258
    DR132
    DR132 New Member
    ALASKA
    You're a hero Viktor!
  19. Mar 2, 2021 at 11:46 PM
    #259
    ViktorG
    Viktor
    Calgary, Canada
  20. Mar 10, 2021 at 11:57 AM
    #260
    ViktorG
    Viktor
    Calgary, Canada
  21. Mar 29, 2021 at 11:53 PM
    #261
    ViktorG
    Viktor
    Calgary, Canada
    After my recent tune!
  22. Mar 30, 2021 at 3:46 AM
    #262
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    Insane... what were the final dyno numbers? And was the dyno done in AWD?
  23. Mar 30, 2021 at 4:01 AM
    #263
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  24. Mar 30, 2021 at 4:10 AM
    #264
    mtb-sam
    mtb-sam New Member
    Man im impressed! wow
    Bo-Hunter and ViktorG[OP] like this.
  25. Mar 30, 2021 at 6:53 AM
    #265
    omgboost
    East Coast
    Dyno appears to be done in RWD in the video
  26. Mar 30, 2021 at 6:59 AM
    #266
    Djone27
    Djone27 New Member
    Thank you, I caught that when I watched the video again. You can see a sliver of the front drivers tire not spinning.
  27. Mar 30, 2021 at 9:08 AM
    #267
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    Viktor, I notice when you launch you are not using brake-torque method, why is that?
    I just got a vbox and when I try to launch the truck the best I could get was 8+ sec in 0-100kmh since I spent half of the time sideways, that's brake-torque to about 1900rpm, launching in 2wd and tow mode.
  28. Mar 30, 2021 at 9:34 AM
    #268
    ViktorG
    Viktor
    Calgary, Canada
    The truck makes so much torque down low that it pushes through the brakes if I give it even half throttle.
    If your truck is 4x4, you should absolutely launch in 4wd.
  29. Mar 30, 2021 at 9:37 AM
    #269
    Downytide
    GTA
    Ok, I'm going to give that a try when truck is back home, I wonder what's the 1/4 time for a Harrop stage 1, I'm probably one of very few cares about ET on an off road truck, old habits die hard I guess.
  30. Mar 30, 2021 at 10:10 AM
    #270
    ViktorG
    Viktor
    Calgary, Canada
    On a 4 door 4x4 Tundra, I would expect high 13s/low 14s from Harrop stage 1
    Black@Blue19 likes this.
