Project Thundra - 9 second, 1000 hp daily driven AWD Tundra build
Discussion in '2nd Gen Builds (2007-2013)' started by ViktorG, Oct 11, 2019.
  1. Oct 27, 2019 at 6:42 PM
    #61
    Warbirds
    Warbirds New Member
    Dave
    ‘18 Crewmax SR5
    I love it!
    pure mad scientist/hot rodding!
    Mountun Goat and ViktorG[OP] like this.
  2. Oct 28, 2019 at 12:42 AM
    #62
    ViktorG
    ViktorG [OP] Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    My friend, you must not have read any of the posts in this thread.
    My engine has forged Pauter rods and JE pistons, ported/polished head with titanium 2UR-GSE valvetrain, I have a set of custom ground cams on the shelf in my garage (waiting for the OVtune that will allow me to rev past 7K before I install them), and there are Darton steel sleeves readily available for the block (even though you don't need them unless you are pushing well over 1000hp).
    My semi-gutted regular cab short box weighs 4800 lbs dry with full interior. That's not much heavier than a Dodge Challenger.
    Fully agree with you on that one, however with the AWD conversion that I did on the truck it makes it a lot easier to put the power down to the ground even without a trick suspension that is required on a RWD setup.
    Hmm, my truck is currently putting out in the neighborhood of 800 crank hp and BRX drives a 1045 whp twin turbo Tundra in Dubai that was built by Dynosty in the States (running 10.5 in RWD), so yes, it is very possible to build a 650 hp+ 3UR-FE.
    Thank you my good sir. Waiting on Whipple to release their blower they have been promising for the last 10 months.
    https://whipplesuperchargers.com/index.php?dispatch=products.view&product_id=502
    That's the next step in chasing my dream...
  3. Nov 24, 2019 at 9:27 AM
    #63
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    Out of curiosity, what would that parts list run out of pocket list price?
  4. Nov 24, 2019 at 9:42 AM
    #64
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    When I was reading the OVtune thread I was thinking about this build and how it would work with your setup. Glad to hear you'll try it out
  5. Nov 24, 2019 at 10:27 AM
    #65
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    @ViktorG been an while, any updates on the build?
    ViktorG[OP] likes this.
  6. Nov 24, 2019 at 10:33 AM
    #66
    Fire123
    Fire123 New Member
    2015 White 1794 Edition
    7" BDS w/ Fox, Fuel Wheels
    KILLER WORK, keep up the progress reports.
    ViktorG[OP] and Mountun Goat like this.
  7. Nov 26, 2019 at 1:06 PM
    #67
    ViktorG
    Viktor
    Calgary, Canada
    I had to have some surgery to repair a torn ligament in my wrist in October, so I won't be able to work on the truck for a couple more months unfortunately.
  8. Nov 26, 2019 at 1:12 PM
    #68
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    wow! How did you do that?! Hope you heal quickly. If I were closer I’d come turn a wrench for you
  9. Nov 26, 2019 at 1:15 PM
    #69
    ViktorG
    Viktor
    Calgary, Canada
    Work :(
    Mountun Goat likes this.
  10. Nov 26, 2019 at 1:19 PM
    #70
    ViktorG
    Viktor
    Calgary, Canada
    Rods ~$1800
    Pistons ~$1300
    Bearings ~$100
    ARP stud kit ~$360
    Machine work - depends, I paid around $3400 USD for mine including line hone, balance, assembly etc. etc.
  11. Nov 26, 2019 at 1:26 PM
    #71
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    Thanks!
  12. Nov 26, 2019 at 2:13 PM
    #72
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  13. Nov 26, 2019 at 2:50 PM
    #73
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Maybe I missed where it was said, but what is the reasoning to not go to a turbocharger setup? Why wait for the Whipple instead of parts already available?
  14. Nov 26, 2019 at 3:48 PM
    #74
    ViktorG
    Viktor
    Calgary, Canada
    I think the Whipple would be cheaper and easier overall, being a direct bolt on kit, and I also love the instant response of the supercharger vs a turbo.
    Installing a turbo kit would need a ton of custom plumbing work for intake/exhaust/oil and the plastic intake manifold would need to be replaced with an aluminum unit if you are gonna run big boost, which is another $5000 on top of everything else.
    The Whipple kit will likely be in the ~$7000 range, and to build a proper turbo kit (with intake) would be well over 10K
  15. Nov 26, 2019 at 8:00 PM
    #75
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Damn!:eek: Hope you heal quickly and well!
    ViktorG[QUOTED][OP] likes this.
  16. Jan 29, 2020 at 2:21 PM
    #76
    ViktorG
    Viktor
    Calgary, Canada
    Just ordered the Harrop TVS2650 along with smaller pulleys.
    Tired of Whipple dragging their a$$ on releasing the 2.9 twin screw for our platform.
    My cast is off and I am slowly recovering from the surgery, will try to install the new blower with help from friends and do some test runs in the next few weeks.
  17. Jan 29, 2020 at 2:31 PM
    #77
    Warreng
    Warreng New Member
    Glad you are getting better, looking forward to updates
  18. Jan 29, 2020 at 4:56 PM
    #78
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    X2
  19. Jan 30, 2020 at 1:04 AM
    #79
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    Are you running any aftermarket headers or still stock manifold?
    I’m really looking forward to this.
  20. Jan 30, 2020 at 3:52 AM
    #80
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    :popcorn: Awesome work. Im excited to see how this turns out. Hope u have a speed recovery :thumbsup:
  21. Jan 30, 2020 at 6:32 AM
    #81
    ViktorG
    Viktor
    Calgary, Canada
    It’s got JBA longtubes and midpipes with a stock muffler
  22. Feb 7, 2020 at 8:09 AM
    #82
    ViktorG
    Viktor
    Calgary, Canada
    Installed the Harrop blower last night.
    On the lowest boost (85mm) top pulley and the ASP crank pulley it peaks at 9 PSI.
    The truck is quite a bit slower now than it was on the TRD blower (50mm pulley at 14 PSI).
    Ran a couple of 1/8th miles yesterday night on a closed course and got only an 8.2 @ 82 mph (used to hit high 7s @ 87-89 mph on the TRD).
    Time to swap the smaller pulley in!
    https://www.youtube.com/watch?v=CgWqXARC3Iw
    Filthyphil, Darkness, ZPMAN and 11 others like this.
  23. Feb 7, 2020 at 8:20 AM
    #83
    Warreng
    Warreng New Member
    Heck ya! Nice video too
    Rica25 and ViktorG[QUOTED][OP] like this.
  24. Feb 7, 2020 at 8:33 AM
    #84
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Are you planning on putting back a similar nitrous back on? Are you planning on running with the 16 injector setup when you add a smaller pulley?
    Rica25 and ViktorG[OP] like this.
  25. Feb 7, 2020 at 8:48 AM
    #85
    Midway
    Midway New Member
    @ViktorG
    You installing the 80mm or 75mm?
  26. Feb 7, 2020 at 8:54 AM
    #86
    ViktorG
    Viktor
    Calgary, Canada
    I’ll be installing 750 cc injectors as soon as OV gets my tune ready. I won’t be doing 16 injectors, you have to buy a different blower setup from Harrop for that (pre-drilled holes for another set of rails and injectors).
    I’ll hold off on nitrous until the OV tune is done and the blower is maxed out. If I can’t reach my goals on motor alone, I’ll add spray back to it.
  27. Feb 7, 2020 at 8:55 AM
    #87
    ViktorG
    Viktor
    Calgary, Canada
    First the 75 and then the 65
  28. Feb 7, 2020 at 8:55 AM
    #88
    Midway
    Midway New Member
    Can't wait!
  29. Feb 7, 2020 at 9:05 AM
    #89
    tglyder
    tglyder Wise & Heimer
    NW Oregon
    Silver 2010
    Try coating the rods with a CVD (secret) film so you don't get build up (Sludge) on the rods. Same life but less loss from build-up on rods.
  30. Feb 7, 2020 at 9:14 AM
    #90
    tglyder
    NW Oregon
    Silver 2010
    This is a great Post.
    5N0W808, Tundyfundy, MS22 and 9 others like this.
