Project Thundra - 9 second, 1000 hp daily driven AWD Tundra build
Discussion in '2nd Gen Builds (2007-2013)' started by ViktorG, Oct 11, 2019.
  1. Oct 7, 2020 at 5:04 PM
    #181
    You are free....that's what I heard anyways.....heh...heh...
  2. Oct 7, 2020 at 5:09 PM
    #182
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Been stalking me on Grinder again? :rofl:
    Filthyphil and omgboost like this.
  3. Oct 7, 2020 at 5:11 PM
    #183
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    how big of a shot are you running now and whats the highest you think you'll go?
  4. Oct 7, 2020 at 5:36 PM
    #184
    ViktorG
    ViktorG [OP] Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I was hitting it with a 100 shot when I ran 11.4
    I’ll go to whatever it takes to get to 9.xx once the blower is maxed, probably will need a 200-300 shot I’m guessing
  5. Oct 24, 2020 at 12:41 AM
    #185
    ViktorG
    Viktor
    Calgary, Canada
  6. Oct 24, 2020 at 4:51 AM
    #186
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Did you design the pulley or did the machine shop?
    My overly conservative preference would be steel in the larger rim with 0.001-002" interference on the hub, but bwdik. The extra weight is probably in the wrong performance direction. Hopefully, you'll get to try it out before Summer.
    ViktorG[OP] likes this.
  7. Oct 24, 2020 at 9:54 AM
    #187
    ViktorG
    Viktor
    Calgary, Canada
    Machine shop did. Steel was going to be super heavy, and sap the power from the engine as you mentioned.
  8. Oct 31, 2020 at 10:33 PM
    #188
    ViktorG
    Viktor
    Calgary, Canada
  9. Nov 1, 2020 at 7:38 AM
    #189
    Yzed608
    Yzed608 New Member
    Wisconsin
    Awesome! Were you able to use the same belt still? Interested to see how much more boost it makes than the other one.
  10. Nov 1, 2020 at 8:19 AM
    #190
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    ViktorG[QUOTED][OP] likes this.
  11. Nov 1, 2020 at 1:26 PM
    #191
    ViktorG
    Viktor
    Calgary, Canada
    I had to use a longer belt with this setup. The boost went up by about 3 PSI :)
  12. Nov 18, 2020 at 4:36 PM
    #192
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    I'm curious what else you had to do to "delete" the air injection system besides setting the secondary air fault A & B values to 86* I just installed the Harrop TVS2650, and removed the valves and pumps while I was in there...
  13. Nov 18, 2020 at 11:08 PM
    #193
    ViktorG
    Viktor
    Calgary, Canada
    Turn off all air injection related fault codes with HPTuners.
  14. Nov 18, 2020 at 11:10 PM
    #194
    ViktorG
    Viktor
    Calgary, Canada
    With the new pulley truck ran the best boost-only 1/4 mile time of 11.71 (spinning in AWD through the whole first gear) and best boost-only trap speed of 115 mph :)
    Vizsla, snivilous, Warreng and 5 others like this.
  15. Nov 19, 2020 at 12:00 AM
    #195
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    hands down, you have the most impressive build for a tundra. you give me inspiration to actually try and best you with my 3.4L tacoma... but we all know that wont happen! lol
    Tundra2 and ViktorG[QUOTED][OP] like this.
  16. Nov 19, 2020 at 5:54 AM
    #196
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Sweet, thank you sir!
  17. Dec 2, 2020 at 5:47 AM
    #197
    Silverghost
    Silverghost New Member
    13 tundra 4x4
    You are a genius, love your you tube vids. Your knowledge is incomparable.
  18. Dec 2, 2020 at 7:32 AM
    #198
    ViktorG
    Viktor
    Calgary, Canada
    Thank you brother, I appreciate the support!
  19. Dec 6, 2020 at 2:14 AM
    #199
    ViktorG
    Viktor
    Calgary, Canada
    omgboost, Vizsla, Toyotoholic and 5 others like this.
  20. Dec 6, 2020 at 2:39 AM
    #200
    Kelvin
    Kelvin New Member
    Is there a Gates racing belt with similar specs to yours?
  21. Dec 6, 2020 at 5:02 AM
    #201
    JohnLakeman
    Cool new "Viktor" intro...professional. :cool:
    That belt problem is going to be a tough one. Beyond the capabilities of the local machine shop.
  22. Dec 6, 2020 at 7:13 AM
    #202
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This makes me recall what was said to be happening with the S/C'd 1st Gen Tacomas ( I had one of these) when the blowers were overdriven. Although they were merely 4 rib belts and the interface was less, it was claimed that at higher RPMs the belts were floating off the pulley because the air couldn't escape from between the pulley and the belt, a kind of hydroplaning and then slipping. I wonder if this could've been what may have happened where the belt became askew and wandered off the pulley given the additional RPMs created by that huge crank pulley. Food for thought...:sandwich::monocle:
    JohnLakeman and ViktorG[OP] like this.
  23. Dec 6, 2020 at 8:10 AM
    #203
    JohnLakeman
    Whoa...That's interesting. Made me have a solution by fluid dynamics brain fart. :goingcrazy:
    ViktorG[OP] and Wynnded[QUOTED] like this.
  24. Dec 6, 2020 at 9:03 AM
    #204
    Yzed608
    Yzed608 New Member
    Wisconsin
    After watching a few other car youtubers mentioning it as well, I finally understand the trips to Mexico :p.
  25. Dec 6, 2020 at 11:33 AM
    #205
    Danimal86
    Daniel
    Sacramento, CA
    I'm diggin' the video intro!
  26. Dec 17, 2020 at 12:01 AM
    #206
    ViktorG
    Viktor
    Calgary, Canada
    dorton, Vizsla, NE_WARRIOR and 6 others like this.
  27. Dec 23, 2020 at 12:05 AM
    #207
    ViktorG
    Viktor
    Calgary, Canada
  28. Dec 23, 2020 at 12:52 AM
    #208
    Yzed608
    Yzed608 New Member
    Wisconsin
    I noticed one mod you can do to reduce your times. You've removed your headrest but not the passenger's, probably worth a few thousandths :rofl:. Keep on keepin' on!
  29. Dec 23, 2020 at 7:11 AM
    #209
    ViktorG
    Viktor
    Calgary, Canada
    LOL
    The driver side headrest is still inside the truck on the floor, so no weight reduction was achieved, I just can't fit my big head and a helmet comfortably there with it still on :rofl:
    Yzed608[QUOTED] and TundraLuv like this.
  30. Dec 23, 2020 at 9:08 AM
    #210
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    This is really awesome stuff @ViktorG !!!
    I love seeing those "Big muscle" cars in the rear view, just drifting away.
    ...and no one can say you don't have any balls to go through with a project like this... maybe because you post your nuts now as part of your intro! Lol. I laugh every time I start watching your videos.
    Always sub'd for me!
    TundraLuv and ViktorG[OP] like this.
