Project Thundra - 9 second, 1000 hp daily driven AWD Tundra build
Discussion in '2nd Gen Builds (2007-2013)' started by ViktorG, Oct 11, 2019.
  1. May 8, 2020 at 10:31 PM
    #121
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Why not HP Tuners and dyno tuning? Or are you just using the OV Tune for the shift features?
    Ponderosa_Pine and DR132 like this.
  2. May 9, 2020 at 1:40 AM
    #122
    ViktorG
    ViktorG [OP] Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    While there are guys in my area that have some experience with HP tuners, nobody has tuned a Tundra before. I didn't want to just get a basic fuel/timing tune and call it a day.
    I wanted VVTi, transmission shift points, transmission pressure, speed limiter, rev limiter, torque converter lock, gear hold etc adjusted.
    I figured it would take days for someone not familiar with the platform to figure all that out, which would cost a ton and risk blowing up my truck.
    OVtune seemed like a better option - he said he can do all that for 600 buck and remotely, so that is what I went with.
  3. May 16, 2020 at 10:55 AM
    #123
    ChargedToyo
    ChargedToyo New Member
    Mario
    2010 Grey
    So just curious why didn’t you go with haltech stand-alone?
  4. May 16, 2020 at 11:19 AM
    #124
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Are you running the 76mm throttle body? RCF TB 84mm? or did you retrofit a LS TB?
  5. May 16, 2020 at 12:10 PM
    #125
    ViktorG
    Viktor
    Calgary, Canada
    Money, I don’t have a lot of it
  6. May 16, 2020 at 12:10 PM
    #126
    ViktorG
    Viktor
    Calgary, Canada
    RC-F
    Mountun Goat likes this.
  7. Jun 1, 2020 at 12:29 AM
    #127
    ViktorG
    Viktor
    Calgary, Canada
  8. Jun 1, 2020 at 5:07 AM
    #128
    Yzed608
    Yzed608 New Member
    Wisconsin
    Nice! At pretty high elevation too.
    Mountun Goat, ViktorG[OP] and Midway like this.
  9. Jun 18, 2020 at 11:25 PM
    #129
    ViktorG
    Viktor
    Calgary, Canada
  10. Jun 19, 2020 at 7:09 AM
    #130
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I remember this was something that S/C'd 5VZ-FEs were trying as well. But the T-stats were usually available locally rather than custom. I also recall that bottom nut on the T-stat for our trucks being a little bugger to get to. Now it looks like you're really getting into uncharted territory.
    ViktorG[OP] likes this.
  11. Jul 5, 2020 at 1:23 AM
    #131
    ViktorG
    Viktor
    Calgary, Canada
    So, I ended up getting an HP tuner and building a tune myself. (Should've listened to your wise words 2 months ago)
    It literally took only one day and it is already much better than what I was getting from the tuner that I was using.
    Next step is to get it on a dyno and get it perfectly dialed in!
    https://www.youtube.com/watch?v=Hd8mU7eX7QE
  12. Jul 5, 2020 at 5:59 AM
    #132
    Adam New Member
    :burnrubber:Cant wait for the Dyno. Your gonna be making some hella numbers
  13. Jul 5, 2020 at 11:13 AM
    #133
    DR132
    DR132 New Member
    ALASKA
    2014 Tundra CM Platinum Blue Ribbon Metallic
    AWD Conversion, BAMuffler 8", Custom tuned with HPTuners, 2018+ LED Headlights, TRD front and rear sway bars
    Right on! Learning to tune can be a very rewarding experience! If you aren't already I definitely recommend joining the HPTuners forum. The Toyota tuning community is still pretty small but there are a couple guys who have figured out a fair bit about our ECMs so there is some very useful information that has been shared. As someone who's only tuned Chevy's until I bought my Tundra the way Toyota does certain things was not intuitive to me and they really helped me figure out the direction I needed to be going with my tune far easier than I would have on my own.
  14. Jul 5, 2020 at 11:30 AM
    #134
    ViktorG
    Viktor
    Calgary, Canada
    Will be hitting the dyno in the next few weeks or months, want to get my Meth injection sorted first so I can push some more ignition timing safely.
    Would also like to see if playing with VVTi angles at WOT will make any more power and I cannot easily quantify that on the street.
    Wynnded and AZTundra like this.
  15. Jul 5, 2020 at 11:31 AM
    #135
    ViktorG
    Viktor
    Calgary, Canada
    The Toyota Repository thread and the posts by the guy named "SlowNStock" got me started in right direction for sure. I joined the forum a couple days ago under "ViktorG".
    DR132[QUOTED], Wynnded and AZTundra like this.
  16. Jul 5, 2020 at 3:02 PM
    #136
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    ViktorG[QUOTED][OP] likes this.
  17. Aug 4, 2020 at 5:34 PM
    #137
    19greysport
    19greysport New Member
    2019 crewmax sport
    Just sent you a messAge on YouTube. I’m the one with the built x runner. Also have a 2019 tundra. Very interested in your build and follow u everywhere. Keep up the good work man!
    Warreng, Black@Blue19 and ViktorG[OP] like this.
  18. Aug 4, 2020 at 5:58 PM
    #138
    ViktorG
    Viktor
    Calgary, Canada
    Thank you sir :thumbsup:
    Black@Blue19 likes this.
  19. Aug 4, 2020 at 7:06 PM
    #139
    TemujinNomad
    TemujinNomad New Member
    How is everything with the new thermostat? I also recently installed the mishimoto type, along with new rad hoses and clamps, and noticed a similar decrease in temps. Regarding your disadvantages in your video, how low of coolant temps would cause concern?
  20. Aug 4, 2020 at 9:13 PM
    #140
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Congrats. Like popping in once in awhile and seeing what is new!! Nice going!!!!
  21. Aug 4, 2020 at 9:23 PM
    #141
    ViktorG
    Viktor
    Calgary, Canada
    Some tables in the ECU don’t activate until the coolant temperature is at 80 C or above. Mine is normally between 78-83, so I went in with HPTuners and lowered those temperature thresholds to 75 C. Other than that, I’ve had absolutely no issues.
  22. Aug 4, 2020 at 9:23 PM
    #142
    ViktorG
    Viktor
    Calgary, Canada
    Thank you :)
  23. Aug 7, 2020 at 3:31 PM
    #143
    19greysport
    2019 crewmax sport
    I’m trying to figure out a problem I’m having with the x runner and it keeps going into open loop and I don’t no why cruising down the high way. Hp tuners is a huge learning curve for me.
  24. Aug 7, 2020 at 5:24 PM
    #144
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You have a build thread about your x runner?
  25. Aug 7, 2020 at 8:30 PM
    #145
    DR132
    DR132 New Member
    ALASKA
    Deceleration fuel cutoff and power enrichment are both open loop fueling modes and will show in HPTuners scanner as OL Accel/decel. Tundra stock tunes have aggressive DFCO which give that strong engine braking effect which you'll see frequently whenever you're letting off the throttle. I would guess that's probably what you're seeing. Unfortunately we don't have access to any DFCO parameters at this point. Is this just a thing you noticed or are you experiencing problems as well?
  26. Aug 8, 2020 at 11:37 AM
    #146
    19greysport
    2019 crewmax sport
  27. Aug 8, 2020 at 11:40 AM
    #147
    19greysport
    2019 crewmax sport
    Just something I’m noticing. It says oldrive a lot. Just gotta keep messing with stuff. Also need a new intake. I’m maxing out my maf and I have it out behind my grill do it’s picking up turbulence and Probly messing things up.
  28. Aug 14, 2020 at 10:32 AM
    #148
    19greysport
    2019 crewmax sport
    Can you post ur tables for ghost cam tune? For spark advance
  29. Aug 15, 2020 at 12:50 AM
    #149
    ViktorG
    Viktor
    Calgary, Canada
    I might one day, but not yet.
  30. Aug 27, 2020 at 3:44 PM
    #150
    forrestgump8326
    forrestgump8326 New Member
    2007 Toyota Tundra SR5 Crewmax 5.7 S/C
    TRD Supercharged
    Hey there, currently building a 2wd s/c Tundra. Are you running the stock transmission and differential?
