Programmable Thermostats
Discussion in 'Home Improvement' started by Outbound, Sep 29, 2019.
  1. Sep 29, 2019 at 7:30 AM
    Outbound
    Outbound [OP] SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    Our house came with a Vivint home system which for best functionality is tied into a paid subscription. Fuck that noise. So I'm starting to replace all of Vivint's equipment. First up is the thermostat. I'm thinking of a smart thermostat, but don't know if it's really required. No AC units, humidifiers etc to run. Just the furnace. Most important thing is that I can set weekday and weekend times for the furnace to run.
    Any suggestions on which ones to use and any install tips?
  2. Sep 29, 2019 at 7:35 AM
    Mnorris1206
    08 tundra
    Nothing to fancy. They have always had programmable thermostats before all this "smart" shit came about. Why dont you like the vivint. We have one and it's great to have really. Shows me on my phone any time any one comes around my home while I'm at work.
  3. Sep 29, 2019 at 7:50 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    I have an Emerson Sensi. “Smart” enough for me to control from anywhere but simple enough to do its job.
    But on a side note....hearing about people who don’t even have AC in their homes boggles my mind. lol. It’s still in the 90s here and the AC has been on since March lol
    TomC843 and Black Wolf like this.
  4. Sep 29, 2019 at 7:53 AM
    plinyyounger
    plinyyounger New Member
    Ken
    El Dorado Hills
    GTI 24
    I use nest, have been for the last two years. Works fantastic, I can control it via phone, tablet, voice or manually. No probs to speak of with the exception of a software glitch here and there which a reset takes care of.
    Outbound[OP] likes this.
  5. Sep 29, 2019 at 8:12 AM
    Outbound
    Aaron
    Northern Alberta
    The Vivint one doesn't seem to want to let me program it without using the Vivint home system panel, which is passcode protected. I don't have a passcode because I'm not willing to pay Vivint $50+ per month for monitoring. I'll be setting up my own security system instead, probably using Ring.
    I'd love to have central AC but it's very much a luxury expense since we only get a month or so a year on average where it'd really be needed. It doesn't get above 90F very often here and even then it's only for a couple days. This morning it's -6C (21F) and there's frost on the ground.
  6. Sep 29, 2019 at 8:16 AM
    Danman34
    Danman34 New Member
    Danny
    Southeast Louisiana here. AC is a must. We can live without heaters most winters haha.
    Outbound[QUOTED][OP] likes this.
  7. Sep 29, 2019 at 8:17 AM
    Dag3
    Dag3 New Member
    David
    Vail, Colorado
    2012 crew max limited
    Installed a Nest last year. It’s awesome. You can control it from anywhere with your phone.
  8. Sep 29, 2019 at 8:39 AM
    Mnorris1206
    08 tundra
    Call and talk with vivint I only pay 30 a month. For the monitoring.
  9. Sep 29, 2019 at 8:41 AM
    Jpneely
    Jpneely New Member
    White SR5 5.7
    we have 2 ecobee 4's. theyre ok. the "smart" features are kind of lost on me since I work rotating shifts, it cant figure out a schedule to run. we just ended up using ours as a thermostat that we can adjust from our phones. I think you can do that with a lot of others that aren't labeled "smart". as far as install goes, it was about as simple as you can get. pull old thermostat off the wall, label where all the wires were going. our ecobees came with nice tags to stick to them. then disconnect wires from old thermostat and plug into new one. boom. stick the new one on the wall. I know going from REALLY old thermostats to new ones has a few extra steps, but that's the experience I had with mine.
  10. Sep 29, 2019 at 8:53 AM
    Outbound
    Aaron
    Northern Alberta
    I did. $50 was the promo rate. Welcome to Canada...
    Mnorris1206[QUOTED] likes this.
  11. Sep 29, 2019 at 8:56 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I have a Honeywell wifi thermostat I use for our heater. Got it for $100 and received a $75 utility rebate.
  12. Sep 29, 2019 at 9:06 AM
    6XC
    6XC OPS4
    '18 MGM Tundra SR5 TSS Crewmax 4x4
    I use an Ecobee 4 and love it. It is especially nice if you have rooms that dont cool as well as others. You can add the small battery powered temp monitors in each room and the thermostat will average them to get the house temp instead of basing it off the temp at the thermostat.
  13. Sep 29, 2019 at 9:44 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Got a nest as well for the past few years and it's a must for this time of year with heat/cool (i'm sure others do this as well). Set a max temp and if exceeded the AC kicks on and set a low temp and the heat kicks on. Great for the New England fall when it's 40-85 degrees the same day. They also have an API that you can use if that's your thing to integrate it into any type of home automation system. Supports Alexa too so that's handy as well to just tell her what to set the temp to or to kick on the fan. I also use their smoke detectors and they work in conjunction with the thermostat. If smoke is detected they can run the house fan to move the smoke out and will also turn off the heater. The smoke detectors also act as occupancy sensors so your thermostat won't go into away mode if it's tucked away in a room you don't walk through often.
  14. Sep 29, 2019 at 10:15 AM
    Outbound
    Aaron
    Northern Alberta
    Great info everyone! Thanks alot. I'll look into the Nest for sure. Pretty neat how they work with smoke detectors.
  15. Sep 29, 2019 at 10:17 AM
    abomb60
    Massachusetts
    It's a neat feature but it has to be their smoke/co detectors. Gets spendy depending on the size of the house but they work well and i'm happy so far.
  16. Sep 29, 2019 at 10:19 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2FBA548A-61DE-4EDE-B90A-EEEF9A366788.jpg I use an Ecobee. I like it because I can put some remote sensors in various rooms of the house to help average the house’s temp. Also can set the heat to only my bedroom sensor in the night to make sure my bedroom is the proper temp. Also reminds me to change the filters after specific hours of runtime, alert me if the temp drops to low in the winter (alerting me to a heat problem before it becomes a pipe freezing problem) or to high in the summer(animals), Alexa voice control, etc. overall very happy with it. Looks nice too.
    Tchase and Outbound[OP] like this.
  17. Sep 29, 2019 at 10:31 AM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    That’s what we have too. No complaints. Simple and does the job, can control from anywhere
  18. Sep 29, 2019 at 10:37 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Auto thermostat It sure makes things easy.
  19. Oct 11, 2019 at 8:45 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I installed a nest in two homes. It is as close to plug and play as I think you can get. I love it, I can control it from anywhere. the programs actually work and it tells me the weather.
  20. Oct 11, 2019 at 9:11 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Meh, for just heat I can't see the benefit of smart thermostat. I use this one for my radiant heat and for $20 it'll do what you want it to.
  21. Oct 11, 2019 at 9:13 AM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Wow, Don't know how you guys do it. Been married 20 years and I am an HVAC tech and can't explain to the wife to just let it run and cycle. I am not kidding that I could replace our REQUIRED basic tstat and replace it with a switch and not much would change. If the units didn't have time delays she be killing compressors every 6 months.
  22. Oct 11, 2019 at 9:44 AM
    Mike Tread lightly.
    south carolina
    One thing I like about the ecobee... It has a timer on it for compressor restart and compressor off when it's too cold outside to run the unit just power on the heat strips.
    Tchase likes this.
  23. Oct 11, 2019 at 9:51 AM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    I have always used Honeywell WiFi Thermostats, never had any issue, I'm currently using a Honeywell T9 WiFi Thermostat , the cool thing about this thermostat is that you can add sensors to those rooms that don't get very cool/hot to get a more even cooling/heating around the house, works great and the Honeywell Home app works flawlessly.
  24. Oct 11, 2019 at 9:54 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Just got the Ecobee, liking it can schedule, for home, away, bet comes with extra sensor and nice app.
  25. Oct 11, 2019 at 9:55 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    ^ and check for rebates with your energy provider I got a $75 rebate.
  26. Oct 11, 2019 at 10:16 AM
    owb2gp
    owb2gp New Member
    ID
    What he said.
    I work for a local power company and we offer rebates on digital and smart thermostats if your primary heat is electric. Worth looking into for sure.
    Tchase[QUOTED] likes this.
  27. Oct 11, 2019 at 10:23 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Ours gas and still qualified. Also we have Heat and A/C but I think it is also well worth if you just have heat. We have a large house and with the kids at college we've shut off a lot of rooms that extra sensor is nice. The only down side to the smart thermo IMHO is it is cold as F if you have to get up and pee at night LOL
  28. Oct 11, 2019 at 10:48 AM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I use a programmable tstat. All this Nest crap is over hyped. Mine has weekday, weekend, vacation, and multiple daily settings. I have no need to be able to control my tstat from my phone or computer. Now I might see a use for someone that is not on a regular schedule.
  29. Oct 11, 2019 at 11:35 AM
    owb2gp
    owb2gp New Member
    ID
    Yes, some gas companies have rebates also.
