ProComp Pro Runners or Blistein 5100
Discussion in 'Suspension' started by racin, Sep 26, 2015.
  1. Sep 26, 2015 at 4:43 AM
    racin
    racin [OP] zmr
    Tampa, FL
    2015 Met.Gray 4x4
    Anyone running the Blistein 5100 or ProComp Pro Runners? they are both 2.5" level shocks setup ...If you do have these what tire/rim setup are you also running...I personally was planning on going with 20x10 rims with Toyo 33x12.5 wanted to check first to see if anyone have a similar setup thanks
  2. Dec 21, 2015 at 8:13 PM
    lbcdan
    lbcdan Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    Bump. Interested as well.
    zcarpenter92 likes this.
  3. Dec 16, 2020 at 6:20 AM
    Loose
    Loose New Member
    2020 Platnium
    I know I am resurrecting and old and ignored thread but...
    ...I am about to put the Pro Comp 2.5 pro runners on all 4 corners with a Icon add a leaf rear springs and a differential drop. I was not able to find too much here on the forum regarding the Pro Comp stet up. Bilstein's are out of stock and no restock is noted in the available future. Not sure what everyone's experience here is but it is what is available at this time. I also plan on a 20x9 with a +20 offset and I am looking to run a 295 tire.
    Does anyone else have a similar setup?
    Sorry for zombifying this thread.
  4. Dec 16, 2020 at 6:26 AM
    Loose
    Loose New Member
    2020 Platnium
  5. Dec 16, 2020 at 6:27 AM
    Loose
    Loose New Member
    2020 Platnium
  6. Dec 16, 2020 at 7:56 AM
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    Will the procomp pro runner shocks fit the rear on a truck with a 6 inch lift?
    Loose likes this.
  7. Dec 16, 2020 at 8:17 AM
    Loose
    Loose New Member
    2020 Platnium
    I am not getting a 6" lift so I dont know that answer to that. The system I am installing will give me 3" in the front and 1.5 in the rear. I am told the add a leaf will allow the truck to remain more level when the bed is loaded
  8. Dec 16, 2020 at 8:33 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 Crewmax 4x4, Bronze
    Ongoing... probably never ending
    Forget about the diff drop on 2.5" lift, you wont be needing it even at 3". ProRunners are more comparable to Bilstein 6112, but at that pricepoint you're better off spending on Fox, Icon or King, they're 100% revalveable, rebuildable, high quality and race proven.
  9. Dec 16, 2020 at 8:55 AM
    Loose
    Loose New Member
    2020 Platnium
    The Icon and Fox are substantially more $$$. The Bilsteins are cheaper but
  10. Dec 16, 2020 at 9:08 AM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    Are the procomp fronts not ~$700 a piece? perhaps I'm looking at something else
  11. Dec 16, 2020 at 9:17 AM
    Loose
    Loose New Member
    2020 Platnium
    I am getting the fronts for 549.99 and the rears for 299.99
  12. Dec 16, 2020 at 9:21 AM
    C.I.
    Cesar Pedrin
    Cabo, Mx
    Disregard my comment then :D
    But yeah, dont do the diff drop.
    Loose likes this.
  13. Dec 16, 2020 at 11:12 AM
    mtndds98
    mtndds98 New Member
    I just got off the phone with Pro Comp. These will not work with a 6 inch lift. Bummer. Only up to 3-4" lifts.
  14. Dec 19, 2020 at 5:53 PM
    Loose
    Loose New Member
    2020 Platnium
  15. Dec 19, 2020 at 5:57 PM
    Loose
    Loose New Member
    2020 Platnium
    After...
    Pro Comp Prorunner 2.5 coilovers with external rez up front and Prorunner 2.5 shocks in back. Icon "add a leaf" and i went with the diff drop (it was 30 bucks)20201219_171750.jpg 20201219_171727.jpg
    C.I. and mtndds98 like this.
  16. Dec 19, 2020 at 5:58 PM
    Loose
    Loose New Member
    2020 Platnium
    I put 600lbs in the back today and no real sag...
    Ride appears improved. Overall I am happy.
    Next....wheels and tires.
    mtndds98 likes this.
  17. Dec 19, 2020 at 7:42 PM
    Bravohook
    Bravohook New Member
    Addame
    Last Best Place, Montana
    2015 SR5 TRD OR MGM
    Cool Things
    How would you describe the ride??? I have been eyeing these up for a bit, but like you did not see any reviews or feedback on them. Currently have 5100's and I'm not supper thrilled about them....I have been leaning towards the OME BP51's
    Loose likes this.
  18. Dec 20, 2020 at 5:19 PM
    Loose
    Loose New Member
    2020 Platnium
    Firm and stiffer but smoother over stock. It is harx to describe. Wife says the truck feels more "planted and sure footed" i habe only gone down a dirt road so no heavy off roading yet
    Dansly56 and Bravohook like this.
  19. Dec 20, 2020 at 6:49 PM
    Bravohook
    Addame
    2015 SR5 TRD OR MGM
    Cool Things
    Coop, thanks man. I like the look of them
  20. Feb 1, 2021 at 12:49 PM
    brown1794
    brown1794 New Member
    Joey
    Windsor, Va
    2015 sunset bronze mica 1794
    I cant seem to find a prorunner 2.5. Where can i get these? Thanks. Sounds sweet!
  21. Feb 1, 2021 at 12:53 PM
    Bravohook
    Addame
    2015 SR5 TRD OR MGM
    Cool Things
    Big J and Loose like this.
