Procomp lift
Discussion in 'Suspension' started by Dustydirt19, Mar 30, 2017.
  1. Mar 30, 2017 at 8:59 PM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Surprise surprise I'm thinking again... I know a lot of guys don't like the procomp lift bit I was curious if that was just the 6in or did you not like the stage 2 with coilovers as well? I like the looks of a 6 in lift. I know there are lots of votes for the BOSS kit but I'm assuming you guys wheel a lot where I won't as much. My offroading would mostly be hunting. So I guess my question is...is the stage 2 procomp lift a bad idea or if I really want a 6in should I go BDS or Fabtech for an extra G? Like I said not much wheeling will be done and I don't wanna break the bank. Input needed. Thanks
  2. Mar 30, 2017 at 9:35 PM
    Dustydirt19
    Dustin
    Duluth, MN
    The 6 in stage 2 I was looking at have the coilovers so I would assume that'd be a little better for the offroad factor for the little bit that I will be doing. I just don't know if it's worth the extra grand to get a bds or fabtech when it may be overkill for what I will do with it. I hate to use the term but it's gonna be 75% mall crawler 25% offroad
  3. Mar 30, 2017 at 9:40 PM
    TheBeast The Beach
    it's not that bad. It will be fine for your use / budget
    GNTundra likes this.
  4. Mar 30, 2017 at 9:47 PM
    DVYota
    DVYota Super stock street truck
    South Carolina
    2014 Sequoia 2021 Tacoma
    Basically stock
    This. the world needs more people that think like this.
  5. Mar 30, 2017 at 9:51 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I've seen the 6 inch pro comp stage 2 and the 7 inch BDS with C/O for about $700 difference.. check around you can get better than a 1K difference:)
    Law323 likes this.
  6. Mar 30, 2017 at 9:53 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Mainly for looks but also functionality. I can get 35s on a boss lift but I like the height of a 6in lift. I don't want the suspension to be absolute junk but it doesn't need to be super high end for what I will be using it for. I'm looking for middle of the road
    Law323 likes this.
  7. Mar 30, 2017 at 9:54 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    If you're just wanting 35's, I'd go with the Boss kit. If you want 37's, go 6". Just my opinion. But hey man, if you want 6", rock it.
    Law323 and TheBeast like this.
  8. Mar 30, 2017 at 9:55 PM
    Dustydirt19
    Dustin
    Duluth, MN
    Even 700 is more than I'd like to swing. I'm hitting my limit with the procomp price plus rims tires etc
  9. Mar 30, 2017 at 10:24 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    If you're not gong to off road and just want the look drop the Coils for now and get the lift for $1300 cheaper.. that will at least cover your new tires or rims with that saving
  10. Mar 31, 2017 at 3:04 AM
    taichou
    taichou New Member
    Hawaii
    2017 Metallic Gray Tundra TRD Off-Road
    Agreed. I just bought the procomp stage 1 with the prorunner front and rear shocks. Going to upgrade the shocks later. I was in a similar situation as you with the tires wheels etc.
    Jsena[QUOTED] likes this.
  11. Mar 31, 2017 at 5:03 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Having ridden in similar vehicles, both with 6" PC lifts, I can say definitively that the Stage II rides a LOT nicer.
    (Break break)
    If you're loooking for trail functionality, and ground clearance if the undercarriage, a bigger tire is what you want. If you can stuff 35's on a 3" lift, you are ultimately getting the same undercarriage clearance as you would with 35's on a 6" lift. The 6" will get your body off the ground a little more (which is why I went with the 6" as well; this was solely due to the longer wheelbase)
    I'm not really sure why I hear a lot of folks trashing the PC stuff. If installed properly, kept clean and maintained, it does exactly what it was designed to do. :thumbsup:
  12. Mar 31, 2017 at 8:43 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Do you have pictures do your truck
  13. Mar 31, 2017 at 9:00 AM
    Bear
    Bear
    Custer, SD
  14. Mar 31, 2017 at 9:07 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    I bet when you actually look at the days you offroad it will come significantly less than 25% :thumbsup:
    That essentially means 1 week out of the month you offroad daily. I have significantly overestimated my needs prior.
    AnonVet, Bear and Law323 like this.
  15. Mar 31, 2017 at 9:22 AM
    Dustydirt19
    Dustin
    Duluth, MN
    I'm liking the looks of your ride @Bear what size tires and rims you running and do you have anymore pics? Front, back, slaying mud etc. Also any issues at all with it?
  16. Mar 31, 2017 at 9:22 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yup, it's more like 2.5% :D
    Law323 and Dustydirt19[OP] like this.
  17. Mar 31, 2017 at 9:34 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Also how much was install?
  18. Mar 31, 2017 at 9:59 AM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    I have the stage one lift. I bought it that way. I do take my truck out in the sand dunes to take my kids around. As long as your careful the spacer should be fine. I may upgrade to Stage 2 front later unless we go from quads to 4seater sxs. I wouldn't use my truck in the dunes under that situation. As for the other two options if I was to start with a stock truck I would personally go with BDS and Fox shocks. Wouldn't even consider the Fabtech but that's just my personal opinion. Pics just for reference.
    Otaku4life69 likes this.
  19. Mar 31, 2017 at 10:03 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What size rims ans tires are you using in this pic
  20. Mar 31, 2017 at 10:05 AM
    Juanjoolio007
    Oregon
    18" Fuel wheels and 35x12.50 Pro comp tires
    Bear and Jsena[QUOTED] like this.
  21. Mar 31, 2017 at 11:08 AM
    Bear
    Bear
    Custer, SD
    18x9 Fuel Beast +1mm offset. 35x18x12.5 Renegade R7 MT. No issues as of yet. Going in tomorrow for a re-alignment (part of the warranty).
    Had the same setup on my FJ for a tad over 3 yrs and almost 61k miles before the shocks started showing signs of needing a rebuild. My FJ was NOT treated nicely btw. LolIMG_3626.jpgIMG_3628.jpgIMG_4539.jpgIMG_3536.jpg
  22. Mar 31, 2017 at 11:10 AM
    Bear
    Bear
    Custer, SD
    Wheels n tires were 1400, the lift ran 2900 installed after rebates. Justifiable for me given what I tend to use my trucks for.
  23. Mar 31, 2017 at 11:14 AM
    Juanjoolio007
    Oregon
    @Bear do you know if upgrading is as simple as ditching the front shocks/spacers and putting in the coilovers? I upgraded a 6" to 8" on a F250 years ago. Huge PITA.
  24. Mar 31, 2017 at 11:25 AM
    Dustydirt19
    Dustin
    Duluth, MN
    It was 2900 for the lift and install? Place by me wanted 2900 for the stage II lift plus 2k to install!!!
  25. Mar 31, 2017 at 11:25 AM
    Dustydirt19
    Dustin
    Duluth, MN
    Quadruple like
  26. Mar 31, 2017 at 11:28 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I've been lookin around a lot.. seems like $1000-1300 for install over here in vegas
  27. Mar 31, 2017 at 12:40 PM
    Bear
    Bear
    Custer, SD
    Holy Jeebus!!! 4 Wheel Parts El Paso. I kinda have a repore with the organization though...and a Mil discount.
    YMMV.
  28. Mar 31, 2017 at 12:44 PM
    Bear
    Bear
    Custer, SD
    Ouch. Man. Guess I was lucky back in the day. Our club did a lot of things with the 4WP guys...I got that install free on the FJ. They were charging $800 normally. It's who you know, not always what you know that makes the world go round???
  29. Mar 31, 2017 at 12:46 PM
    Bear
    Bear
    Custer, SD
    Having done several kits on multiple vehicles over the years, I will say this...these days my time is more valuable than my money. I don't regret having someone else do the work on these lifts. CuttIng the cross member alone and replacing the spindles (pressing bearings and such) is worth it alone. The rest of the stuff is relatively easy
    TheBeast likes this.
  30. Mar 31, 2017 at 12:49 PM
    Bear
    Bear
    Custer, SD
    Best I could tell...looks like the major difference in the two kits is the coilovers and MX6 shocks out back. The small block and add-a-leafs look the same. Not sure what kind of pain it is getting those massive coilovers in upfront though. I reckoned n you'd have to tear apart most of the front suspension linkage.
