Project Thundra - 9 second, 1000 hp daily driven AWD Tundra build
Discussion in '2nd Gen Builds (2007-2013)' started by ViktorG, Oct 11, 2019.
  1. Feb 7, 2020 at 9:17 AM
    #91
    tglyder
    tglyder Wise & Heimer
    NW Oregon
    Silver 2010
    So if, I mean when this project is complete and successful, will you reapply al this tech to a new motor that is fresh and hasn't suffered the learning curve for an every day driver? Or run this til' it blows up?
  2. Feb 7, 2020 at 10:29 AM
    #92
    ViktorG
    ViktorG [OP] Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I’m really hoping this is the last motor to go into this truck. I definitely don’t have the money to build another one.
    Mountun Goat likes this.
  3. Feb 7, 2020 at 9:29 PM
    #93
    ViktorG
    Viktor
    Calgary, Canada
    Installed the 75 mm pulley and boost went up to 10 PSI.
    Ran a couple 1/8th miles on a private road and picked up 4 mph from last runs (8.0 @ 86).
    Getting close to the numbers the TRD was putting out with the 50 mm top pulley.
  4. Feb 20, 2020 at 6:42 PM
    #94
    ViktorG
    Viktor
    Calgary, Canada
    Did a few adjustments and the truck did a 7.6@90 in the 1/8th mile on boost alone, which is what I was running with the TRD blower + nitrous :)
  5. Feb 20, 2020 at 6:45 PM
    #95
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  6. Feb 20, 2020 at 6:58 PM
    #96
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    HELL YEAH!!
    ViktorG[QUOTED][OP] likes this.
  7. Feb 20, 2020 at 7:02 PM
    #97
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    :headbang:
  8. Feb 22, 2020 at 5:43 PM
    #98
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Sick dude :headbang:
    ViktorG[QUOTED][OP] and AZTundra like this.
  9. Feb 25, 2020 at 3:49 PM
    #99
    ViktorG
    Viktor
    Calgary, Canada
  10. Mar 5, 2020 at 4:13 PM
    #100
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I just saw your new video. What are you going to do to get it into the 11’s? Hopefully you do it without using just nitrous
    sd_cavbluetundra and ViktorG[OP] like this.
  11. Mar 5, 2020 at 5:10 PM
    #101
    ViktorG
    Viktor
    Calgary, Canada
    I have a few more tricks up my sleeve ;)
    Stay tuned
  12. Mar 5, 2020 at 6:33 PM
    #102
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Trebuchet? ;):p
  13. Mar 5, 2020 at 7:09 PM
    #103
    ViktorG
    Viktor
    Calgary, Canada
    Hopefully I won’t have to go to that extreme lol
    Mountun Goat and Wynnded[QUOTED] like this.
  14. Mar 5, 2020 at 7:11 PM
    #104
    ViktorG
    Viktor
    Calgary, Canada
    Here is the best run without nitrous so far...
  15. Mar 5, 2020 at 7:28 PM
    #105
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'll bet that your YouTube subscriptions would skyrocket (almost a pun).
  16. Mar 11, 2020 at 9:51 AM
    #106
    ViktorG
    Viktor
    Calgary, Canada
  17. Mar 11, 2020 at 10:13 AM
    #107
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I just read your for sale post, not that I need a blower, but had some questions in general. You say the blower will make 12psi of boost with the 2.0 pulley. What elevation is that at and what do you monitor boost with? I have the URD pulley (2.35" or whatever), and near the ocean I make well over 10psi (I think I remember making 11+ before, but I don't live near the ocean so was just driving by once). I have an innovate digital boost/afr gauge I monitor off the driverside blower port. I'm just surprised that you have a considerably smaller pulley, but from the sounds of it it doesn't make that much more boost than what I'm seeing? Or am I missing something?
    Mountun Goat and ViktorG[OP] like this.
  18. Mar 11, 2020 at 10:19 AM
    #108
    ViktorG
    Viktor
    Calgary, Canada
    I'm at 3500 ft elevation, so the atmospheric pressure here is approximately 12.9 PSI vs 14.7 at sea level.
    I also have long tube headers which lowered my boost by around 1.5 PSI vs the stock manifolds.
    I’m using an Autometer digital boost gauge.
    At sea level with stock exhaust my TRD setup may potentially make 14+ PSI
  19. Mar 11, 2020 at 11:15 AM
    #109
    snivilous
    SW UT
    Awesome, that explains it! I was worried something was up, but your numbers make sense with what I see at the same elevation. Thank you sir!
  20. Mar 11, 2020 at 7:02 PM
    #110
    Rock15t
    Rock15t New Member
    2011 Sequoia SR5 5.7 4x4
    Pretty sweet build!
  21. Apr 2, 2020 at 11:23 PM
    #111
    ViktorG
    Viktor
    Calgary, Canada
    Finally! With BRX now twin turboed and in Dubai and Eddy's old truck parted out, this may just be the quickest current North American supercharged Tundra in the 1/4 mile :burnrubber:
  22. Apr 2, 2020 at 11:37 PM
    #112
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    you know. you really make me want to make my little reg cab fast. good thing suprastore makes things like dry sump for the 4.7!
  23. Apr 11, 2020 at 3:20 PM
    #113
    SoCalRandy
    SoCalRandy New Member
    Randy
    San Diego, California
    2020 MGM Limited Crewmax 4x4
    Subb’ed
    ViktorG[OP] likes this.
  24. May 8, 2020 at 8:59 AM
    #114
    Danimal86
    Daniel
    Sacramento, CA
    Any update?
  25. May 8, 2020 at 9:29 AM
    #115
    ViktorG
    Viktor
    Calgary, Canada
    Waiting on OVTune to get my tune sorted out. It is currently running super rich with the new tune and 750 cc injectors, got a few revisions but it still needs more work before I can full send it.
    Wynnded and Mountun Goat like this.
  26. May 8, 2020 at 12:54 PM
    #116
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Misses opportunity to casually provide link to His Own Private Island :rolleyes:;)
  27. May 8, 2020 at 1:41 PM
    #117
    ViktorG
    Viktor
    Calgary, Canada
  28. May 8, 2020 at 2:15 PM
    #118
    Adam New Member
    I gotta say Viktor, I look forward to your posts. I want to see your Tundra do the impossible. I love the videos you post with it. If you had the backing like Cletus Mcfarland, I am sure you could compete for the youtube views.
  29. May 8, 2020 at 2:43 PM
    #119
    ViktorG
    Viktor
    Calgary, Canada
    Thank you sir! To be like cleetus, I’d have to quit my job and just do videos every day :)
  30. May 8, 2020 at 10:04 PM
    #120
    TXTundra2722
    2015 Black Tundra
    I give you permission, go forth and conquer!
    :oldglory:
