Programming Ignition key
Discussion in '2.5 Gen Tundras (2014-2021)' started by surfranger, Apr 28, 2018.
  1. Apr 28, 2018 at 2:07 PM
    surfranger
    surfranger [OP] New Member
    2018 Tundra Ltd. TRD 4x4
    On older Toyotas you could program (sync) a new ignition key by a procedure. (insert master key (5 times)...open and close door (6 times) within 30 sec.) If there is a procedure like this for my 2018, they are keeping it secret. Is it true the only way to sync a chipped key is using Techstream2 hookup?
  2. Apr 28, 2018 at 5:16 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Welcome from CO! Techstream is the only way grasshopper...
    NewImprovedRon likes this.
  3. Apr 28, 2018 at 5:50 PM
    surfranger
    Thanks for the info. Instead of paying dealer $100, im going to use the unsynced key in magnet box just to open door. then keep spare ignition key inside truck. They will never get my $100!!!
  4. Apr 28, 2018 at 5:54 PM
    boostedtrdpro
    Jeremy
    Just spend $30 or $60 depending on which cable you want (whether you want to capture live data or not) and download Techstream from here for free. Then you can also run diagnostics on your truck and change parameters in the trucks computer...such as turning off that pesky seat belt chime...if it bugs you.
  5. Feb 20, 2024 at 10:26 AM
    PNWtundrite
    PNWtundrite New Member
    2010 Tundra TRD rock warrior black
    Demello front number with winch and lights, Bilstein 5100 Eibach spring 3" front lift and 5100 rear 2" lift, Android auto stereo with front camera
    Ooh where's the download link!
